Changes between Version 2 and Version 3 of FDORfc57
- Mar 23, 2011, 6:59:21 PM (13 years ago)
FDORfc57
v2 v3 1 = FDO RFC 57 - Implement the GetFeatureInfo command for WMS provider =1 = FDO RFC 57 - Implement the !GetFeatureInfo command for WMS provider = 2 2 3 3 This page contains a request for comments document (RFC) for the FDO Open Source project. … … 22 22 == Overview == 23 23 24 The RFC is to implement the GetFeatureInfo command for WMS provider.24 The RFC is to implement the !GetFeatureInfo command for WMS provider. 25 25 26 26 == Motivation == 27 27 28 GetFeatureInfo is an optional operation of WMS server. It is only supported for those Layers for which the attribute queryable="1" (true) has been defined or inherited. 29 The GetFeatureInfo operation is designed to provide clients of a WMS with more information about features in the pictures of maps that were returned by Get Map requests. The canonical use case for GetFeatureInfo is that a user sees the response of a Map request and chooses a point on that map for which to obtain more information. 30 Here is the table of the parameters of a GetFeatureInfo Request based on the 1.3.0 version: 28 !GetFeatureInfo is an optional operation of WMS server. It is only supported for those Layers for which the attribute queryable="1" (true) has been defined or inherited. The !GetFeatureInfo operation is designed to provide clients of a WMS with more information about features in the pictures of maps that were returned by Get Map requests. The canonical use case for !GetFeatureInfo is that a user sees the response of a Map request and chooses a point on that map for which to obtain more information. 29 30 Here is the table of the parameters of a !GetFeatureInfo Request based on the 1.3.0 version: 31 31 32 ||'''Request parameter''' ||'''Mandatory/optional''' ||'''Description'''|| 32 33 ||VERSION=1.3.0 ||M ||Request version|| 33 ||REQUEST= GetFeatureInfo ||M ||Request name||34 ||REQUEST=!GetFeatureInfo ||M ||Request name|| 34 35 ||map request part|| M ||Partial copy of the Map request parameters that generated the map for which information is desired.|| 35 36 ||QUERY_LAYERS=layer_list || M ||Comma-separated list of one or more layers to be queried|| … … 39 40 ||J=pixel_row ||M ||j coordinate in pixels of feature in Map CS|| 40 41 ||EXCEPTIONS=exception_format ||O ||The format in which exceptions are to be reported by the WMS (default= XML)|| 42 41 43 Basically, the goal is that users must be able to not only connect to WMS services and add features to maps from those services; they should also be able to click on map features to get more information.[[BR]] 42 44 As to the 1.1.0 version, the standard employs the x = pixel_column and y = pixel_row to replace I = pixel_column and J = pixel_row.[[BR]] 43 More details regarding the WMS GetFeatureInfo request can be found in the WMS standards http://www.opengeospatial.org/standards/wms.45 More details regarding the WMS !GetFeatureInfo request can be found in the WMS standards http://www.opengeospatial.org/standards/wms. 44 46 45 47 == Proposed Solution == 46 48 47 The shortest WMS GetFeatureInfo implementation path would involve implementingGetFeatureInfo request within the current FDO WMS provider. The design solution would provide a custom command to users to retrieve the feature information: FdoWmsCommandType_GetFeatureInfo.[[BR]]48 49 '''• Input of the GetFeatureInfo request'''[[BR]]50 From the required parameters table above, we can see GetFeatureInfo requires almost all the parameters required byGetMap request and plus more, the custom command would also require the same input for Select command and extra parameters (i, j coordinate in pixels of feature in Map CS). [[BR]]51 52 '''• Output of the GetFeatureInfo request'''[[BR]]53 The format of responded message from the GetFeatureInfo request is defined by the WMS server. For example:[[BR]]49 The shortest WMS !GetFeatureInfo implementation path would involve implementing !GetFeatureInfo request within the current FDO WMS provider. The design solution would provide a custom command to users to retrieve the feature information: FdoWmsCommandType_GetFeatureInfo.[[BR]] 50 51 '''• Input of the !GetFeatureInfo request'''[[BR]] 52 From the required parameters table above, we can see !GetFeatureInfo requires almost all the parameters required by !GetMap request and plus more, the custom command would also require the same input for Select command and extra parameters (i, j coordinate in pixels of feature in Map CS). [[BR]] 53 54 '''• Output of the !GetFeatureInfo request'''[[BR]] 55 The format of responded message from the !GetFeatureInfo request is defined by the WMS server. For example:[[BR]] 54 56 <Format>text/plain</Format> [[BR]] 55 57 <Format>text/html</Format>[[BR]] 56 Currently, the WMS implementation specification doesn’t define a standard format for it. So, the solution is to return a FdoString* type pointer by this command. If user set the FEATURE_COUNT greater than 1, the information for multiple candidate features will be returned. However, we don’t parse the returned information since no standard regarding the format and client should take the responsibility to parse it. For example the following text is returned from one server to response the GetFeatureInfo request.