Changes between Version 20 and Version 21 of FDORfc50
Jun 3, 2010, 10:44:33 AM (14 years ago)
gregboone
  • FDORfc50
    v20 v21
    2323== Motivation ==
    2424
    25 It is a common requirement for applications to join classes together so that they can process related information that is spread across more than one class, e.g. properties stored in one class and geometry in another class. This can be for modeling purposes such as when geometry in one class is shared between separate feature classes or when properties from another class are needed for rendering purposes. Currently this is achieved either by using client-side join processing as in MapGuide or for RDBMS sources, by defining views as the physical level and exposing them as feature classes at the FDO API level. While these techniques are useful, the first results in very poor performance compared to a native join if the classes come from the same data store and the data store can do native joins as is possible with RDBMS-based providers. Using views is common as well, but requires the user to do this at the physical data store level. Finally, users could use SQL pass-through for providers that support it but that has issues because again the user is dealing with physical schema rather than FDO classes and the result is not a feature class.
     25It is a common requirement for applications to join classes together so that they can process related information that is spread across more than one class, e.g. properties stored in one class and geometry in another class. This can be for modeling purposes such as when geometry in one class is shared between separate feature classes or when properties from another class are needed for rendering purposes. Currently this is achieved either by using client-side join processing as in !MapGuide or for RDBMS sources, by defining views as the physical level and exposing them as feature classes at the FDO API level. While these techniques are useful, the first results in very poor performance compared to a native join if the classes come from the same data store and the data store can do native joins as is possible with RDBMS-based providers. Using views is common as well, but requires the user to do this at the physical data store level. Finally, users could use SQL pass-through for providers that support it but that has issues because again the user is dealing with physical schema rather than FDO classes and the result is not a feature class.
    2626
    2727This RFC adds the ability to create joined selects using the FDO API directly rather than using the workarounds described above. This adds more power and flexibility to the FDO API for applications that need that capability. This enhancement will be optional for providers and a capabilities function is included for an application to determine if a provider supports it.
