Changes between Version 26 and Version 27 of FDORfc33
04/15/09 12:43:03 (16 years ago)
gregboone
  • TabularUnified FDORfc33
    v26 v27
    2929In general, the intent of SQL pass-through is to deal with physical schemas. There is no parsing of the SQL statements, and what is identified are physical schema tables, columns, functions, commands, etc. The SQL statement can be any SQL command, not just select, but any DML (select, insert, update, delete) or any DDL (create, drop, alter, …). However, FDO feature readers deal with FDO logical schemas, which is at a different conceptual level. It’s mixing these levels that causes difficulty for applications using the FDO API. Applications are required to use different code pathways to handle select statement as opposed to direct SQL execution. If clients could use the result of both these types of operations in a generic routine or component, such as a Data Table or Symbolization packages, applications would be provided a much more seamless and dynamic mechanism on which they can build and extend their applications.
    3030
    31 To a certain degree, the FDO feature reader assumes an FDO class definition is directly related to the properties being returned. With physical schema SQL (let’s say just Select command), there isn’t necessarily any FDO class definition that applies. This is why currently the SQL command's Execute method returns a data reader, which handles any generically returned data. Note that the FDO select aggregates command doesn’t return a feature reader either, since it’s returning computed data.
     31To a certain degree, the current FDO feature reader implementation assumes an FDO class definition is directly related to the properties being returned. With physical schema SQL (let’s say just Select command), there isn’t necessarily any FDO class definition that applies. This is why currently the SQL command's Execute method returns a data reader, which handles any generically returned data. Note that the FDO select aggregates command doesn’t return a feature reader either, since it’s returning computed data.
    3232
    33 We can break down the SQL pass through selects into a couple of categories. One category would be selecting data that really isn’t related to any of the FDO schema classes, e.g. selecting from system tables or views.
     33One response to this issue has been to suggest that providers reverse engineer the select results and attempt to find the FDO class definition (coming from a describe schema request) that matches it. Other suggestions have been to construct a class definition on the fly, one that would not result from a call to describe schema. If the select is from a single table, providers would find the class definition that is based on that table and use it. However, then matching up the columns being selected with the properties in the logical schema, there may be some slight differences. This would result in the mixing of physical schema and logical schema elements together. For example, class names that are not the same as table names, property names that are not the same as column names, the use of additional computed columns, inclusion of pkey columns, etc. Granted that in many cases, the logical and physical views would be virtually identical. However, since that cannot be guaranteed, the design that is adopted will have to be able to handle the general case.
    3434
    35     - Select from Oracle’s mdsys.cs_srs table.
    36     - Select from SQL Server’s sys.indexes
     35To account for these scenarios, providers will need to be modified to reverse engineer class definitions from the selected data and not attempt to match the select request to an existing FDO class. IN reality, FDO Providers will be required to handle this in any case since a generic SQL select may not match up at all with an existing FDO class. An example of this can be found when selecting from a table with an owner that is different from the connected data store. For example, Connect to data store called Denver and select from Boulder.Roads – the schema may or may not be similar to Denver.Roads. In these types of circumstances, providers should manufacture a new class definition unless they could determine with certainty that the select is on a table that matches one of the already defined FDO classes.
    3736
    38 Even if we consider cases where the select is from a table that contains feature or feature related data, FDO does not provide a mechanism for returning some form of a class representation that identifies that feature data and makes operating on that data consistently with other feature data.
    39
    40 One suggestion has been to reverse engineer the select results and attempt to find the FDO class definition (coming from a describe schema request) that matches it. Other suggestions have been to construct a class definition on the fly, one that would not result from a call to describe schema. If the select is from a single table, providers could find the class definition that is based on that table and use it. However, then matching up the columns being selected with the properties in the logical schema, there may be some slight differences. This would result in the mixing of physical schema and logical schema elements together. For example, class names that are not the same as table names, property names that are not the same as column names, the use of additional computed columns, inclusion of pkey columns, etc. Granted that in many cases, the logical and physical views would be virtually identical. However, since that cannot be guaranteed, the design that is adopted will have to be able to handle the general case.
    41
    42 To adjust for the these scenarios, providers should be modified to reverse engineer a class definition from the selected data and not attempt to match the select request to an existing FDO class. FDO Providers would be required to handle this in any case since an SQL select may not match up at all with an existing class, such as selecting from a table with an owner that is different from the connected data store. For example, Connect to data store called Denver and select from Boulder.Roads – the schema may or may not be similar to Denver.Roads. Providers should manufacture a new class definition unless they could determine with certainty that the select is on a table that matches one of the already defined FDO classes.
    43
    44 Therefore, in cases where the resulting columns come from an existing FDO feature table, a provider can return the class definition corresponding to that table. In cases where the columns come from an unknown table, a class definition can be constructed on the fly. By definition, the FDO class definition returned by a feature reader does not necessarily correspond exactly to an existing FDO class definition. Existing class definitions may contain the properties that were asked for in the Select command, plus additional computed properties. It is perfectly legal to return a constructed class definition, which is only valid for the select that was executed, and not usable for further updates or inserts.
     37In cases where the resulting columns come from an existing FDO feature table, a provider can return the class definition corresponding to that table. In cases where the columns come from an unknown table, a class definition can be constructed on the fly. By definition, the FDO class definition returned by a feature reader does not necessarily correspond exactly to an existing FDO class definition. Existing class definitions may contain the properties that were asked for in the Select command, plus additional computed properties. It is perfectly legal to return a constructed class definition, which is only valid for the select that was executed, and not usable for further updates or inserts.
    4538
    4639In the circumstance that a computed class is generated, the FDO class definition’s !IsComputed property will return true. In that manner, applications are able to distinguish the content of the feature reader responses coming from the providers and tailor their implementations accordingly. In such a situation, some care will also need to be given to the name of the generated schema and classes. At this point there is no standards exist. It would be beneficial if as a result of this RFC, some uniform conventions could be adopted.