[[BR]]58 Currently, the WMS implementation specification doesn’t define a standard format for it. So, the solution is to return a FdoString* type pointer by this command. If user set the FEATURE_COUNT greater than 1, the information for multiple candidate features will be returned. However, we don’t parse the returned information since no standard regarding the format and client should take the responsibility to parse it. For example the following text is returned from one server to response the !GetFeatureInfo request.[[BR]] 57 59 Layer 'IBA'[[BR]] 58 60 Feature 6:[[BR]] … … 67 69 LINK = 'http://www.bsc-eoc.org/iba/site.jsp?siteID=NU089' [[BR]] 68 70 69 However, the following XML formatted message will return if issue the command to a MapGuide server. [[BR]] 71 However, the following XML formatted message will return if issue the command to a !MapGuide server. [[BR]] 72 73 {{{ 70 74 <?xml version=”1.0”, encoding=”UTF-18”?> [[BR]] 71 75 < FeatureInfoCollection>[[BR]] … … 77 81 </FeatureInfo> [[BR]] 78 82 </FeatureInfoCollection> [[BR]] 83 }}} 84 79 85 Note: we can parse the response value and return a class if WMS spec defines a standard format in the future. 80 86 81 '''• GetFeatureInfo custom command interface'''[[BR]]87 '''• !GetFeatureInfo custom command interface'''[[BR]] 82 88 83 89 {{{ … … 94 100 /// Execute the FdoWmsIGetFeatureInfo command and returns a 95 101 /// FdoString* pointer, which points to the feature information returned 96 102 /// by the WMS server. 97 103 /// 98 104 /// \return … … 126 132 /// \brief 127 133 /// Set the position (X, Y) which indicates a point of interest on the map that was 128 /// produced by the embedded GetMap request.The point (X, Y) is a134 /// produced by the embedded !GetMap request.The point (X, Y) is a 129 135 /// point in the (i, j) space defined by the Map CS. 130 136 /// This function is mandatory; if not specified, … … 137 143 /// Return nothing 138 144 /// 139 FDO_API virtual void SetPosition(FdoIDirectPosition* pos) = 0;145 FDO_API virtual void SetPosition(FdoIDirectPosition* pos) = 0; 140 146 141 147 /// \brief 142 148 /// Get the position (X, Y) which indicates a point of interest on the map that was 143 /// produced by the embedded GetMap request. The point (X, Y) is a149 /// produced by the embedded !GetMap request. The point (X, Y) is a 144 150 /// point in the (i, j) space defined by the Map CS. 145 151 /// … … 169 175 }; 170 176 }}} 171 In this class, both methods GetFeatureClassNames and SetFeatureClassNames are used to get/set the feature class collection which would be mapped to WMS layers in order to query the relevant feature information. [[BR]] 177 178 In this class, both methods !GetFeatureClassNames and !SetFeatureClassNames are used to get/set the feature class collection which would be mapped to WMS layers in order to query the relevant feature information. [[BR]] 172 179 173 180 '''• Example''' [[BR]] 174 The GetFeatureInfo custom command will be used like below: 181 182 The !GetFeatureInfo custom command will be used like below: 175 183 176 184 {{{ 177 FdoPtr<FdoWmsIGetFeatureInfo> cmdGFI = static_cast<FdoWmsIGetFeatureInfo*> (connection->CreateCommand(FdoWmsCommandType_ GetFeatureInfo));185 FdoPtr<FdoWmsIGetFeatureInfo> cmdGFI = static_cast<FdoWmsIGetFeatureInfo*> (connection->CreateCommand(FdoWmsCommandType_!GetFeatureInfo)); 178 186 FdoPtr<FdoIdentifier> id = FdoIdentifier::Create(L”Park”); 179 187 cmdGFI->SetFeatureClassNames(id); … … 183 191 FdoStringP featureInfo = cmdGFI->Execute (); 184 192 }}} 185 Since there are lots of same parameters required as GetMap request, the Execute function of this custom command will be similar with the select command. The difference is to pass the extra i, j values and fire the GetFeatureInfo request to WMS server. What’s more, share the same codes between select command and GetFeatureInfo custom command should be considered seriously.[[BR]] 186 187 Similar to the GetMap request, the parameters regarding the GetMap parts should be obtained from the override configuration. If it’s not customized, the default parameters will be gotten from capabilities documents (returned from GetCapabilities). One note is that the command should generally be called after the GetMap request; otherwise, the returned result is probably unexpected if the parameters are wrongly specified. 193 194 Since there are lots of same parameters required as !GetMap request, the Execute function of this custom command will be similar with the select command. The difference is to pass the extra i, j values and fire the !GetFeatureInfo request to WMS server. What’s more, share the same codes between select command and !GetFeatureInfo custom command should be considered seriously.[[BR]] 195 196 Similar to the !GetMap request, the parameters regarding the !GetMap parts should be obtained from the override configuration. If it’s not customized, the default parameters will be gotten from capabilities documents (returned from !GetCapabilities). One note is that the command should generally be called after the !GetMap request; otherwise, the returned result is probably unexpected if the parameters are wrongly specified. 188 197 189 198 == Implications ==
