Changes between Version 24 and Version 25 of FDORfc48
07/30/10 05:40:20 (15 years ago)
oresthalustchak
  • TabularUnified FDORfc48
    v24 v25
    183183Autodesk to provide resources / funding.
    184184
    185 == Addendum, July 30, 2010 ==
    186
    187 This RFC provides some utility methods to check polygon vertex order and fix polygon vertex order errors. However, what action should be taken when copying a polygon from one feature source to another feature source isn't addressed in this RFC. The answer for this question depends on users' preference. The following enums and methods will be introduced to address it.
    188
    189 {{{
    190 /// \brief
    191 /// FdoFixPolygonVertexOrderAction is an enumeration of the action taken
    192 /// when fixing polygon vertex order.
    193 ///
    194 enum FdoFixPolygonVertexOrderAction
    195 {
    196     /// No processing.
    197     FdoFixPolygonVertexOrderAction_None = 0,
    198
    199     /// Reverse polygon vertex.
    200     FdoFixPolygonVertexOrderAction_Reverse = 1,
    201
    202     /// Check polygon vertex order and fix it if necessary.
    203     FdoFixPolygonVertexOrderAction_CheckAndFix = 2
    204 };
    205
    206 /// \brief
    207 /// FdoFixPolygonVertexOrderPreference represents the preference
    208 /// when fixing polygon vertex order.
    209 ///
    210 enum FdoFixPolygonVertexOrderPreference
    211 {
    212     /// Prefer performance. It guarantees that polygons in the target have the correct
    213     /// vertex order if the target is enforced.
    214     FdoFixPolygonVertexOrderPreference_Performance = 0,
    215
    216     /// Prefer correctness. It guarantees that polygons in the target have
    217     /// the correct vertex order if the vertex order rule of the target isn't none.
    218     FdoFixPolygonVertexOrderPreference_Correctness = 1
    219 };
    220
    221
    222 /// \brief
    223 /// Spatial utility class
    224 ///
    225 class FdoSpatialUtility
    226 {
    227 public:
    228     /// \brief
    229     /// Given the vertex order and strictness rule of the source and the target,
    230     /// get what action should be taken to fix polygon.
    231     ///
    232     /// \param sourceVertexOrderRule
    233     /// Input the vertex order rule of the source.
    234     /// \param sourceStrictnessRule
    235     /// Input the vertex order strictness rule of the source.
    236     /// \param targetVertexOrderRule
    237     /// Input the vertex order rule of the target.
    238     /// \param targetStrictnessRule
    239     /// Input the vertex order strictness rule of the target.
    240     /// \param preference
    241     /// Input the preference when fixing polygon vertex order.
    242     ///
    243     /// \return
    244     /// Returns the action taken to fixing polygon vertex order.
    245     ///
    246     FDO_SPATIAL_API static FdoFixPolygonVertexOrderAction GetFixPolygonVertexOrderAction(
    247         FdoPolygonVertexOrderRule sourceVertexOrderRule,
    248         FdoBoolean sourceStrictnessRule,
    249         FdoPolygonVertexOrderRule targetVertexOrderRule,
    250         FdoBoolean targetStrictnessRule,
    251         FdoFixPolygonVertexOrderPreference preference);
    252 };
    253 }}}
    254
    255 Method !GetFixPolygonVertexOrderAction is used to get what action should be taken when copying a polygon from one feature source to another feature source. The following two tables are defined in this method.
