Changes between Version 5 and Version 6 of TracLogging
- 09/05/24 06:48:15 (2 months ago)
TracLogging
v5 v6 18 18 == Log Levels 19 19 20 The verbosity level of logged messages can be set using the [TracIni#logging-log_level-option "[logging] log_level"] option. The log level defines the minimum level of urgency required for a message to be logged , and those levels are:20 The verbosity level of logged messages can be set using the [TracIni#logging-log_level-option "[logging] log_level"] option. The log level defines the minimum level of urgency required for a message to be logged: 21 21 22 22 '''CRITICAL''':: Log only the most critical (typically fatal) errors. … … 26 26 '''DEBUG''':: Trace messages, profiling, etc. 27 27 28 Additionally, you can 28 Additionally, you can enable logging of SQL statements at debug level. This is turned off by default, as it's very verbose. Set [TracIni#trac-debug_sql-option "[trac] debug_sql = yes"] to activate. 29 29 30 30 == Log Format … … 42 42 }}} 43 43 44 In a multi-project environment where all logs are sent to the same place (e.g. `syslog`), it makes sense to add the project name. In this example we use `basename` sincethat can generally be used to identify a project:44 In a multi-project environment where all logs are sent to the same place (e.g. `syslog`), it makes sense to add the project name. In this example we use `basename` as that can generally be used to identify a project: 45 45 {{{#!ini 46 46 log_format = Trac[$(basename)s:$(module)s] $(levelname)s: $(message)s
