Changes between Version 4 and Version 5 of WikiProcessors
05/08/22 15:10:28 (3 years ago)
  • TabularUnified WikiProcessors
    v4 v5
    11= Wiki Processors
    3 Processors are WikiMacros designed to provide alternative markup formats for the [TracWiki Wiki engine]. Processors can be thought of as ''macro functions to process user-edited text''.
     3Processors are WikiMacros that provide alternative markup formats for the [TracWiki Wiki engine]. Processors can be thought of as ''macro functions to process user-edited text''.
    44
    55Wiki processors can be used in any Wiki text throughout Trac, such as:
    66 - [#CodeHighlightingSupport syntax highlighting] or for rendering text verbatim
    7  - rendering [#HTMLrelated Wiki markup inside a context], like inside <div> blocks or <span> or within <td> or <th> table cells
    8  - using an alternative markup syntax, like [WikiHtml raw HTML] and [WikiRestructuredText Restructured Text] or [http://www.textism.com/tools/textile/ textile]
     7 - rendering [#HTMLrelated Wiki markup inside a context] such as <div> or <span> blocks or within <td> or <th> table cells
     8 - using an alternative markup syntax, like [WikiHtml raw HTML] and [WikiRestructuredText Restructured Text] or [https://www.booked.net/textism.html textile]
    1010== Using Processors
    4040{{{#!td colspan=2 align=center style="border: none"
    4141
    42                 __Example 1__: Inserting raw HTML
     42                '''Example 1''': Inserting raw HTML
    4343}}}
    4444|-----------------------------------------------------------------
    6060{{{#!td colspan=2 align=center style="border: none"
    6161
    62      __Example 2__: Highlighted Python code in a <div> block with custom style
     62     '''Example 2''': Highlighted Python code in a <div> block with custom style
    6363}}}
    6464|-----------------------------------------------------------------
    9494{{{#!td colspan=2 align=center style="border: none"
    9595
    96      __Example 3__: Searching tickets from a wiki page, by keywords.
     96     '''Example 3''': Searching tickets from a wiki page, by keywords.
    9797}}}
    9898|-----------------------------------------------------------------
    155155|| '''`#!th`''' || Wrap wiki content inside a <th> element. (''since 0.12'') ||
    156156|| '''`#!tr`''' || Can optionally be used for wrapping `#!td` and `#!th` blocks, either for specifying row attributes or better visual grouping. (''since 0.12'') ||
    157 || '''`#!table`''' || Can optionally be used for wrapping `#!tr`, `#!td` and `#!th` blocks, for specifying table attributes. One current limitation however is that tables cannot be nested. (''since 0.12'') ||
     157|| '''`#!table`''' || Can optionally be used for wrapping `#!tr`, `#!td` and `#!th` blocks, for specifying table attributes. One current limitation however is that tables cannot be nested. (''since 0.12'') ||
    158158|| || See WikiHtml for example usage and more details about these processors. ||
    159159|||| ||
    160160||||= '''Other Markups''' =||
    161161|| '''`#!rst`''' || Trac support for Restructured Text. See WikiRestructuredText. ||
    162 || '''`#!textile`''' || Supported if [http://cheeseshop.python.org/pypi/textile Textile] is installed. See [http://www.textism.com/tools/textile/ a Textile reference]. ||
     162|| '''`#!textile`''' || Supported if [https://pypi.org/project/textile Textile] is installed. See [https://www.booked.net/textism.html a Textile reference]. ||
    163163|||| ||
    164164||||= '''[=#CodeHighlightingSupport Code Highlighting Support]''' =||
    165 || '''`#!c`''' [[BR]] '''`#!cpp`''' (C++) [[BR]] '''`#!python`''' [[BR]] '''`#!perl`''' [[BR]] '''`#!ruby`''' [[BR]] '''`#!php`''' [[BR]] '''`#!asp`''' [[BR]] '''`#!java`''' [[BR]] '''`#!js`''' (Javascript) [[BR]] '''`#!sql`''' [[BR]] '''`#!xml`''' (XML or HTML) [[BR]] '''`#!sh`''' (!Bourne/Bash shell) [[BR]] '''etc.''' [[BR]] || Trac includes processors to provide inline syntax highlighting for source code in various languages. [[BR]] [[BR]] Trac relies on [http://pygments.org Pygments] for syntax coloring. [[BR]] [[BR]] See TracSyntaxColoring for information about which languages are supported and how to enable support for more languages. ||
     165|| '''`#!c`''' [[BR]] '''`#!cpp`''' (C++) [[BR]] '''`#!python`''' [[BR]] '''`#!perl`''' [[BR]] '''`#!ruby`''' [[BR]] '''`#!php`''' [[BR]] '''`#!asp`''' [[BR]] '''`#!java`''' [[BR]] '''`#!js`''' (Javascript) [[BR]] '''`#!sql`''' [[BR]] '''`#!xml`''' (XML or HTML) [[BR]] '''`#!sh`''' (!Bourne/Bash shell) [[BR]] || Trac includes processors to provide inline syntax highlighting for source code in various languages. [[BR]] [[BR]] Trac relies on [http://pygments.org Pygments] for syntax coloring. [[BR]] [[BR]] See TracSyntaxColoring for information about which languages are supported and how to enable support for more languages. ||
    166166|||| ||
    167167
    271271For more processor macros developed and/or contributed by users, visit the [https://trac-hacks.org Trac Hacks] community site.
    272272
    273 Developing processors is no different from Wiki macros. In fact, they work the same way, only the usage syntax differs. See WikiMacros#DevelopingCustomMacros for more information.
     273Processors are implemented using the same interfaces as Wiki macros, only the usage syntax differs. To develop a processor, see WikiMacros#DevelopingCustomMacros.
    274274
    275275----
