Changes between Version 4 and Version 5 of FDORfc33
04/09/09 09:32:10 (16 years ago)
gregboone
  • TabularUnified FDORfc33
    v4 v5
    2121||-1|| ||
    2222
    23
    2423== Motivation ==
    2524
    2726
    2827== Overview ==
     28
     29SQL pass-through deals with physical schema. There is no parsing and what is identified are physical schema tables, columns, functions, commands, etc. SQL can be any SQL command, not just select, but any DML (select, insert, update, delete) or any DDL (create, drop, alter, …). However, FDO feature reader deals with FDO logical schema, which is at a different conceptual level. It’s mixing these levels that causes some difficulty for applications using the FDO API.
     30
     31In general, the FDO feature reader (to a certain degree) assumes an FDO class definition related to the properties being returned, but with physical schema SQL (let’s say just Select command), there isn’t necessarily any FDO class definition that applies. That’s why currently it just returns a data reader, which handles any generic returned data (actually the FDO select aggregates command also doesn’t return a feature reader since it’s returning computed data).
     32
     33We can break down the SQL pass through selects into a couple of categories. One category would be selecting data that really isn’t related to any of the FDO schema classes, e.g. selecting from system tables or views (e.g. select from Oracle’s mdsys.cs_srs table, select stuff from dual or SQL Server’s sys.indexes, etc. Spatial predicates are quite a bit different.).
     34
     35Even if we consider cases where the select is from a table that contains feature or feature related data, what does it mean to return a class definition for that data? Do we reverse engineer the select results and try to find the FDO class definition that seems to match it, that is one of the class definitions that you would get back from FDO’s describe schema? Do we just make up a class definition that may not even exist in FDO’s Describe Schema? If the select is from a single table, we possibly could find the class definition that is based on that table and use it. However, then we have to match up the columns being selected with properties in the logical schema, which may be slightly different – then we’re mixing physical schema and logical schema together (e.g. class names may not be the same as table names, property names may not be the same as column names, there may be additional computed columns, the user may not have selected the pkey columns – should we add them automatically?, etc.). Granted that in many cases, these would be virtually identical, but we can’t guarantee it and have to be able to handle the general case. Maybe we just reverse engineer a class definition from the selected data and not try to match up any existing FDO class? We would have to handle this anyway since a select may not match up at all with an existing class, such as selecting from a table with an owner that is different from the connected data store (e.g. connect to data store called Denver and select from Boulder.Roads – the schema may or may not be similar to Denver.Roads. Even worse, what happens if the user turns around and tries to update one of the returned objects – they’d have to get back to Boulder.Roads and not just try to update the FDO Roads feature class. So, this would have to be a different feature class.) It sounds like we’d manufacture a new class definition unless we could determine with certainty that the select is on a table that matches one of the already defined fdo classes. (An interesting case is “select r.* from roads r where r.length > 50”.)
     36
     37Therefore, in cases where the resulting columns come from an existing FDO feature table, a provider can return the !FdoClassDefinition corresponding to that table. In cases where the columns come from an unknown table, a class definition can be constructed on the fly. By definition, the FDO class definition returned by an FdoIFeatureReader does not necessarily correspond exactly to an existing FDO class even in existing providers. This is due to the fact that it may only contains the properties that were asked for in the Select command, plus additional computed properties. It is perfectly legal to return a constructed class definition, which is only valid for the select that was executed, and not usable for further updates or inserts.
     38
     39So following up on the above discussion, providers that return feature readers from SQLCommands will need to come up with the appropriate class definition that the feature reader could expose.
     40
     41Here are a few use cases:
     42
     43    - Select is against a table that has an existing class definition and the select returns the same information as defined by the class definition (e.g. select * from roads).
     44    - Select is against a table that has an existing class definition, but the select returns other information such as a subset of properties or additional computed properties. The FDO select command handles this type of case as well. The class definition returned by the feature reader includes the specific properties for that select.
     45    - Select is against a table that doesn’t have an existing class definition. We’ll have to generate a temporary class definition.
     46    - Select is against a table that has an existing class definition, but the select is an aggregation that doesn’t return actual objects (e.g. select count(*), max(length) from roads). In this case it doesn’t make sense to return the same class name as for the underlying table since we’re not actually returning road objects at all. This is basically another temporary class definition.
    2947
    3048
