| 1 | [[PageOutline]] |
| 2 | |
| 3 | This page is an FDO Code Snippet. Visit the CodeSnippets page to view more! |
| 4 | |
| 5 | = Calculating Static Extents = |
| 6 | |
| 7 | Some providers require that you perform a !SelectAggregates on a dataset to determine its extents, specifiying the !SpatialExtents function as one of the properties to calculate. |
| 8 | |
| 9 | == C++ Example == |
| 10 | |
| 11 | {{{ |
| 12 | #!cpp |
| 13 | |
| 14 | FdoPtr<FdoISelectAggregates> agg = (FdoISelectAggregates*)con->CreateCommand(FdoCommandType_SelectAggregates); |
| 15 | agg->SetFeatureClassName(L"MyFeatureClass"); |
| 16 | FdoPtr<FdoIdentifierCollection> props = agg->GetPropertyNames(); |
| 17 | |
| 18 | FdoPtr<FdoExpression> exp = FdoExpression::Parse(L"SpatialExtents(GEOMETRY)"); |
| 19 | FdoPtr<FdoComputedIdentifier> se = FdoComputedIdentifier::Create(L"Extents", exp); |
| 20 | props->Add(se); |
| 21 | |
| 22 | FdoPtr<FdoIDataReader> extrdr = agg->Execute(); |
| 23 | extrdr->ReadNext(); |
| 24 | |
| 25 | FdoPtr<FdoByteArray> ba = extrdr->GetGeometry(L"Extents"); |
| 26 | //ba contains the extents polygon, in FGF array form, use FdoIGeometry APIs to get the numbers out of it. |
| 27 | |
| 28 | }}} |
| 29 | |
| 30 | == C# Example == |
| 31 | |
| 32 | {{{ |
| 33 | #!cpp |
| 34 | |
| 35 | public IPolygon GetExtents() |
| 36 | { |
| 37 | IPolygon retpolygon; |
| 38 | ISelectAggregates pselagree = (ISelectAggregates)FDOConnection.CreateCommand(CommandType.CommandType_SelectAggregates); |
| 39 | |
| 40 | pselagree.SetFeatureClassName(System.IO.Path.GetFileNameWithoutExtension(OpenedFile)); |
| 41 | IFeatureReader FDOReader = pselagree.Execute(); |
| 42 | FgfGeometryFactory GeoFac = new FgfGeometryFactory(); |
| 43 | |
| 44 | Byte[] Tmppts = FDOReader.GetGeometry("Geometry"); |
| 45 | |
| 46 | IGeometry Geo = GeoFac.CreateGeometryFromFgf(Tmppts); |
| 47 | |
| 48 | retpolygon = (IPolygon)Geo; |
| 49 | |
| 50 | return retpolygon; |
| 51 | |
| 52 | } |
| 53 | |
| 54 | }}} |
| 55 | |
| 56 | |
| 57 | == Contributors == |
| 58 | |
| 59 | * Traian Stanev |
| 60 | * Shaik Esu |
| 61 | |
