Changes between Initial Version and Version 5 of Ticket #1323
- Apr 8, 2007, 7:02:36 AM (17 years ago)
Ticket #1323 – Description
initial v5 1 {{{2 1 importWkb methods corrupt XYZM data when importing it since the dimension is incorrectly set to 2.5D. The dimension could be checked in the methods by statement 3 2 … … 6 5 The vertex data can be correctly imported then in XYZM case using 7 6 7 {{{ 8 8 for( i = 0; i < nPointCount; i++ ) { 9 9 memcpy( paoPoints + i, pabyData + 9 + i*32, 16 ); 10 10 memcpy( padfZ + i, pabyData + 9 + 16 + i*32, 8 ); 11 11 } 12 }}} 12 13 13 14 which should be executed if dimension == 4 14 15 15 16 This is related to #1036 and should be fixed when it is fixed. The M data is discarded in both fixes, but support for it should be added to OGR. I'd be in fact interested in doing that. 16 }}}
