Changes between Version 11 and Version 12 of FdoGdalNotes
07/27/07 08:03:41 (18 years ago)
jbirch
We really need to re-brand MapGuide to get rid of the CamelCase :)
  • FdoGdalNotes
    v11 v12
    6363In order to address this problem, the raster provider's config file schema was extended (initially to meet the same need with the proprietary Autodesk raster provider) to store bounding boxes for the images in the feature source.  Using this new schema as a guideline, Frank has added preliminary bounds support to the fdogdal provider, and this has been sucessfully tested in several environments.  Further testing is encouraged.
    6464
    65 '''Note:''' These enhancements are only available for FDO 3.2.2, which means that you must be running MapGuide 1.2 RC or greater.
     65'''Note:''' These enhancements are only available for FDO 3.2.2, which means that you must be running !MapGuide 1.2 RC or greater.
    6666
    6767=== Downloads ===
