Changes between Version 2 and Version 3 of TracModWSGI
- Feb 1, 2017, 12:34:45 AM (7 years ago)
TracModWSGI
v2 v3 7 7 == The `trac.wsgi` script 8 8 9 Trac can be run on top of mod_wsgi with the help of an application script, which is justa Python file saved with a `.wsgi` extension.9 Trac can be run on top of mod_wsgi with the help of an application script, which is a Python file saved with a `.wsgi` extension. 10 10 11 11 A robust and generic version of this file can be created using the `trac-admin <env> deploy <dir>` command which automatically substitutes the required paths, see TracInstall#cgi-bin. The script should be sufficient for most installations and users not wanting more information can proceed to [#Mappingrequeststothescript configuring Apache]. … … 14 14 {{{#!python 15 15 def application(environ, start_request): 16 # Add this to config when you have multiple projects 16 # Add this to config when you have multiple projects 17 17 environ.setdefault('trac.env_parent_dir', '/usr/share/trac/projects') 18 18 .. … … 20 20 21 21 === A very basic script 22 22 23 In its simplest form, the script could be: 23 24 … … 80 81 <Directory /usr/local/trac/mysite/apache> 81 82 WSGIApplicationGroup %{GLOBAL} 82 Order deny,allow 83 Allow from all 83 # For Apache 2.2 84 <IfModule !mod_authz_core.c> 85 Order deny,allow 86 Allow from all 87 </IfModule> 88 # For Apache 2.4 89 <IfModule mod_authz_core.c> 90 Require all granted 91 </IfModule> 84 92 </Directory> 85 93 }}} … … 94 102 <Directory /usr/share/trac/cgi-bin> 95 103 WSGIApplicationGroup %{GLOBAL} 96 Order deny,allow 97 Allow from all 104 # For Apache 2.2 105 <IfModule !mod_authz_core.c> 106 Order deny,allow 107 Allow from all 108 </IfModule> 109 # For Apache 2.4 110 <IfModule mod_authz_core.c> 111 Require all granted 112 </IfModule> 98 113 </Directory> 99 114 }}} … … 101 116 In order to let Apache run the script, access to the directory in which the script resides is opened up to all of Apache. Additionally, the `WSGIApplicationGroup` directive ensures that Trac is always run in the first Python interpreter created by mod_wsgi. This is necessary because the Subversion Python bindings, which are used by Trac, don't always work in other sub-interpreters and may cause requests to hang or cause Apache to crash. After adding this configuration, restart Apache, and then it should work. 102 117 103 To test the setup of Apache, mod_wsgi and Python itself (ie .without involving Trac and dependencies), this simple wsgi application can be used to make sure that requests gets served (use as only content in your `.wsgi` script):118 To test the setup of Apache, mod_wsgi and Python itself (ie without involving Trac and dependencies), this simple wsgi application can be used to make sure that requests gets served (use as only content in your `.wsgi` script): 104 119 105 120 {{{#!python … … 109 124 }}} 110 125 111 For more information about using the mod_wsgi specific directives, see the [http ://code.google.com/p/modwsgi/wiki/ mod_wsgi's wiki] and more specifically the [http://code.google.com/p/modwsgi/wiki/IntegrationWithTracIntegrationWithTrac] page.126 For more information about using the mod_wsgi specific directives, see the [https://code.google.com/archive/p/modwsgi/wikis mod_wsgi's wiki] and more specifically the [https://code.google.com/archive/p/modwsgi/wikis/IntegrationWithTrac.wiki IntegrationWithTrac] page. 112 127 113 128 == Configuring Authentication 114 129 115 The following sections describe different methods for setting up authentication. See also [http://httpd.apache.org/docs/2. 2/howto/auth.html Authentication, Authorization and Access Control] in the Apache guide.130 The following sections describe different methods for setting up authentication. See also [http://httpd.apache.org/docs/2.4/howto/auth.html Authentication, Authorization and Access Control] in the Apache guide. 116 131 117 132 === Using Basic Authentication … … 133 148 }}} 134 149 135 ''See the man page for `htpasswd` for full documentation.'' 150 See the man page for `htpasswd` for full documentation. 136 151 137 152 After you've created the users, you can set their permissions using TracPermissions. … … 156 171 </LocationMatch> 157 172 }}} 158 Note that neither a file nor a directory named 'login' needs to exist.