Changes between Version 9 and Version 10 of FDORfc10
08/31/07 01:30:58 (17 years ago)
klain
  • FDORfc10
    v9 v10
    5050WMS Override API will accept a string instead of the enumeration for image format. It will only accept server defined format strings that contain ‘png’, ‘tiff’, ‘jpeg’ or ‘gif’ in their definitions.
    5151
    52 For example, by calling {{{SetImageFormat("image/png; PhotometricInterpretation=PaletteColor")}}}, WMS Provider will return raster stream in palette model. And by calling {{{SetImageFormat("image/png; PhotometricInterpretation=RGB")}}}, the raster stream will be returned in RGB model. In this way, WMS Provider could fully make use of the server capability to support different bit-depth.
    53 These additional parameters will go into the configuration file like:
     52For example, by calling {{{SetImageFormat("image/png; PhotometricInterpretation=PaletteColor")}}}, WMS Provider will return raster stream in palette model. And by calling {{{SetImageFormat("image/png; PhotometricInterpretation=RGB")}}}, the raster stream will be returned in RGB model.
     53
     54In this way, WMS Provider could fully make use of the server capability to support different bit-depth. These additional parameters will go into the configuration file like:
    5455{{{
    5556<RasterDefinition name="Image">
