Changes between Version 4 and Version 5 of WikiProcessors
- 05/08/22 15:10:32 (3 years ago)
TabularUnified WikiProcessors
v4 v5 1 1 = Wiki Processors 2 2 3 Processors are WikiMacros designed to provide alternative markup formats for the [TracWiki Wiki engine]. Processors can be thought of as ''macro functions to process user-edited text''.3 Processors are WikiMacros that provide alternative markup formats for the [TracWiki Wiki engine]. Processors can be thought of as ''macro functions to process user-edited text''. 4 4 5 5 Wiki processors can be used in any Wiki text throughout Trac, such as: 6 6 - [#CodeHighlightingSupport syntax highlighting] or for rendering text verbatim 7 - rendering [#HTMLrelated Wiki markup inside a context] , like inside <div> blocks or <span>or within <td> or <th> table cells8 - using an alternative markup syntax, like [WikiHtml raw HTML] and [WikiRestructuredText Restructured Text] or [http ://www.textism.com/tools/textile/textile]7 - rendering [#HTMLrelated Wiki markup inside a context] such as <div> or <span> blocks or within <td> or <th> table cells 8 - using an alternative markup syntax, like [WikiHtml raw HTML] and [WikiRestructuredText Restructured Text] or [https://www.booked.net/textism.html textile] 9 9 10 10 == Using Processors … … 40 40 {{{#!td colspan=2 align=center style="border: none" 41 41 42 __Example 1__: Inserting raw HTML42 '''Example 1''': Inserting raw HTML 43 43 }}} 44 44 |----------------------------------------------------------------- … … 60 60 {{{#!td colspan=2 align=center style="border: none" 61 61 62 __Example 2__: Highlighted Python code in a <div> block with custom style62 '''Example 2''': Highlighted Python code in a <div> block with custom style 63 63 }}} 64 64 |----------------------------------------------------------------- … … 94 94 {{{#!td colspan=2 align=center style="border: none" 95 95 96 __Example 3__: Searching tickets from a wiki page, by keywords.96 '''Example 3''': Searching tickets from a wiki page, by keywords. 97 97 }}} 98 98 |----------------------------------------------------------------- … … 155 155 || '''`#!th`''' || Wrap wiki content inside a <th> element. (''since 0.12'') || 156 156 || '''`#!tr`''' || Can optionally be used for wrapping `#!td` and `#!th` blocks, either for specifying row attributes or better visual grouping. (''since 0.12'') || 157 || '''`#!table`''' || Can optionally be used for wrapping `#!tr`, `#!td` and `#!th` blocks, for specifying table attributes. One current limitation however is that tables cannot be nested. (''since 0.12'') || 157 || '''`#!table`''' || Can optionally be used for wrapping `#!tr`, `#!td` and `#!th` blocks, for specifying table attributes. One current limitation however is that tables cannot be nested. (''since 0.12'') || 158 158 || || See WikiHtml for example usage and more details about these processors. || 159 159 |||| || 160 160 ||||= '''Other Markups''' =|| 161 161 || '''`#!rst`''' || Trac support for Restructured Text. See WikiRestructuredText. || 162 || '''`#!textile`''' || Supported if [http ://cheeseshop.python.org/pypi/textile Textile] is installed. See [http://www.textism.com/tools/textile/a Textile reference]. ||162 || '''`#!textile`''' || Supported if [https://pypi.org/project/textile Textile] is installed. See [https://www.booked.net/textism.html a Textile reference]. || 163 163 |||| || 164 164 ||||= '''[=#CodeHighlightingSupport Code Highlighting Support]''' =|| 165 || '''`#!c`''' [[BR]] '''`#!cpp`''' (C++) [[BR]] '''`#!python`''' [[BR]] '''`#!perl`''' [[BR]] '''`#!ruby`''' [[BR]] '''`#!php`''' [[BR]] '''`#!asp`''' [[BR]] '''`#!java`''' [[BR]] '''`#!js`''' (Javascript) [[BR]] '''`#!sql`''' [[BR]] '''`#!xml`''' (XML or HTML) [[BR]] '''`#!sh`''' (!Bourne/Bash shell) [[BR]] '''etc.''' [[BR]]|| Trac includes processors to provide inline syntax highlighting for source code in various languages. [[BR]] [[BR]] Trac relies on [http://pygments.org Pygments] for syntax coloring. [[BR]] [[BR]] See TracSyntaxColoring for information about which languages are supported and how to enable support for more languages. ||165 || '''`#!c`''' [[BR]] '''`#!cpp`''' (C++) [[BR]] '''`#!python`''' [[BR]] '''`#!perl`''' [[BR]] '''`#!ruby`''' [[BR]] '''`#!php`''' [[BR]] '''`#!asp`''' [[BR]] '''`#!java`''' [[BR]] '''`#!js`''' (Javascript) [[BR]] '''`#!sql`''' [[BR]] '''`#!xml`''' (XML or HTML) [[BR]] '''`#!sh`''' (!Bourne/Bash shell) [[BR]] || Trac includes processors to provide inline syntax highlighting for source code in various languages. [[BR]] [[BR]] Trac relies on [http://pygments.org Pygments] for syntax coloring. [[BR]] [[BR]] See TracSyntaxColoring for information about which languages are supported and how to enable support for more languages. || 166 166 |||| || 167 167 … … 271 271 For more processor macros developed and/or contributed by users, visit the [https://trac-hacks.org Trac Hacks] community site. 272 272 273 Developing processors is no different from Wiki macros. In fact, they work the same way, only the usage syntax differs. See WikiMacros#DevelopingCustomMacros for more information.273 Processors are implemented using the same interfaces as Wiki macros, only the usage syntax differs. To develop a processor, see WikiMacros#DevelopingCustomMacros. 274 274 275 275 ----
