Changes between Version 2 and Version 3 of WikiProcessors
04/22/15 15:13:48 (10 years ago)
  • TabularUnified WikiProcessors
    v2 v3
    1 = Wiki Processors =
     1= Wiki Processors
    33Processors are WikiMacros designed to provide alternative markup formats for the [TracWiki Wiki engine]. Processors can be thought of as ''macro functions to process user-edited text''.
    44
    5 The Wiki engine uses processors to allow using [wiki:WikiRestructuredText Restructured Text], [wiki:WikiHtml raw HTML] and [http://www.textism.com/tools/textile/ textile] in any Wiki text throughout Trac.
    8 == Using Processors ==
    10 To use a processor on a block of text, use a Wiki code block, selecting a processor by name using ''shebang notation'' (#!), familiar to most UNIX users from scripts.
    12 '''Example 1''' (''inserting raw HTML in a wiki text''):
    13
     5Wiki processors can be used in any Wiki text throughout Trac, such as:
     6 - [#CodeHighlightingSupport syntax highlighting] or for rendering text verbatim
     7 - rendering [#HTMLrelated Wiki markup inside a context], like inside <div> blocks or <span> or within <td> or <th> table cells
     8 - using an alternative markup syntax, like [wiki:WikiHtml raw HTML] and [wiki:WikiRestructuredText Restructured Text] or [http://www.textism.com/tools/textile/ textile]
     10== Using Processors
     12To use a processor on a block of text, first delimit the lines using a Wiki ''code block'':
     13{{{
     14{{{
     15The lines
     16that should be processed...
     17}}}
     18}}}
     19
     20Immediately after the `{{{` or on the line just below, add `#!` followed by the ''processor name'':
     21
     22{{{
     23{{{
     24#!processorname
     25The lines
     26that should be processed...
     27}}}
     28}}}
     29
     30This is the "shebang" notation, familiar to most UNIX users.
     31
     32Besides their content, some Wiki processors can also accept ''parameters'', which are then given as `key=value` pairs after the processor name and on the same line. If `value` has to contain space, as it's often the case for the style parameter, a quoted string can be used (`key="value with space"`).
     34As some processors are meant to process Wiki markup, it's quite possible to ''nest'' processor blocks.
     35You may want to indent the content of nested blocks for increased clarity, this extra indentation will be ignored when processing the content.
     36
     37== Examples
     38
     39||= Wiki Markup =||= Display =||
     40{{{#!td colspan=2 align=center style="border: none"
     41
     42                __Example 1__: Inserting raw HTML
     43}}}
     44|-----------------------------------------------------------------
     45{{{#!td style="border: none"
     46{{{
    1447{{{
    1548#!html
    16 <pre class="wiki">{{{
     49<h1 style="color: grey">This is raw HTML</h1>
     50}}}
     51}}}
     52}}}
     53{{{#!td valign=top style="border: none; padding-left: 2em"
     54{{{
    1755#!html
    18 &lt;h1 style="color: orange"&gt;This is raw HTML&lt;/h1&gt;
    19 }}}</pre>
    20 }}}
    21
    22 '''Results in:'''
    23 {{{
    24 #!html
    25 <h1 style="color: orange">This is raw HTML</h1>
    26 }}}
    27
    28 Note that since 0.11, such blocks of HTML have to be self-contained, i.e. you can't start an HTML element in one block and close it later in a second block. Use div or span processors for achieving similar effect (see WikiHtml).
    29
    30 ----
    31
    32 '''Example 2''' (''inserting Restructured Text in wiki text''):
    34 {{{
    35 #!html
    36 <pre class="wiki">{{{
    37 #!rst
    38 A header
    39 --------
    40 This is some **text** with a footnote [*]_.
    41
    42 .. [*] This is the footnote.
