Changes between Version 7 and Version 8 of FDORfc38
Aug 26, 2009, 10:18:33 AM (15 years ago)
danstoica
  • FDORfc38
    v7 v8
    4444    * The FDO geometry type will be set accordingly on reading. The caller must expect either a polygon or a multi-polygon regardless of original geometry type on insert.
    4545
     46    * This is a behavior change to the SHP provider. Before this change, SHP would return only polygon types. It would never return something called a multi-polygon. After the change, SHP will return either polygons or multi-polygons. Previously a layer from a polygon SHP file would have only polygons, now it could have polygons, multi-polygons or both. This change could occur with existing data and layers, e.g. stylization rules that handle polygons and multi-polygons differently may see a change.
     47
     48
     49
    4650== Test Plan ==
    4751
