Changes between Version 4 and Version 5 of TracCgi
09/05/24 06:48:15 (2 months ago)
  • TracCgi
    v4 v5
    77}}}
    88
    9 CGI script is the entrypoint that web-server calls when a web-request to an application is made. The `trac.cgi` script can be created using the `trac-admin <env> deploy <dir>` command which automatically substitutes the required paths, see TracInstall#cgi-bin. Make sure the script is executable by your web server.
     9CGI script is the entry point that the web-server calls when a web-request to an application is made. The `trac.cgi` script can be created using the `trac-admin <env> deploy <dir>` command which automatically substitutes the required paths, see TracInstall#cgi-bin. Make sure the script is executable by your web server.
    1010
    1111== Apache web-server configuration
    1414
    1515 1. Use a `ScriptAlias` directive that maps a URL to the `trac.cgi` script (recommended)
    16  1. Copy the `trac.cgi` file into the directory for CGI executables used by your web server (commonly named `cgi-bin`). You can also create a symbolic link, but in that case make sure that the `FollowSymLinks` option is enabled for the `cgi-bin` directory.
     16 1. Copy the `trac.cgi` file into the directory for CGI executables used by your web server, commonly named `cgi-bin`. You can also create a symbolic link, but in that case make sure that the `FollowSymLinks` option is enabled for the `cgi-bin` directory.
    1717
    18 To make Trac available at `http://yourhost.example.org/trac` add `ScriptAlias` directive to Apache configuration file, changing `trac.cgi` path to match your installation:
     18To make Trac available at `http://yourhost.example.org/trac` add `ScriptAlias` directive to your Apache configuration file, changing `trac.cgi` path to match your installation:
    1919{{{#!apache
    2020ScriptAlias /trac /path/to/www/trac/cgi-bin/trac.cgi
    2121}}}
    2222
    23  ''Note that this directive requires that the `mod_alias` module is enabled.''
     23'''Note''': this directive requires that the `mod_alias` module is enabled.
    2424
    2525If you're using Trac with a single project you need to set its location using the `TRAC_ENV` environment variable:
    3737}}}
    3838
    39   ''Note that the `SetEnv` directive requires that the `mod_env` module is enabled.''
     39'''Note''': the `SetEnv` directive requires that the `mod_env` module is enabled.
    4040
    4141An alternative to `SetEnv` is editing `TRAC_ENV` or `TRAC_ENV_PARENT_DIR` in `trac.cgi`:
    5151If you are using the [https://httpd.apache.org/docs/suexec.html Apache suEXEC] feature please see [trac:ApacheSuexec].
    5252
    53 On some systems, you ''may'' need to edit the shebang line in the `trac.cgi` file to point to your real Python installation path. On a Windows system you may need to configure Windows to know how to execute a `.cgi` file (Explorer -> Tools -> Folder Options -> File Types -> CGI).
     53On some systems, you ''may'' need to edit the shebang line in the `trac.cgi` file to point to your real Python installation path. On Windows, configure the execution of a `.cgi` file: Explorer -> Tools -> Folder Options -> File Types -> CGI.
    5454
    5555=== Python Egg Cache
    7070}}}
    7171
    72
    73
    7472=== Using WSGI
    7573