[[BR]] 159 See also the [http://httpd.apache.org/docs/2.2/mod/mod_auth_basic.html mod_auth_basic] documentation.173 174 Note that neither a file nor a directory named 'login' needs to exist. See also the [https://httpd.apache.org/docs/2.4/mod/mod_auth_basic.html mod_auth_basic] documentation. 160 175 161 176 === Using Digest Authentication 162 177 163 For better security, it is recommended that you either enable SSL or at least use the “digest” authentication scheme instead of “Basic”.178 For better security, it is recommended that you either enable SSL or at least use the "digest" authentication scheme instead of "Basic". 164 179 165 180 You have to create your `.htpasswd` file with the `htdigest` command instead of `htpasswd`, as follows: … … 182 197 For multiple environments, you can use the same `LocationMatch` as described with the previous method. 183 198 184 '''Note : `Location` cannot be used inside .htaccess files, but must instead live within the main httpd.conf file. If you are on a shared server, you therefore will not be able to provide this level of granularity. '''199 '''Note''': `Location` cannot be used inside .htaccess files, but must instead live within the main httpd.conf file. If you are on a shared server, you therefore will not be able to provide this level of granularity. 185 200 186 201 Don't forget to activate the mod_auth_digest. For example, on a Debian 4.0r1 (etch) system: … … 189 204 }}} 190 205 191 See also the [http ://httpd.apache.org/docs/2.2/mod/mod_auth_digest.html mod_auth_digest] documentation.206 See also the [https://httpd.apache.org/docs/2.4/mod/mod_auth_basic.html mod_auth_digest] documentation. 192 207 193 208 === Using LDAP Authentication 194 209 195 Configuration for [http ://httpd.apache.org/docs/2.2/mod/mod_ldap.html mod_ldap] authentication in Apache is more involved (httpd 2.2.xand OpenLDAP: slapd 2.3.19).210 Configuration for [https://httpd.apache.org/docs/2.4/mod/mod_ldap.html mod_ldap] authentication in Apache is more involved (httpd 2.2+ and OpenLDAP: slapd 2.3.19). 196 211 197 212 1. You need to load the following modules in Apache httpd.conf: … … 219 234 AuthLDAPURL "ldap://directory.example.com:3268/DC=example,DC=com?sAMAccountName?sub?(objectClass=user)" 220 235 }}} 221 You will also need to provide an account for Apache to use when checking credentials. As this password will be listed in plain text in the config, you need to use an account specifically for this task:236 You will also need to provide an account for Apache to use when checking credentials. As this password will be listed in plain text in the configuration, you need to use an account specifically for this task: 222 237 {{{#!apache 223 238 AuthLDAPBindDN ldap-auth-user@example.com … … 251 266 252 267 See also: 253 - [http ://httpd.apache.org/docs/2.2/mod/mod_authnz_ldap.html mod_authnz_ldap], documentation for mod_authnz_ldap.254 - [http ://httpd.apache.org/docs/2.2/mod/mod_ldap.html mod_ldap], documentation for mod_ldap, which provides connection pooling and a shared cache.255 - [http ://trac-hacks.org/wiki/LdapPlugin TracHacks:LdapPlugin] for storing TracPermissions in LDAP.268 - [https://httpd.apache.org/docs/2.4/mod/mod_authnz_ldap.html mod_authnz_ldap], documentation for mod_authnz_ldap. 269 - [https://httpd.apache.org/docs/2.4/mod/mod_ldap.html mod_ldap], documentation for mod_ldap, which provides connection pooling and a shared cache. 270 - [https://trac-hacks.org/wiki/LdapPlugin TracHacks:LdapPlugin] for storing TracPermissions in LDAP. 256 271 257 272 === Using SSPI Authentication … … 278 293 See also [trac:TracOnWindows/Advanced]. 279 294 280 === Using Apache authentication with the Account Manager plugin's Login form === 281 282 To begin with, see the basic instructions for using the Account Manager plugin's [http://trac-hacks.org/wiki/AccountManagerPlugin/Modules#LoginModule Login module] and its [http://trac-hacks.org/wiki/AccountManagerPlugin/AuthStores#HttpAuthStore HttpAuthStore authentication module]. 283 284 '''Note:''' If is difficult to get !HttpAuthStore to work with WSGI when using any Account Manager version prior to acct_mgr-0.4. Upgrading is recommended. 