| 3 | |
| 4 | |
| 5 | {{{ |
| 6 | $ valgrind ogrinfo /vsizip/ticket5464.gdb.zip/tmp.gdb/a00000003.gdbtable -al |
| 7 | ==23995== Memcheck, a memory error detector |
| 8 | ==23995== Copyright (C) 2002-2009, and GNU GPL'd, by Julian Seward et al. |
| 9 | ==23995== Using Valgrind-3.6.0.SVN-Debian and LibVEX; rerun with -h for copyright info |
| 10 | ==23995== Command: ogrinfo /vsizip/ticket5464.gdb.zip/tmp.gdb/a00000003.gdbtable -al |
| 11 | ==23995== |
| 12 | Had to open data source read-only. |
| 13 | INFO: Open of `/vsizip/ticket5464.gdb.zip/tmp.gdb/a00000003.gdbtable' |
| 14 | using driver `OpenFileGDB' successful. |
| 15 | |
| 16 | Layer name: GDB_SpatialRefs |
| 17 | Geometry: Unknown (any) |
| 18 | Feature Count: 2 |
| 19 | Layer SRS WKT: |
| 20 | (unknown) |
| 21 | FID Column = ID |
| 22 | SRTEXT: String (0.0) |
| 23 | FalseX: Real (0.0) |
| 24 | FalseY: Real (0.0) |
| 25 | XYUnits: Real (0.0) |
| 26 | FalseZ: Real (0.0) |
| 27 | ZUnits: Real (0.0) |
| 28 | FalseM: Real (0.0) |
| 29 | MUnits: Real (0.0) |
| 30 | XYTolerance: Real (0.0) |
| 31 | ZTolerance: Real (0.0) |
| 32 | MTolerance: Real (0.0) |
| 33 | OGRFeature(GDB_SpatialRefs):1 |
| 34 | SRTEXT (String) = GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]] |
| 35 | FalseX (Real) = -180 |
| 36 | FalseY (Real) = -90 |
| 37 | XYUnits (Real) = 1000000 |
| 38 | FalseZ (Real) = (null) |
| 39 | ZUnits (Real) = (null) |
| 40 | FalseM (Real) = (null) |
| 41 | MUnits (Real) = (null) |
| 42 | XYTolerance (Real) = 2e-06 |
| 43 | ZTolerance (Real) = (null) |
| 44 | MTolerance (Real) = (null) |
| 45 | |
| 46 | ==23995== Invalid write of size 1 |
| 47 | ==23995== at 0x5A9D483: OpenFileGDB::FileGDBTable::SelectRow(int) (filegdbtable.cpp:1082) |
| 48 | ==23995== by 0x5D09FBD: OGROpenFileGDBLayer::GetNextFeature() (ogropenfilegdblayer.cpp:1249) |
| 49 | ==23995== by 0x40434D: ReportOnLayer(OGRLayer*, char const*, char const*, OGRGeometry*) (ogrinfo.cpp:557) |
| 50 | ==23995== by 0x403929: main (ogrinfo.cpp:334) |
| 51 | ==23995== Address 0x17785ab2 is 0 bytes after a block of size 242 alloc'd |
| 52 | ==23995== at 0x4C274A8: malloc (vg_replace_malloc.c:236) |
| 53 | ==23995== by 0x5A05BB1: VSIMalloc (cpl_vsisimple.cpp:505) |
| 54 | ==23995== by 0x5A9BD7C: OpenFileGDB::FileGDBTable::Open(char const*) (filegdbtable.cpp:670) |
| 55 | ==23995== by 0x5D06F89: OGROpenFileGDBLayer::BuildLayerDefinition() (ogropenfilegdblayer.cpp:255) |
| 56 | ==23995== by 0x5D07723: OGROpenFileGDBLayer::GetGeomType() (ogropenfilegdblayer.cpp:414) |
| 57 | ==23995== by 0x403D89: ReportOnLayer(OGRLayer*, char const*, char const*, OGRGeometry*) (ogrinfo.cpp:460) |
| 58 | ==23995== by 0x403929: main (ogrinfo.cpp:334) |
| 59 | ==23995== |
| 60 | OGRFeature(GDB_SpatialRefs):2 |
| 61 | SRTEXT (String) = GEOGCS["GCS_Australian_Antarctic_1998",DATUM["D_Australian_Antarctic_1998",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]] |
| 62 | FalseX (Real) = -400 |
| 63 | FalseY (Real) = -400 |
| 64 | XYUnits (Real) = 1000000000 |
| 65 | FalseZ (Real) = -100000 |
| 66 | ZUnits (Real) = 10000 |
| 67 | FalseM (Real) = (null) |
| 68 | MUnits (Real) = (null) |
| 69 | XYTolerance (Real) = 8.983153e-09 |
| 70 | ZTolerance (Real) = 0.001 |
| 71 | MTolerance (Real) = (null) |
| 72 | }}} |
