Changes between Version 10 and Version 11 of FDORfc34
Apr 15, 2009, 1:40:48 PM (15 years ago)
gregboone
  • FDORfc34
    v10 v11
    414414
    415415
     416=== ISQLDataReader ===
     417
     418{{{
     419/// \brief
     420/// The FdoISQLDataReader interface provides a forward-only, read-only
     421/// iterator for reading relational table data. A reference to an
     422/// FdoISQLDataReader is returned from the SQLCommands ExecuteReader method.
     423/// The initial position of the FdoISQLDataReader interface is prior to the first item.
     424/// Thus, you must call ReadNext to begin accessing any data.
     425class FdoISQLDataReader: public FdoIDisposable
     426{
     427public:
     428...
     429...
     430...
     431    /// \brief
     432    /// Returns true if the value of the specified column is null.
     433    ///
     434    /// \param index
     435    /// Input the position of the column.
     436    ///
     437    /// \return
     438    /// Returns true if the value is null.
     439    ///
     440    FDO_API virtual FdoBoolean IsNull(FdoInt32 index);
     441
     442    /// \brief
     443    /// Gets the data type of the column at the specified index.
     444    ///
     445    /// \param index
     446    /// Input the position of the column.
     447    ///
     448    /// \return
     449    /// Returns the type of the column.
     450    ///
     451    FDO_API virtual FdoDataType GetColumnType(FdoInt32 index);
     452
     453    /// \brief
     454    /// Gets the FDO property type of the column at the specified index. This is used
     455    /// to indicate if a given column is a geometric property or a data property. If the column is
     456    /// a FdoPropertyType_DataProperty, then GetColumnType can be used to find the data type of the column.
     457    ///
     458    /// \param index
     459    /// Input the position of the column.
     460    ///
     461    /// \return
     462    /// Returns the FDO property type of the column.
     463    ///
     464    FDO_API virtual FdoPropertyType GetPropertyType(FdoInt32 index);
     465
     466    /// \brief
     467    /// Gets the Boolean value of the specified column. No conversion is
     468    /// performed, thus the column must be FdoDataType_Boolean or an
     469    /// exception is thrown.
     470    ///
     471    /// \param index
     472    /// Input the position of the column.
     473    ///
     474    /// \return
     475    /// Returns the Boolean value
     476    ///
     477    FDO_API virtual FdoBoolean GetBoolean(FdoInt32 index);
     478
     479    /// \brief
     480    /// Gets the byte value of the specified column. No conversion is
     481    /// performed, thus the column must be FdoDataType_Byte or an
     482    /// exception is thrown.
     483    ///
     484    /// \param index
     485    /// Input the position of the column.
     486    ///
     487    /// \return
     488    /// Returns the byte value.
     489    ///
     490    FDO_API virtual FdoByte GetByte(FdoInt32 index);
     491
     492    /// \brief
     493    /// Gets the date time value of the specified column. No conversion
     494    /// is performed, thus the column must be FdoDataType_DateTime or
     495    /// an exception is thrown.
     496    ///
     497    /// \param index
     498    /// Input the position of the column.
     499    ///
     500    /// \return
     501    /// Returns the date and time value.
     502    ///
     503    FDO_API virtual FdoDateTime GetDateTime(FdoInt32 index);
     504
     505    /// \brief
     506    /// Gets the double-precision floating point value of the specified column.
     507    /// No conversion is performed, thus the column must be of type
     508    /// Double or an exception is thrown.
     509    ///
     510    /// \param index
     511    /// Input the position of the column.
     512    ///
     513    /// \return
     514    /// Returns the double value.
     515    ///
     516    FDO_API virtual FdoDouble GetDouble(FdoInt32 index);
     517
     518    /// \brief
     519    /// Gets the signed 16-bit integer value of the specified column. No conversion is
     520    /// performed, thus the column must be FdoDataType_Int16 or an
     521    /// exception is thrown.
     522    ///
     523    /// \param index
     524    /// Input the position of the column.
     525    ///
     526    /// \return
     527    /// Returns the FdoInt16 value.
     528    ///
     529    FDO_API virtual FdoInt16 GetInt16(FdoInt32 index);
     530
     531    /// \brief
     532    /// Gets the signed 32-bit integer value of the specified column. No conversion is
     533    /// performed, thus the column must be FdoDataType_Int32 or an
     534    /// exception is thrown.
     535    ///
     536    /// \param index
     537    /// Input the position of the column.
     538    ///
     539    /// \return
     540    /// Returns the FdoInt32 value.
     541    ///
     542    FDO_API virtual FdoInt32 GetInt32(FdoInt32 index);
     543
     544    /// \brief
     545    /// Gets the signed 64-bit integer value of the specified column. No conversion
     546    /// is performed, thus the column must be FdoDataType_Int64 or an
     547    /// exception is thrown.
     548    ///
     549    /// \param index
     550    /// Input the position of the column.
     551    ///
     552    /// \return
     553    /// Returns the FdoInt64 value.
     554    ///
     555    FDO_API virtual FdoInt64 GetInt64(FdoInt32 index);
     556
     557    /// \brief
     558    /// Gets the single-precision floating point value of the specified column.
     559    /// No conversion is performed, thus the column must be FdoDataType_Single
     560    /// or an exception is thrown.
     561    ///
     562    /// \param index
     563    /// Input the position of the column.
     564    ///
     565    /// \return
     566    /// Returns the single value
     567    ///
     568    FDO_API virtual FdoFloat GetSingle(FdoInt32 index);
     569
     570    /// \brief
     571    /// Gets the string value of the specified column. No conversion is
     572    /// performed, thus the column must be FdoDataType_String or an
     573    /// exception is thrown.
     574    ///
     575    /// \param index
     576    /// Input the position of the column.
     577    ///
     578    /// \return
     579    /// Returns the string value.
     580    ///
     581    FDO_API virtual FdoString* GetString(FdoInt32 index);
     582
     583    /// \brief
     584    /// Gets a LOBValue reference. The LOB is fully read in and data available.
     585    /// Because no conversion is performed, the property must be FdoDataType_BLOB or
     586    /// FdoDataType_CLOB etc. (a LOB type)
     587    ///
     588    /// \param index
     589    /// Input the position of the column.
     590    ///
     591    /// \return
     592    /// Returns the reference to LOBValue
     593    ///
     594    FDO_API virtual FdoLOBValue* GetLOB(FdoInt32 index);
     595
     596    /// \brief
     597    /// Gets a reference of the specified LOB property as a FdoBLOBStreamReader or
     598    /// FdoCLOBStreamReader etc. to allow reading in blocks of data.
     599    /// Because no conversion is performed, the property must be FdoDataType_BLOB
     600    /// or FdoDataType_CLOB etc. (a LOB type)
     601    /// Cast the FdoIStreamReader to the appropiate LOB Stream Reader.
     602    ///
     603    /// \param index
     604    /// Input the position of the column.
     605    ///
     606    /// \return
     607    /// Returns a reference to a LOB stream reader
     608    ///
     609    FDO_API virtual FdoIStreamReader* GetLOBStreamReader(FdoInt32 index);
     610
     611    /// \brief
     612    /// Gets the geometry value of the specified column as a byte array
     613    /// in FGF format. No conversion is performed, thus the column
     614    /// must be of Geometric type or an exception is thrown.
     615    ///
     616    /// \param index
     617    /// Input the position of the column.
     618    ///
     619    /// \return
     620    /// Returns the FGF byte array value.
     621    ///
     622    FDO_API virtual FdoByteArray* GetGeometry(FdoInt32 index);
     623};
     624}}}
     625
    416626== Provider Implementation ==
    417627