285 286 Here is an example (from the !HttpAuthStore link) using acct_mgr-0.4 for hosting a single project: 287 {{{#!ini 288 [components] 289 ; be sure to enable the component 290 acct_mgr.http.HttpAuthStore = enabled 291 292 [account-manager] 293 ; configure the plugin to use a page that is secured with http authentication 294 authentication_url = /authFile 295 password_store = HttpAuthStore 296 }}} 297 This will generally be matched with an Apache config like: 298 {{{#!apache 299 <Location /authFile> 300 …HTTP authentication configuration… 301 Require valid-user 302 </Location> 303 }}} 304 Note that '''authFile''' need not exist (unless you are using Account Manager older than 0.4). See the !HttpAuthStore link above for examples where multiple Trac projects are hosted on a server. 295 === Using CA !SiteMinder Authentication 296 297 Setup CA !SiteMinder to protect your Trac login URL, for example `/trac/login`. Also, make sure the policy is set to include the HTTP_REMOTE_USER variable. If your site allows it, you can set this in `LocalConfig.conf`: 298 {{{#!apache 299 RemoteUserVar="WHATEVER_IT_SHOULD_BE" 300 SetRemoteUser="YES" 301 }}} 302 303 The specific variable is site-dependent. Ask your site administrator. If your site does not allow the use of `LocalConfig.conf` for security reasons, have your site administrator set the policy on the server to set REMOTE_USER. 304 305 Also add a !LogOffUri parameter to the agent configuration, for example `/trac/logout`. 306 307 Then modify the trac.wsgi script generated using `trac-admin <env> deploy <dir>` to add the following lines, which extract the `HTTP_REMOTE_USER` variable and set it to `REMOTE_USER`: 308 309 {{{#!python 310 def application(environ, start_request): 311 # Set authenticated username on CA SiteMinder to REMOTE_USER variable 312 # strip() is used to remove any spaces on the end of the string 313 if 'HTTP_SM_USER' in environ: 314 environ['REMOTE_USER'] = environ['HTTP_REMOTE_USER'].strip() 315 ... 316 }}} 317 318 You do not need any Apache "Location" directives. 305 319 306 320 === Example: Apache/mod_wsgi with Basic Authentication, Trac being at the root of a virtual host … … 310 324 - uses Apache basic authentication for Trac authentication. 311 325 312 If you want your Trac to be served from e .g. !http://trac.my-proj.my-site.org, then from the folder e.g.`/home/trac-for-my-proj`, if you used the command `trac-admin the-env initenv` to create a folder `the-env`, and you used `trac-admin the-env deploy the-deploy` to create a folder `the-deploy`, then first:326 If you want your Trac to be served from eg !http://trac.my-proj.my-site.org, then from the folder eg `/home/trac-for-my-proj`, if you used the command `trac-admin the-env initenv` to create a folder `the-env`, and you used `trac-admin the-env deploy the-deploy` to create a folder `the-deploy`, then first: 313 327 314 328 Create the htpasswd file: … … 319 333 htpasswd htpasswd seconduser 320 334 }}} 335 321 336 Keep the file above your document root for security reasons. 322 337 323 Create this file e.g. (ubuntu) `/etc/apache2/sites-enabled/trac.my-proj.my-site.org.conf`with the following content:338 Create this file for example `/etc/apache2/sites-enabled/trac.my-proj.my-site.org.conf` on Ubuntu with the following content: 324 339 325 340 {{{#!apache … … 344 359 }}} 345 360 346 Note: for subdomains to work you would probably also need to alter `/etc/hosts` and add A-Records to your host's DNS.361 For subdomains to work you would probably also need to alter `/etc/hosts` and add A-Records to your host's DNS. 347 362 348 363 == Troubleshooting … … 350 365 === Use a recent version 351 366 352 Please use either version 1.6, 2.4 or later of `mod_wsgi`. Versions prior to 2.4 in the 2.X branch have problems with some Apache configurations that use WSGI file wrapper extension. This extension is used in Trac to serve up attachments and static media files such as style sheets. If you are affected by this problem, attachments will appear to be empty and formatting of HTML pages will appear not to work due to style sheet files not loading properly. Another frequent symptom is that binary attachment downloads are truncated. See mod_wsgi tickets [http ://code.google.com/p/modwsgi/issues/detail?id=100 #100] and [http://code.google.com/p/modwsgi/issues/detail?id=132 #132].353 354 '' Note: using mod_wsgi 2.5 and Python 2.6.1 gave an Internal Server Error on my