Changes between Version 4 and Version 5 of FdoExpressionType
- Oct 18, 2007, 8:04:35 AM (17 years ago)
FdoExpressionType
v4 v5 14 14 === API Changes === 15 15 16 Retrieving the expression type will be supported by adding !GetExpressionType() (for !FdoExpression) functions to each class derived from !FdoExpression and !GetFilterType() (for !FdoFilter) functions to each class derived from !FdoFilter. The functions will not have any parameters and will simply return the type of expression or filter.16 Retrieving the expression type will be supported by adding !GetExpressionType() functions to each class derived from !FdoExpression and !GetFilterType() functions to each class derived from !FdoFilter. The functions will not have any parameters and will simply return the type of expression or filter. 17 17 18 18 To support such a change, the FDO API will need to define two enumerations which will contain all types of expression and filters.
