Changes between Version 6 and Version 7 of FDORfc60
Apr 13, 2011, 8:11:05 AM (13 years ago)
gregboone
  • FDORfc60
    v6 v7
    106106Let us use the following physical schema as a starting point for further discussion.  In this example a Road table is used to capture the Location, Name and Width of road objects in a city. Associated to the Road table is a !RoadAnnotation table that contains textual labels that describe the road. A Road object can be associated to 0…n !RoadAnnotation objects.
    107107
     108[[Image(road_example.png)]]
     109
     110These two classes are related through their primary identifiers.
     111
     112        Road.!FeatId == !RoadAnnotation.!ParentId
     113
     114Road features can be related n times to !RoadAnnotation objects through a combination of matching primary identifiers and the !RoadAnnotation !SequenceId. The full primary key on !RoadAnnotation is therefore a combination of the !ParentId and !SequenceId. The !SequenceId column is used to order the text elements associated to Road. Any sortable type is valid for this column in the table, although integers would be the obvious choice.
     115
     116The !RoadAnnotation table contains a set of properties that are in form (not name) mandated by the OGC specification. These properties, taken together, represent a complete Annotation Text Element. Each Text Element is defined by its Location or spatial geometry, a textual display Value, a textual description of its display model Attributes, and the geographic Leader Line that is used to place the Text Value in relation to its owner or neighboring features.
     117
     118The optional “Text” properties defined on the Road table are also mandated by the OGC Specification. Implementing applications may optionally provide a means of capturing the overall Text Envelope, a Default Text Value and a set of Default Text Attributes to be used to describe all instances of Annotation Text associated to the parent feature. The Default values are used if no values (NULL) are specified for a individual instance of an Annotation object. The Text Default Value may be a text string or a query expression. Text Default Attributes are typically serialized XML documents that describe how to symbolize text entities and their leader lines.
     119
     120In the example above, I show these properties defined on the parent Road table, however, they could in fact be located in any schema:table in the data store and their location and property names described using metadata.
    108121
    109122