system (Apache 2.2.11 and Trac 0.11.2.1). Upgrading to Python 2.6.2 (as suggested [http://www.mail-archive.com/modwsgi@googlegroups.com/msg01917.html here]) solved this for me[[BR]]-- Graham Shanks''355 356 If you plan to use `mod_wsgi` in embedded mode on Windows or with the MPM worker on Linux, then you will need version 0.3.4 or greater. See [trac:#10675] for details.367 Please use either version 1.6, 2.4 or later of `mod_wsgi`. Versions prior to 2.4 in the 2.X branch have problems with some Apache configurations that use WSGI file wrapper extension. This extension is used in Trac to serve up attachments and static media files such as style sheets. If you are affected by this problem, attachments will appear to be empty and formatting of HTML pages will appear not to work due to style sheet files not loading properly. Another frequent symptom is that binary attachment downloads are truncated. See mod_wsgi tickets [https://code.google.com/archive/p/modwsgi/issues/100 #100] and [https://code.google.com/archive/p/modwsgi/issues/132 #132]. 368 369 '''Note''': using mod_wsgi 2.5 and Python 2.6.1 gave an Internal Server Error on my system (Apache 2.2.11 and Trac 0.11.2.1). Upgrading to Python 2.6.2 (as suggested [http://www.mail-archive.com/modwsgi@googlegroups.com/msg01917.html here]) solved this for me[[BR]]-- Graham Shanks 370 371 If you plan to use `mod_wsgi` in embedded mode on Windows or with the MPM worker on Linux, then you will need version 3.4 or greater. See [trac:#10675] for details. 357 372 358 373 === Getting Trac to work nicely with SSPI and 'Require Group' 359 374 360 If you have set Trac up on Apache, Win32 and configured SSPI, but added a 'Require group' option to your apache configuration, then the SSPIOmitDomain option is probably not working. If it is not working, your usernames in Trac probably look like 'DOMAIN\user' rather than 'user'.361 362 This WSGI script 'fixes'that:375 If you have set Trac up on Apache, Win32 and configured SSPI, but added a 'Require group' option to your Apache configuration, then the SSPIOmitDomain option is probably not working. If it is not working, your usernames in Trac probably look like 'DOMAIN\user' rather than 'user'. 376 377 This WSGI script fixes that: 363 378 {{{#!python 364 379 import os … … 396 411 Now Trac drops the connection after serving a page and the connection count on the database will be kept low. 397 412 398 //This is not a recommended approach though. See also the notes at the bottom of the [http://code.google.com/p/modwsgi/wiki/IntegrationWithTrac mod_wsgi's IntegrationWithTrac] wiki page.// 413 //This is not a recommended approach though. See also the notes at the bottom of the [https://code.google.com/archive/p/modwsgi/wikis/IntegrationWithTrac.wiki mod_wsgi's IntegrationWithTrac] wiki page.// 414 415 === Missing Headers and Footers 416 417 If python optimizations are enabled, then headers and footers will not be rendered. An error will be raised in Trac 1.0.11 and later when optimizations are enabled. 418 419 In your WSGI configuration file, the `WSGIPythonOptimize` setting must be set to `0` (`1` or `2` will not work): 420 421 {{{#!apache 422 WSGIPythonOptimize 0 423 }}} 424 425 On Ubuntu, the WSGI mod configuration is at `/etc/apache2/mods-enabled/wsgi.conf`. 426 427 The same issue is seen with `PythonOptimize On` in [TracModPython#Pagelayoutissues ModPython]. 399 428 400 429 === Other resources 401 430 402 For more troubleshooting tips, see also the [TracModPython#Troubleshooting mod_python troubleshooting] section, as most Apache-related issues are quite similar, plus discussion of potential [http ://code.google.com/p/modwsgi/wiki/ApplicationIssues application issues] when using mod_wsgi. The wsgi page also has a [http://code.google.com/p/modwsgi/wiki/IntegrationWithTracIntegration With Trac] document.431 For more troubleshooting tips, see also the [TracModPython#Troubleshooting mod_python troubleshooting] section, as most Apache-related issues are quite similar, plus discussion of potential [https://code.google.com/archive/p/modwsgi/wikis/ApplicationIssues.wiki application issues] when using mod_wsgi. The wsgi page also has a [https://code.google.com/archive/p/modwsgi/wikis/IntegrationWithTrac.wiki Integration With Trac] document. 403 432 404 433 ----
