Changes between Initial Version and Version 1 of FdoOGCProxyServerSupport
Oct 18, 2007, 1:37:42 PM (15 years ago)
gregboone
  • FdoOGCProxyServerSupport
     1
     2== FDO OGC Integrated Proxy Server Support ==
     5=== Overview ===
     7As a result of feedback from customers using the FDO API and the WMS/WFS Providers, a number of requests have arisen to allow access to Web services, such as WMS and WFS, through a proxy server. A proxy server acts as an intermediary between an internal network (Intranet) and the Internet, retrieving files from a remote web services.
     8
     9Proxy Server support can be enabled in the OSGeo Web Service providers by enhancing and expanding the connection parameter list that each provider supports. The following sections outline the additional connection properties that will be introduced in order to allow proxy server access.
     10
     11=== Description ===
     12
     13The following connection parameters will be added to the WMS and WFS connection string definitions. These properties will also appear in the Connection Property dictionary for each of these providers.
     14
     15==== !ConnectionType ====
     16
     17The !ConnectionType property defines the type of connection that will be used when connecting to the Web service.
     18
     19||'''Property'''||'''Value'''||
     20||Name||!ProxyConnectionType||
     21||!LocalizedName||!ProxyConnectionType (English)||
     22||!DefaultValue||!UseSystemSettings||
     23||!IsRequired||No||
     24||!IsProtected||No||
     25||!IsEnumerable||Yes||
     26||Enumerations||!UseDirectConnection||
     27||||!UseSystemSettings||
     28||||!UseProxyServer||
     29||!IsFileName||No||
     30||!IsFilePath||No||
     31||!IsDatastoreName||No||
     32
     33''!UseSystemSettings'': Choose this option to use the LAN settings as defined by the operating system[[br]]
     34''!UseDirectConnection'': Choose this option to override the system LAN settings and connect directly to the Internet. (Not through a proxy server)[[br]]
     35''!UseProxyServer'': Choose this option to use the user-specified proxy server to connect to the Internet[[br]]
     36
     37On Windows you can review the current LAN settings by clicking Control Panel > Internet Options > Connections Tab > LAN Settings. This is the default connection setting.
     38
     39==== !ProxyServerName ====
     40
     41The !ProxyServerName property specifies the name of a user specified proxy server that will be used to make the connection to the external web service.
     42
     43||'''Property'''||'''Value'''||
     44||Name||!ProxyServerName||
     45||!LocalizedName||!ProxyServerName (English)||
     46||!DefaultValue||||
     47||!IsRequired||No||
     48||!IsProtected||No||
     49||!IsEnumerable||No||
     50||!IsFileName||No||
     51||!IsFilePath||No||
     52||!IsDatastoreName||No||
     53
     54==== !ProxyServerPort ====
     56The !ProxyServerPort property specifies the port of the user-specified proxy server that will be used to connect to the Internet. If set, it must be used in conjunction with the !ProxyServerName parameter.
     57
     58||'''Property'''||'''Value'''||
     59||Name||!ProxyServer||
     60||!LocalizedName||!ProxyServer (English)||
     61||!DefaultValue||||
     62||!IsRequired||No||
     63||!IsProtected||No||
     64||!IsEnumerable||No||
     65||!IsFileName||No||
     66||!IsFilePath||No||
     67||!IsDatastoreName||No||
     68
     69==== !ProxyServerUsername ====
     70
     71The !ProxyServerUsername property specifies the username to be used when connecting to a user-specified proxy server.  If set, it must be used in conjunction with the !ProxyServerName and !ProxyServerPassword parameters.
     72
     73||'''Property'''||'''Value'''||
     74||Name||!ProxyServerUsername||
     75||!LocalizedName||!ProxyServerUsername (English)||
     76||!DefaultValue||||
     77||!IsRequired||No||
     78||!IsProtected||No||
     79||!IsEnumerable||No||
     80||!IsFileName||No||
     81||!IsFilePath||No||
     82||!IsDatastoreName||No||
     83
     84==== !ProxyServerPassword ====
     85
     86The !ProxyServerPassword property specifies the password to be used when connecting to a user-specified proxy server.  If set, it must be used in conjunction with the !ProxyServerName and !ProxyServerPassword parameters.