    43 }}}</pre>
    44 }}}
    45
    46 '''Results in:'''
    47 {{{
    48 #!rst
    49 A header
    50 --------
    51 This is some **text** with a footnote [*]_.
    52
    53 .. [*] This is the footnote.
    54 }}}
    55 ----
    56 '''Example 3''' (''inserting a block of C source code in wiki text''):
    57
    58 {{{
    59 #!html
    60 <pre class="wiki">{{{
    61 #!c
    62 int main(int argc, char *argv[])
    63 {
    64   printf("Hello World\n");
    65   return 0;
    66 }
    67 }}}</pre>
    68 }}}
    69
    70 '''Results in:'''
    71 {{{
    72 #!c
    73 int main(int argc, char *argv[])
    74 {
    75   printf("Hello World\n");
    76   return 0;
    77 }
    78 }}}
    79
    80 ----
    81
    82 == Available Processors ==
     56<h1 style="color: grey">This is raw HTML</h1>
     57}}}
     58}}}
     59|-----------------------------------------------------------------
     60{{{#!td colspan=2 align=center style="border: none"
     61
     62     __Example 2__: Highlighted Python code in a <div> block with custom style
     63}}}
     64|-----------------------------------------------------------------
     65{{{#!td style="border: none"
     66  {{{
     67  {{{#!div style="background: #ffd; border: 3px ridge"
     68
     69  This is an example of embedded "code" block:
     70
     71    {{{
     72    #!python
     73    def hello():
     74        return "world"
     75    }}}
     76
     77  }}}
     78  }}}
     79}}}
     80{{{#!td valign=top style="border: none; padding: 1em"
     81  {{{#!div style="background: #ffd; border: 3px ridge"
     82
     83  This is an example of embedded "code" block:
     84
     85    {{{
     86    #!python
     87    def hello():
     88        return "world"
     89    }}}
     90
     91  }}}
     92}}}
     93|-----------------------------------------------------------------
     94{{{#!td colspan=2 align=center style="border: none"
     95
     96     __Example 3__: Searching tickets from a wiki page, by keywords.
     97}}}
     98|-----------------------------------------------------------------
     99{{{#!td style="border: none"
     100  {{{
     101  {{{
     102  #!html
     103  <form action="/query" method="get"><div>
     104  <input type="text" name="keywords" value="~" size="30"/>
     105  <input type="submit" value="Search by Keywords"/>
     106  <!-- To control what fields show up use hidden fields
     107  <input type="hidden" name="col" value="id"/>
     108  <input type="hidden" name="col" value="summary"/>
     109  <input type="hidden" name="col" value="status"/>
     110  <input type="hidden" name="col" value="milestone"/>
     111  <input type="hidden" name="col" value="version"/>
     112  <input type="hidden" name="col" value="owner"/>
     113  <input type="hidden" name="col" value="priority"/>
     114  <input type="hidden" name="col" value="component"/>
     115  -->
     116  </div></form>
     117  }}}
     118  }}}
     119}}}
     120{{{#!td valign=top style="border: none; padding: 1em"
     121  {{{
     122  #!html
     123  <form action="/query" method="get"><div>
     124  <input type="text" name="keywords" value="~" size="30"/>
     125  <input type="submit" value="Search by Keywords"/>
     126  <!-- To control what fields show up use hidden fields
     127  <input type="hidden" name="col" value="id"/>
     128  <input type="hidden" name="col" value="summary"/>
     129  <input type="hidden" name="col" value="status"/>
     130  <input type="hidden" name="col" value="milestone"/>
     131  <input type="hidden" name="col" value="version"/>
     132  <input type="hidden" name="col" value="owner"/>
     133  <input type="hidden" name="col" value="priority"/>
     134  <input type="hidden" name="col" value="component"/>
     135  -->
     136  </div></form>
     137  }}}
     138}}}
     139
     140== Available Processors
     141
    83142The following processors are included in the Trac distribution:
    84  * '''html''' -- Insert custom HTML in a wiki page. See WikiHtml.
