Changes between Version 7 and Version 8 of ApplicationDefinition/MapSet/MapGroup
- Aug 7, 2011, 10:40:35 PM (13 years ago)
v7 v8 13 13 <Extension> 14 14 <ResourceId>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</ResourceId> 15 <ImageFormat>PNG8</ImageFormat> 15 16 </Extension> 16 17 </Map> … … 147 148 If you have defined a !MapGuide map type, you must provide a {{{<ResourceId>}}} sub-tag that defines the repository path to the MapDefinition to be used to render this map. 148 149 150 You can specify the image format using the {{{<ImageFormat>}}} tag using any of the supported mapguide image formats, i.e PNG,PNG8,GIF,JPG 151 149 152 === !MapServer Extension === 150 153
