Changes between Version 2 and Version 3 of TracNavigation
- Feb 1, 2017, 12:34:45 AM (7 years ago)
TracNavigation
v2 v3 1 = Trac Navigation =1 = Trac Navigation 2 2 3 The main and meta navigation entries can be customized in some basic ways. The `[mainnav]` and `[metanav]` configuration sections can be used to customize the text and link used for the navigation items, or even to disable them. The `mainnav` and `metanav` options in the `[trac]` configuration section can be used to change the order.3 The main and meta navigation entries can be customized in some basic ways. The `[mainnav]` and `[metanav]` configuration sections can be used to customize the navigation item text and link, change the ordering of the navigation items, or even disable them. 4 4 5 5 === `[mainnav]` #mainnav-bar … … 9 9 ** [=#Example Example] ** 10 10 11 In the following example, we rename the link to the Wiki start "Home", and make the "View Tickets" entry link to a specific report. The second example (below) also hides the "!Help/Guide" link. 12 13 Relevant excerpt from the TracIni: 14 {{{ 11 In the following example we rename the link to WikiStart //Home//, and make the //View Tickets// entry link to a specific report. 12 {{{#!ini 15 13 [mainnav] 16 14 wiki.label = Home … … 19 17 20 18 === `[metanav]` #metanav-bar 21 `[metanav]` corresponds to the '''meta navigation bar''', by default positioned above the main navigation bar and below the ''Search'' box. It contains the ''Log 19 `[metanav]` corresponds to the '''meta navigation bar''', by default positioned above the main navigation bar and below the ''Search'' box. It contains the ''Login'', ''Logout'', ''!Help/Guide'' etc. entries. This navigation bar is meant to access some global information about the Trac project and the current user. 22 20 23 There is one special entry in the `[metanav]` section: `logout.redirect` is the page the user sees after hitting the logout button. 21 There is one special entry in the `[metanav]` section: `logout.redirect` is the page the user sees after hitting the logout button. The ''!Help/Guide'' link is also hidden in the following example. 24 22 [[comment(see also #Trac3808)]] 25 23 26 24 ** Example ** 27 25 28 {{{ 26 {{{#!ini 29 27 [metanav] 30 28 help = disabled … … 33 31 34 32 35 === Notes36 Possible URL formats (for `.href` or `.redirect`):33 === URL Formats 34 Possible URL formats for `.href` or `.redirect`: 37 35 || '''config''' || '''redirect to''' || 38 36 || `wiki/Logout` || `/projects/env/wiki/Logout` || … … 41 39 42 40 43 === `[trac]`#nav-order44 The ` mainnav` and `metanav` options in the `[trac]` configuration section control the order in which the navigation items are displayed (left to right). This can be useful withplugins that add navigation items.41 === Ordering #nav-order 42 The `order` attribute specifies the order in which the navigation items are displayed. This can be particularly useful for plugins that add navigation items. 45 43 46 ** Example ** 44 Non-negative floating point values may be used for the `order` attribute. The navigation items will be arranged from left to right in increasing order. Navigation items without an `order` attribute are sorted alphabetically by name. 47 45 48 In the following example, we change the order to prioritise the ticket related items further left. 46 The default values are: 47 {{{#!ini 48 [mainnav] 49 browser.order = 4 50 newticket.order = 6 51 roadmap.order = 3 52 search.order = 7 53 tickets.order = 5 54 timeline.order = 2 55 wiki.order = 1 49 56 50 Relevant excerpt from the TracIni: 51 {{{ 52 [trac] 53 mainnav = wiki,tickets,newticket,timeline,roadmap,browser,search,admin 57 [metanav] 58 about.order = 5 59 help.order = 4 60 login.order = 1 61 logout.order = 2 62 prefs.order = 3 54 63 }}} 55 56 The default order and item names can be viewed in the [TracIni#trac-section trac section of TracIni].57 64 58 65 === Context Navigation #ctxtnav-bar 59 66 60 Note that it is still not possible to customize the '''contextual navigation bar''', i.e. the one usually placed below the main navigation bar. 61 67 Note that it is still not possible to customize the '''contextual navigation bar''', ie the one usually placed below the main navigation bar. 62 68 63 69 ----