    85  * '''div''' -- Wrap an arbitrary Wiki content in a <div> element (''since 0.11''). See WikiHtml.
    86  * '''span''' -- Wrap an arbitrary Wiki content in a <span> element (''since 0.11''). See also WikiHtml.
    87  * '''rst''' -- Trac support for Restructured Text. See WikiRestructuredText.
    88  * '''textile''' -- Supported if [http://cheeseshop.python.org/pypi/textile Textile] is installed. See [http://www.textism.com/tools/textile/ a Textile reference].
    89  * '''comment''' -- Do not process the text in this section (i.e. contents exist only in the plain text - not in the rendered page).
    90  * '''diff''' -- Pretty print patches and diffs.
    91
    92 === Code Highlighting Support ===
    93 Trac includes processors to provide inline [wiki:TracSyntaxColoring syntax highlighting] for the following languages:
    94  * '''c''' -- C
    95  * '''cpp''' -- C++
    96  * '''csharp''' --- C# (''use #!text/x-csharp'')
    97  * '''python''' -- Python
    98  * '''perl''' -- Perl
    99  * '''ruby''' -- Ruby
    100  * '''php''' -- PHP
    101  * '''asp''' -- ASP
    102  * '''java''' -- Java
    103  * '''js''' -- Javascript
    104  * '''sql''' -- SQL
    105  * '''xml''' -- XML
    106  * '''sh''' -- Bourne/Bash shell
    107
    108 '''Note:''' ''Trac relies on external software packages for syntax coloring. See TracSyntaxColoring for more info.''
    109
    110 By using the MIME type as processor, it is possible to syntax-highlight the same languages that are supported when browsing source code. For example, you can write:
    111 {{{
     143
     144|| '''`#!default`''' || Present the text verbatim in a preformatted text block. This is the same as specifying ''no'' processor name (and no `#!`) ||
     145|| '''`#!comment`''' || Do not process the text in this section, i.e. contents exist only in the plain text - not in the rendered page. ||
     146|| '''`#!rtl`''' || Introduce a Right-To-Left block with appropriate CSS direction and styling ''(since 0.12.2)'' ||
     147|||| ||
     148||||= '''[=#HTMLrelated HTML related]''' =||
     149|| '''`#!html`''' || Insert custom HTML in a wiki page. ||
     150|| '''`#!htmlcomment`''' || Insert an HTML comment in a wiki page (''since 0.12''). ||
     151|| || Note that `#!html` blocks have to be ''self-contained'', i.e. you can't start an HTML element in one block and close it later in a second block. Use the following processors for achieving a similar effect.  ||
     152|| '''`#!div`''' || Wrap an arbitrary Wiki content inside a <div> element (''since 0.11''). ||
     153|| '''`#!span`''' || Wrap an arbitrary Wiki content inside a <span> element (''since 0.11''). ||
     154|| '''`#!td`''' || Wrap an arbitrary Wiki content inside a <td> element (''since 0.12'') ||
     155|| '''`#!th`''' || Wrap an arbitrary Wiki content inside a <th> element (''since 0.12'') ||
     156|| '''`#!tr`''' || Can optionally be used for wrapping `#!td` and `#!th` blocks, either for specifying row attributes or better visual grouping (''since 0.12'') ||
     157|| '''`#!table`''' || Can optionally be used for wrapping `#!tr`, `#!td` and `#!th` blocks, for specifying table attributes. One current limitation however is that tables cannot be nested. (''since 0.12'') ||
     158|| || See WikiHtml for example usage and more details about these processors. ||
     159|||| ||
     160||||= '''Other Markups''' =||
     161|| '''`#!rst`''' || Trac support for Restructured Text. See WikiRestructuredText. ||
     162|| '''`#!textile`''' || Supported if [http://cheeseshop.python.org/pypi/textile Textile] is installed. See [http://www.textism.com/tools/textile/ a Textile reference]. ||
