Changes between Version 1 and Version 2 of TracImport
Jun 10, 2010, 1:36:20 PM (14 years ago)
  • TracImport
    v1 v2
    33== Bugzilla ==
    44
    5 Ticket data can be imported from Bugzilla using the [http://projects.edgewall.com/trac/browser/trunk/contrib/bugzilla2trac.py bugzilla2trac.py] script, available in the contrib/ directory of the Trac distribution.
     5Ticket data can be imported from Bugzilla using the [http://trac.edgewall.org/browser/trunk/contrib/bugzilla2trac.py bugzilla2trac.py] script, available in the contrib/ directory of the Trac distribution.
    66
    77{{{
    4242== Sourceforge ==
    4343
    44 Ticket data can be imported from Sourceforge using the [http://projects.edgewall.com/trac/browser/trunk/contrib/sourceforge2trac.py sourceforge2trac.py] script, available in the contrib/ directory of the Trac distribution.
     44Ticket data can be imported from Sourceforge using the [http://trac.edgewall.org/browser/trunk/contrib/sourceforge2trac.py sourceforge2trac.py] script, available in the contrib/ directory of the Trac distribution.
    4545
    4646== Mantis ==
     47
     48NB! The mantis2trac script now lives at http://trac-hacks.org/wiki/MantisImportScript . You can always get the latest version from http://trac-hacks.org/changeset/latest/mantisimportscript?old_path=/&filename=mantisimportscript&format=zip
    4749
    4850Mantis bugs can be imported using the attached script.
    5254  * bug comments
    5355  * bug activity (field changes)
     56  * attachments (as long as the files live in the mantis db, not on the filesystem)
    5457
    55 Attachments are NOT imported.  If you use the script, please read the NOTES section (at the top of the file) and make sure you adjust the config parameters for your environment.
     58If you use the script, please read the NOTES section (at the top of the file) and make sure you adjust the config parameters for your environment.
    5659
    5760mantis2trac.py has the same parameters as the bugzilla2trac.py script:
    7982=== Using a comma delimited file - CSV ===
    8083See [http://trac.edgewall.org/attachment/wiki/TracSynchronize/csv2trac.2.py] for details.  This approach is particularly useful if one needs to enter a large number of tickets by hand. (note that the ticket type type field, (task etc...) is also needed for this script to work with more recent Trac releases)
     84