     87
     88||'''Property'''||'''Value'''||
     89||Name||!ProxyServerPassword||
     90||!LocalizedName||!ProxyServerPassword (English)||
     91||!DefaultValue||||
     92||!IsRequired||No||
     93||!IsProtected||Yes||
     94||!IsEnumerable||No||
     95||!IsFileName||No||
     96||!IsFilePath||No||
     97||!IsDatastoreName||No||
     98
     99==== !ProxyBypassForLocal ====
     100
     101The !ProxyBypassForLocal property specifies whether to use the proxy server for all local (intranet) addresses. Because a proxy server acts as a security barrier between an internal network (intranet) and the Internet, users could need extra permissions from your system administrator to gain access to Web pages through a proxy server. Users may be able to gain access to local addresses easier and faster without using a proxy server.
     102
     103||'''Property'''||'''Value'''||
     104||Name||!ProxyBypassForLocal||
     105||!LocalizedName||!ProxyBypassForLocal(English)||
     106||!DefaultValue||No||
     107||!IsRequired||No||
     108||!IsProtected||No||
     109||!IsEnumerable||Yes||
     110||Enumerations||True||
     111||||False||
     112||!IsFileName||No||
     113||!IsFilePath||No||
     114||!IsDatastoreName||No||
     115
     116==== Example Usage ====
     117
     118The following are examples of how the connection properties specified above.
     119
     120===== Use System Proxy Server Settings (Default) =====
     121
     122The following is an example using FdoIConnection::!SetConnectionString.
     123
     124{{{
     125FdoPtr<FdoIConnection> connection = GetConnection ();
     126FdoStringP connString =
     127    L"FeatureServer=http://www.myserver.com/wfs;
     128      Username=guest;
     129      Password=guest;
     130      Version=1.1.1");
     131connection->SetConnectionString(connString);
     132FdoConnectionState state = connection->Open ();
     133}}}
     134
     135The following is an example using the FdoIConnectionPropertyDictionary.
     136
     137{{{
     138FdoPtr<FdoIConnection> conn = GetConnection ();
     139FdoPtr<FdoIConnectionInfo> info = conn->GetConnectionInfo();
     140FdoPtr<FdoIConnectionPropertyDictionary> props = info->GetConnectionProperties();
     141props->SetProperty(L"FeatureServer", L"http://www.myserver.com/wfs");
     142props->SetProperty(L"Username", L"guest");
     143props->SetProperty(L"Password", L"guest");
     144props->SetProperty(L"Version", L"1.1.0");
     145FdoConnectionState state = connection->Open ();
     146}}}
     147
     148===== Use System Proxy Server Settings with Bypass =====
     149
     150The following is an example using FdoIConnection::!SetConnectionString.
     151
     152{{{
     153FdoPtr<FdoIConnection> connection = GetConnection ();
     154FdoStringP connString =
     155    L"FeatureServer=http://www.myserver.com/wfs;
     156      Username=guest;
     157      Password=guest;
     158      Version=1.1.1;
     159      ProxyBypassForLocal=true");
     160connection->SetConnectionString(connString);
     161FdoConnectionState state = connection->Open ();
     162}}}
     163
     164The following is an example using the FdoIConnectionPropertyDictionary.
     165
     166{{{
     167FdoPtr<FdoIConnection> conn = GetConnection ();
     168FdoPtr<FdoIConnectionInfo> info = conn->GetConnectionInfo();
     169FdoPtr<FdoIConnectionPropertyDictionary> props = info->GetConnectionProperties();
     170props->SetProperty(L"FeatureServer", L"http://www.myserver.com/wfs");
     171props->SetProperty(L"Username", L"guest");
     172props->SetProperty(L"Password", L"guest");
     173props->SetProperty(L"Version", L"1.1.0");
     174props->SetProperty(L"ProxyBypassForLocal", L"true");
     175FdoConnectionState state = connection->Open ();
     176}}}
     177
     178===== Use Direct Connection Server Settings =====
     179
     180The following is an example using FdoIConnection::!SetConnectionString.