     163|||| ||
     164||||= '''[=#CodeHighlightingSupport Code Highlighting Support]''' =||
     165|| '''`#!c`''' [[BR]] '''`#!cpp`''' (C++) [[BR]] '''`#!python`''' [[BR]] '''`#!perl`''' [[BR]] '''`#!ruby`''' [[BR]] '''`#!php`''' [[BR]] '''`#!asp`''' [[BR]] '''`#!java`''' [[BR]] '''`#!js`''' (Javascript) [[BR]] '''`#!sql`''' [[BR]] '''`#!xml`''' (XML or HTML) [[BR]] '''`#!sh`''' (!Bourne/Bash shell) [[BR]] '''etc.''' [[BR]] || Trac includes processors to provide inline syntax highlighting for source code in various languages. [[BR]] [[BR]] Trac relies on external software packages for syntax coloring, like [http://pygments.org Pygments]. [[BR]] [[BR]] See TracSyntaxColoring for information about which languages are supported and how to enable support for more languages. ||
     166|||| ||
     167
     168Using the MIME type as processor, it is possible to syntax-highlight the same languages that are supported when browsing source code.
     169
     170||||= '''MIME Type Processors''' =||
     171{{{#!tr
     172{{{#!td
     173Some examples:
     174 {{{
    112175{{{
    113176#!text/html
    114177<h1>text</h1>
    115178}}}
    116 }}}
    117
     179 }}}
     180}}}
     181{{{#!td
    118182The result will be syntax highlighted HTML code:
    119 {{{
     183 {{{
    120184#!text/html
    121185<h1>text</h1>
    122 }}}
    123
    124 The same is valid for all other mime types supported.
    125
    126
    127 For more processor macros developed and/or contributed by users, visit:
    128  * [trac:ProcessorBazaar]
    129  * [trac:MacroBazaar]
    130  * [th:WikiStart Trac Hacks] community site
    131
    132
    133 == Advanced Topics: Developing Processor Macros ==
    134 Developing processors is no different from Wiki macros. In fact they work the same way, only the usage syntax differs. See WikiMacros for more information.
    135
     186 }}}
     187
     188The same is valid for all other [TracSyntaxColoring#SyntaxColoringSupport mime types supported].
     189}}}
     190}}}
     191{{{#!td
     192 {{{
     193{{{
     194#!diff
     195--- Version 55
     196+++ Version 56
     197@@ -115,8 +115,9 @@
     198     name='TracHelloWorld', version='1.0',
     199     packages=find_packages(exclude=['*.tests*']),
     200-    entry_points = """
     201-        [trac.plugins]
     202-        helloworld = myplugs.helloworld
     203-    """,
     204+    entry_points = {
     205+        'trac.plugins': [
     206+            'helloworld = myplugs.helloworld',
     207+        ],
     208+    },
     209 )
     210}}}
     211 }}}
     212}}}
     213{{{#!td
     214'''`#!diff`''' has a particularly nice renderer:
     215 {{{
     216#!diff
     217--- Version 55
     218+++ Version 56
     219@@ -115,8 +115,9 @@
     220     name='TracHelloWorld', version='1.0',
     221     packages=find_packages(exclude=['*.tests*']),
     222-    entry_points = """
     223-        [trac.plugins]
     224-        helloworld = myplugs.helloworld
     225-    """,
     226+    entry_points = {
     227+        'trac.plugins': [
     228+            'helloworld = myplugs.helloworld',
     229+        ],
     230+    },
     231 )
     232 }}}
     233}}}
     234
     235For more processor macros developed and/or contributed by users, visit the [http://trac-hacks.org/wiki/WikiStart Trac Hacks] community site.
     236
     237Developing processors is no different from Wiki macros. In fact, they work the same way, only the usage syntax differs. See WikiMacros#DevelopingCustomMacros for more information.
    136238
    137239----
