Changes between Initial Version and Version 1 of Ticket #3775
- Oct 7, 2010, 10:22:29 AM (14 years ago)
Ticket #3775 – Description
initial v1 1 In method TABFile::GetSpatialRef, on line 1037, the following statement uses 'atof'to convert the SRS_UA_DEGREE_CONV string to double.1 In method {{{TABFile::GetSpatialRef}}}, on line 1037, the following statement uses {{{atof}}} to convert the SRS_UA_DEGREE_CONV string to double. 2 2 3 3 {{{ … … 12 12 This causes problems when the current locale has not "." as the decimal separator (results in 0 instead of 0.0174532925199433) 13 13 14 Simply replacing 'atof' with 'CPLAtof' solves the problem. 14 '''Fix ::''' 15 16 Simply replacing {{{atof}}} with {{{CPLAtof}}} solves the problem.
