Changes between Initial Version and Version 1 of Ticket #4129
- Jul 24, 2011, 3:08:29 PM (13 years ago)
Ticket #4129 – Description
initial v1 1 1 Hi, While debugging my application I get a kernel resource leak. The following is the call stack. The application is only calling GDALAllRegister() and GDALDestoryDriverManager(). The same leak happens with the example applications. I've also tried older versions of gdal. My OS is windows 7 and I tried both x86 and 64bit. 2 2 {{{ 3 3 ID Description Source Function Module Object Size State 4 4 X2 Synchronization object handle creation site cpl_multiproc.cpp:480 CPLCreateMutex gdal18.dll New … … 13 13 gdal18.dll!GDALDestroyDriverManager - gdaldrivermanager.cpp:687 14 14 main - main.cpp:507 15 15 }}}
