Changes between Version 1 and Version 2 of ApplicationDefinition
- Mar 10, 2008, 11:30:09 AM (16 years ago)
v1 v2 23 23 The main tag contains the following sub-tags: 24 24 25 ''' [wiki:ApplicationDefinition/Title Title]''':26 Occurs once. Used to set the title of the web page when the application is run.25 '''Title''': 26 Occurs once. This tag contains a string value used to set the title of the web page when the application is run. 27 27 28 28 '''[wiki:ApplicationDefinition/MapGroup MapGroup]''': 29 Occurs at least once. Definesmaps to be used in the application.29 Occurs at least once. This tag contains sub tags that define maps to be used in the application. 30 30 31 31 '''[wiki:ApplicationDefinition/WidgetSet WidgetSet]''': 32 Occurs at least once. Defines a Map and associated widgets to be created.32 Occurs at least once. This tag represents a visible map in the user interface, and describes widgets to be associated with the map. 33 33 34 34 '''[wiki:ApplicationDefinition/Extension Extension]''':
