Changes between Version 5 and Version 6 of TracUpgrade
09/05/24 06:51:41 (7 months ago)
  • TabularUnified TracUpgrade
    v5 v6
    8484
    8585=== 7. Steps specific to a given Trac version #VersionSpecificSteps
     86
     87==== Upgrading from Trac 1.4 to 1.5 #to1.5
     88
     89===== Python 2.7 no longer supported
     90
     91Upgrade Python to 3.5 or later.
    8692
    8793==== Upgrading from Trac 1.2 to 1.4 #to1.4
    235241Prior to 1.0, the owner field of new tickets always defaulted to `[ticket] default_owner` when the value was not empty. If the value was empty, the owner field defaulted to to the Component's owner. In 1.0 and later, the `default_owner` must be set to `< default >` to make new tickets default to the Component's owner. This change allows the `default_owner` to be set to an empty value if no default owner is desired.
    236242
     243===== Behavior of `* -> *` workflow transition
     244
     245The workflow transition `* -> *` must have the operation
     246`leave_status`. Due to a defect in Trac < 1.0.18
     247`leave_status` was not required, so it may be necessary
     248to add the operation when upgrading. The action will not
     249display for a `* -> *` transition if the action does
     250not have the `leave_status` operation.
     251
    237252==== Upgrading from older versions of Trac #OlderVersions
    238253