    256
    257 {{{
    258 static FdoFixPolygonVertexOrderAction table1[36] = {
    259                                                     // From Order    From Strict    To Order    To Strict     NonSense
    260     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CCW           Enforced       CCW         Enforced
    261     FdoFixPolygonVertexOrderAction_None,            // CCW           Enforced       CCW         Not enforced
    262     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CCW           Enforced       CW          Enforced
    263     FdoFixPolygonVertexOrderAction_Reverse,         // CCW           Enforced       CW          Not enforced
    264     FdoFixPolygonVertexOrderAction_None,            // CCW           Enforced       None        Enforced      True
    265     FdoFixPolygonVertexOrderAction_None,            // CCW           Enforced       None        Not enforced
    266
    267     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CCW           Not enforced   CCW         Enforce
    268     FdoFixPolygonVertexOrderAction_None,            // CCW           Not enforced   CCW         Not enforced
    269     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CCW           Not enforced   CW          Enforced
    270     FdoFixPolygonVertexOrderAction_Reverse,         // CCW           Not enforced   CW          Not enforced
    271     FdoFixPolygonVertexOrderAction_None,            // CCW           Not enforced   None        Enforced      True
    272     FdoFixPolygonVertexOrderAction_None,            // CCW           Not enforced   None        Not enforced
    273
    274     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CW            Enforced       CCW         Enforced
    275     FdoFixPolygonVertexOrderAction_Reverse,         // CW            Enforced       CCW         Not enforced
    276     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CW            Enforced       CW          Enforced
    277     FdoFixPolygonVertexOrderAction_None,            // CW            Enforced       CW          Not enforced
    278     FdoFixPolygonVertexOrderAction_None,            // CW            Enforced       None        Enforced      True
    279     FdoFixPolygonVertexOrderAction_None,            // CW            Enforced       None        Not enforced
    280
    281     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CW            Not enforced   CCW         Enforced
    282     FdoFixPolygonVertexOrderAction_Reverse,         // CW            Not enforced   CCW         Not enforced
    283     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CW            Not enforced   CW          Enforced
    284     FdoFixPolygonVertexOrderAction_None,            // CW            Not enforced   CW          Not enforced
    285     FdoFixPolygonVertexOrderAction_None,            // CW            Not enforced   None        Enforced      True
    286     FdoFixPolygonVertexOrderAction_None,            // CW            Not enforced   None        Not enforced
    287
    288     FdoFixPolygonVertexOrderAction_CheckAndFix,     // None          Enforced       CCW         Enforced      True
    289     FdoFixPolygonVertexOrderAction_None,            // None          Enforced       CCW         Not enforced  True
    290     FdoFixPolygonVertexOrderAction_CheckAndFix,     // None          Enforced       CW          Enforced      True
    291     FdoFixPolygonVertexOrderAction_None,            // None          Enforced       CW          Not enforced  True
    292     FdoFixPolygonVertexOrderAction_None,            // None          Enforced       None        Enforced      True
    293     FdoFixPolygonVertexOrderAction_None,            // None          Enforced       None        Not enforced  True
    294
    295     FdoFixPolygonVertexOrderAction_CheckAndFix,     // None          Not enforced   CCW         Enforced
    296     FdoFixPolygonVertexOrderAction_None,            // None          Not enforced   CCW         Not enforced
    297     FdoFixPolygonVertexOrderAction_CheckAndFix,     // None          Not enforced   CW          Enforced
    298     FdoFixPolygonVertexOrderAction_None,            // None          Not enforced   CW          Not enforced
    299     FdoFixPolygonVertexOrderAction_None,            // None          Not enforced   None        Enforced      True
    300     FdoFixPolygonVertexOrderAction_None             // None          Not enforced   None        Not enforced
    301 };
    302
    303 static FdoFixPolygonVertexOrderAction table2[36] = {
    304                                                     // From Order    From Strict    To Order    To Strict     NonSense
    305     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CCW           Enforced       CCW         Enforced
    306     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CCW           Enforced       CCW         Not enforced
    307     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CCW           Enforced       CW          Enforced
    308     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CCW           Enforced       CW          Not enforced
    309     FdoFixPolygonVertexOrderAction_None,            // CCW           Enforced       None        Enforced      True
    310     FdoFixPolygonVertexOrderAction_None,            // CCW           Enforced       None        Not enforced
    311
    312     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CCW           Not enforced   CCW         Enforced
    313     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CCW           Not enforced   CCW         Not enforced
