6 | | * mapid: the id of a MapGroup object in the ApplicationDefinition file to be loaded at run-time |
7 | | * theme: full path to the map resource - a MapDefinition file in MapGuide case (e.g. Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition) or the full path to the MapServer mapfile (e.g. /ms4w/apps/gmap/htdocs/gmap75.map) |
8 | | * Session: the session identifier if required |
9 | | * extent: comma separated values for the initial extent of the map as minx,miny,maxx,maxy |
10 | | * ApplicationDefinition: path to an alternate ApplicationDefinition file instead of the default one |
| 6 | * mapid:: the id of a MapGroup object in the ApplicationDefinition file to be loaded at run-time |
| 7 | * theme:: full path to the map resource - a MapDefinition file in MapGuide case (e.g. Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition) or the full path to the MapServer mapfile (e.g. /ms4w/apps/gmap/htdocs/gmap75.map) |
| 8 | * Session: the session identifier if required |
| 9 | * extent: comma separated values for the initial extent of the map as minx,miny,maxx,maxy |
| 10 | * ApplicationDefinition: path to an alternate ApplicationDefinition file instead of the default one |