     181
     182{{{
     183FdoPtr<FdoIConnection> connection = GetConnection ();
     184FdoStringP connString =
     185    L"FeatureServer=http://www.myserver.com/wfs;
     186      Username=guest;
     187      Password=guest;
     188      Version=1.1.1;
     189      ConnectionType=UseDirectConnection");
     190connection->SetConnectionString(connString);
     191FdoConnectionState state = connection->Open ();
     192}}}
     193
     194The following is an example using the FdoIConnectionPropertyDictionary.
     195
     196{{{
     197FdoPtr<FdoIConnection> conn = GetConnection ();
     198FdoPtr<FdoIConnectionInfo> info = conn->GetConnectionInfo();
     199FdoPtr<FdoIConnectionPropertyDictionary> props = info->GetConnectionProperties();
     200props->SetProperty(L"FeatureServer", L"http://www.myserver.com/wfs");
     201props->SetProperty(L"Username", L"guest");
     202props->SetProperty(L"Password", L"guest");
     203props->SetProperty(L"Version", L"1.1.0");
     204props->SetProperty(L"ConnectionType", L"UseDirectConnection");
     205FdoConnectionState state = connection->Open ();
     206}}}
     207
     208===== Use User-Specified Proxy Server =====
     209
     210The following is an example using FdoIConnection::!SetConnectionString.
     211
     212{{{
     213FdoPtr<FdoIConnection> connection = GetConnection ();
     214FdoStringP connString =
     215    L"FeatureServer=http://www.myserver.com/wfs;
     216      Username=guest;
     217      Password=guest;
     218      Version=1.1.1;
     219      ConnectionType=UseProxyServer;
     220      ProxyServerName=Server123");
     221connection->SetConnectionString(connString);
     222FdoConnectionState state = connection->Open ();
     223}}}
     224
     225The following is an example using the FdoIConnectionPropertyDictionary.
     226
     227{{{
     228FdoPtr<FdoIConnection> conn = GetConnection ();
     229FdoPtr<FdoIConnectionInfo> info = conn->GetConnectionInfo();
     230FdoPtr<FdoIConnectionPropertyDictionary> props = info->GetConnectionProperties();
     231props->SetProperty(L"FeatureServer", L"http://www.myserver.com/wfs");
     232props->SetProperty(L"Username", L"guest");
     233props->SetProperty(L"Password", L"guest");
     234props->SetProperty(L"Version", L"1.1.0");
     235props->SetProperty(L"ConnectionType", L"UseProxyServer");
     236props->SetProperty(L"ProxyServerName", L"Server123");
     237FdoConnectionState state = connection->Open ();
     238}}}
     239
     240===== Use User-Specified Proxy Server with Password =====
     241
     242The following is an example using FdoIConnection::!SetConnectionString.
     243
     244{{{
     245FdoPtr<FdoIConnection> connection = GetConnection ();
     246FdoStringP connString =
     247    L"FeatureServer=http://www.myserver.com/wfs;
     248      Username=guest;
     249    Password=guest;
     250    Version=1.1.1;
     251    ConnectionType=UseProxyServer;
     252    ProxyServerName=Server123;
     253    ProxyServerPort=80;
     254    ProxyServerUsername=user1;
     255    ProxyServerPassword=pwd");
     256connection->SetConnectionString(connString);
     257FdoConnectionState state = connection->Open ();
     258}}}
     259
     260The following is an example using the FdoIConnectionPropertyDictionary.
     261
     262{{{
     263FdoPtr<FdoIConnection> conn = GetConnection ();
     264FdoPtr<FdoIConnectionInfo> info = conn->GetConnectionInfo();
     265FdoPtr<FdoIConnectionPropertyDictionary> props = info->GetConnectionProperties();
     266props->SetProperty(L"FeatureServer", L"http://www.myserver.com/wfs");
     267props->SetProperty(L"Username", L"guest");
     268props->SetProperty(L"Password", L"guest");
     269props->SetProperty(L"Version", L"1.1.0");
     270props->SetProperty(L"ConnectionType", L"UseProxyServer");
     271props->SetProperty(L"ProxyServerName", L"Server123");
     272props->SetProperty(L"ProxyServerPort", L"80");
     273props->SetProperty(L"ProxyServerUsername", L"user1");
     274props->SetProperty(L"ProxyServerPassword", L"pwd");
     275FdoConnectionState state = connection->Open ();
     276}}}
     277
     278
     279