    314     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CCW           Not enforced   CW          Enforced
    315     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CCW           Not enforced   CW          Not enforced
    316     FdoFixPolygonVertexOrderAction_None,            // CCW           Not enforced   None        Enforced      True
    317     FdoFixPolygonVertexOrderAction_None,            // CCW           Not enforced   None        Not enforced
    318
    319     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CW            Enforced       CCW         Enforced
    320     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CW            Enforced       CCW         Not enforced
    321     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CW            Enforced       CW          Enforced
    322     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CW            Enforced       CW          Not enforced
    323     FdoFixPolygonVertexOrderAction_None,            // CW            Enforced       None        Enforced      True
    324     FdoFixPolygonVertexOrderAction_None,            // CW            Enforced       None        Not enforced
    325
    326     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CW            Not enforced   CCW         Enforced
    327     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CW            Not enforced   CCW         Not enforced
    328     FdoFixPolygonVertexOrderAction_CheckAndFix,     // CW            Not enforced   CW          Enforced
    329     FdoFixPolygonVertexOrderAction_CheckAndFix,    // CW            Not enforced   CW          Not enforced
    330     FdoFixPolygonVertexOrderAction_None,            // CW            Not enforced   None        Enforced      True
    331     FdoFixPolygonVertexOrderAction_None,            // CW            Not enforced   None        Not enforced
    332
    333     FdoFixPolygonVertexOrderAction_CheckAndFix,     // None          Enforced       CCW         Enforced      True
    334     FdoFixPolygonVertexOrderAction_CheckAndFix,     // None          Enforced       CCW         Not enforced  True
    335     FdoFixPolygonVertexOrderAction_CheckAndFix,     // None          Enforced       CW          Enforced      True
    336     FdoFixPolygonVertexOrderAction_CheckAndFix,     // None          Enforced       CW          Not enforced  True
    337     FdoFixPolygonVertexOrderAction_None,            // None          Enforced       None        Enforced      True
    338     FdoFixPolygonVertexOrderAction_None,            // None          Enforced       None        Not enforced  True
    339
    340     FdoFixPolygonVertexOrderAction_CheckAndFix,     // None          Not enforced   CCW         Enforced
    341     FdoFixPolygonVertexOrderAction_CheckAndFix,     // None          Not enforced   CCW         Not enforced
    342     FdoFixPolygonVertexOrderAction_CheckAndFix,     // None          Not enforced   CW          Enforced
    343     FdoFixPolygonVertexOrderAction_CheckAndFix,     // None          Not enforced   CW          Not enforced
    344     FdoFixPolygonVertexOrderAction_None,            // None          Not enforced   None        Enforced      True
    345     FdoFixPolygonVertexOrderAction_None             // None          Not enforced   None        Not enforced
    346 };
    347 }}}
    348
    349 If users perfer performance to correctness, method !GetFixPolygonVertexOrderAction will use table1. It guarantees that polygons in the target will have the correct vertex order if the target is enforced. If users perfer correctness to performance, method !GetFixPolygonVertexOrderAction will use table2. It guarantees that polygons in the target will have the correct vertex order if the vertex order rule of the target isn't none.
    350
    351 Considering performance, an additional parameter '!FdoBoolean checkInteriorRings' will be added for method FdoSpatialUtility::!ReversePolygonVertexOrder(...). If users know the input polygon is a valid polygon, they can pass false for parameter checkInteriorRings to reverse its vertex order. Otherwise, pass true. Method !FdoSpatialUtility::!ReversePolygonVertexOrder(...) will check whether interior rings have the different vertex order with exterior ring and guarantee the returned polygon is a valid polygon after reversing the vertex order of the input polygon.
    352
    353
    354 {{{
    355 class FdoSpatialUtility
    356 {
    357 public:
    358     /// \brief
    359     /// Reverse the vertex order of the input polygon.
    360     ///
    361     /// \param geometry
    362     /// Input the polygon geometry to be reversed. It can be a polygon, multipolygon,
    363     /// curvepolygon, or multicurvepolygon.
    364     /// \param checkInteriorRings
    365     /// true  - Check whether interior rings have the different vertex order with
    366     ///         exterior ring and guarantee the returned polygon is a valid polygon
    367     ///         after reversing the vertex order of the input polygon.
    368     /// false - Reverse the vertex order of interior rings and exterior ring directly
    369     ///         no matter interior rings have the different vertex order with exterior ring.
    370     ///
    371     /// \return
    372     /// Returns the modified polygon.
    373     ///
    374     FDO_SPATIAL_API static FdoIGeometry* ReversePolygonVertexOrder (
    375                               FdoIGeometry * geometry,
    376                               FdoBoolean checkInteriorRings = false );
    377 }
    378 }}}
