Changes between Initial Version and Version 1 of Ticket #2216
- Feb 11, 2008, 9:33:39 AM (16 years ago)
Ticket #2216
- Property Status new → closed
- Property Resolution → fixed
Ticket #2216 – Description
initial v1 3 3 1) The redefinitions of copysign, copysignf and copysignl to _copysign in cpl_config.h.vc causes syntax errors while including the mingw math.h. The solution is to only redefine them if the compiler in use is MS VC++. 4 4 5 2) Currently CPL_STDCALL is only being redefined to _ _stdcall for VC++ compilers. This means that an MinGW app build against a VC++ built GDAL does not use stdcall where appropriate. The solution is for cpl_config.h.vc to always define CPL_STDCALL to __stdcall as long as CPL_DISABLE_STDCALL is not defined.5 2) Currently CPL_STDCALL is only being redefined to _ _stdcall for VC++ compilers. This means that an MinGW app build against a VC++ built GDAL does not use stdcall where appropriate. The solution is for cpl_config.h.vc to always define CPL_STDCALL to _ _stdcall as long as CPL_DISABLE_STDCALL is not defined. 6 6
