Changes between Version 2 and Version 3 of TracInterfaceCustomization
- Feb 1, 2017, 12:33:48 AM (7 years ago)
v2 v3 1 = Customizing the Trac Interface =1 = Customizing the Trac Interface 2 2 [[TracGuideToc]] 3 [[PageOutline ]]3 [[PageOutline(2-5,Contents,pullout)]] 4 4 5 == Introduction ==6 5 This page gives suggestions on how to customize the look of Trac. Topics include editing the HTML templates and CSS files, but not the program code itself. The topics show users how they can modify the look of Trac to meet their specific needs. Suggestions for changes to Trac's interface applicable to all users should be filed as tickets, not listed on this page. 7 6 8 == Project Logo and Icon ==7 == Project Logo and Icon 9 8 The easiest parts of the Trac interface to customize are the logo and the site icon. Both of these can be configured with settings in [wiki:TracIni trac.ini]. 10 9 11 10 The logo or icon image should be put in a folder named "htdocs" in your project's environment folder. ''Note: in projects created with a Trac version prior to 0.9 you will need to create this folder''. 12 11 13 ''Note: you can actually put the logo and icon anywhere on your server (as long as it's accessible through the web server), and use their absolute or server-relative URLs in the configuration.'' 12 '''Note''': you can actually put the logo and icon anywhere on your server (as long as it's accessible through the web server), and use their absolute or server-relative URLs in the configuration. 14 13 15 14 Now configure the appropriate section of your [wiki:TracIni trac.ini]: 16 15 17 === Logo ===18 Change the `src` setting to `site/` followed by the name of your image file. The `width` and `height` settings should be modified to match your image's dimensions. The Trac chrome handler uses "`site/`" for files within the project directory `htdocs`, and "`common/`"for the common `htdocs` directory belonging to a Trac installation. Note that 'site/' is not a placeholder for your project name, it is the literal prefix that should be used. For example, if your project is named 'sandbox', and the image file is 'red_logo.gif' then the 'src' setting would be 'site/red_logo.gif', not 'sandbox/red_logo.gif'.16 === Logo 17 Change the `src` setting to `site/` followed by the name of your image file. The `width` and `height` settings should be modified to match your image's dimensions. The Trac chrome handler uses `site/` for files within the project directory `htdocs`, and `common/` for the common `htdocs` directory belonging to a Trac installation. Note that 'site/' is not a placeholder for your project name, it is the literal prefix that should be used. For example, if your project is named 'sandbox', and the image file is 'red_logo.gif' then the 'src' setting would be 'site/red_logo.gif', not 'sandbox/red_logo.gif'. 19 18 20 {{{ 19 {{{#!ini 21 20 [header_logo] 22 21 src = site/my_logo.gif … … 26 25 }}} 27 26 28 === Icon ===27 === Icon 29 28 Icons are small images displayed by your web browser next to the site's URL and in the `Bookmarks` menu. Icons should be a 32x32 image in `.gif` or `.ico` format. Change the `icon` setting to `site/` followed by the name of your icon file: 30 29 31 {{{ 30 {{{#!ini 32 31 [project] 33 32 icon = site/my_icon.ico 34 33 }}} 35 34 36 Note that this icon is ignored by Internet Explorer, which only accepts a file named `favicon.ico` at the root of the host. To make the project icon work in IE as well as other browsers, you can store the icon in the document root of the host and then reference it from `trac.ini` as follows: 37 38 {{{ 39 [project] 40 icon = /favicon.ico 41 }}} 42 43 If your browser does not show your favicon in the address bar, append a "?" to the file extension: 44 45 {{{ 46 [project] 47 icon = /favicon.ico? 48 }}} 49 50 == Custom Navigation Entries == 35 == Custom Navigation Entries 51 36 The new [mainnav] and [metanav] can now be used to customize the text and link used for the navigation items, or even to disable them, but not for adding new ones. 52 37 53 38 In the following example, we rename the link to the Wiki start "Home", and hide the "!Help/Guide". We also make the "View Tickets" entry link to a specific report: 54 {{{ 39 {{{#!ini 55 40 [mainnav] 56 41 wiki.label = Home … … 63 48 See also TracNavigation for a more detailed explanation of the mainnav and metanav terms. 64 49 65 == Site Appearance ==#SiteAppearance50 == Site Appearance #SiteAppearance 66 51 67 Trac is using [http://genshi.edgewall.org Genshi] as the templating engine. Say you want to add a link to a custom stylesheet, and then your own header and footer. Save the following content as `site.html` inside your projects `templates/` directory (each Trac project can have their own `site.html`), eg {{{/path/to/env/templates/site.html}}}:52 Trac is using [http://genshi.edgewall.org Genshi] as the templating engine. Say you want to add a link to a custom stylesheet, and then your own header and footer. Save the following content as `site.html` inside your projects `templates/` directory (each Trac project can have their own `site.html`), eg `/path/to/env/templates/site.html`: 68 53 69 {{{ 70 #!xml 54 {{{#!xml 71 55 <html xmlns="http://www.w3.org/1999/xhtml" 72 56 xmlns:py="http://genshi.edgewall.org/" … … 105 89 {{{#!xml 106 90 <form py:match="div[@id='content' and @class='ticket']/form" py:attrs="select('@*')"> 107 <py:if test="req. environ['PATH_INFO']== '/newticket' and (not 'preview' in req.args)">91 <py:if test="req.path_info == '/newticket' and (not 'preview' in req.args)"> 108 92 <p>Please make sure to search for existing tickets before reporting a new one!</p> 109 93 </py:if> … … 112 96 }}} 113 97 114 This example illustrates a technique of using `req. environ['PATH_INFO']` to limit scope of changes to one view only. For instance, to make changes in `site.html` only for timeline and avoid modifying other sections - use `req.environ['PATH_INFO']== '/timeline'` condition in `<py:if>` test.98 This example illustrates a technique of using `req.path_info` to limit scope of changes to one view only. For instance, to make changes in `site.html` only for timeline and avoid modifying other sections - use `req.path_info == '/timeline'` condition in `<py:if>` test. 115 99 116 100 More examples snippets for `site.html` can be found at [trac:wiki:CookBook/SiteHtml CookBook/SiteHtml]. … … 118 102 Example snippets for `style.css` can be found at [trac:wiki:CookBook/SiteStyleCss CookBook/SiteStyleCss]. 119 103 120 If the environment is upgraded from 0.10 and a `site_newticket.cs` file already exists, it can be loaded using a workaround - providing it contains no [trac:ClearSilver] processing. In addition, as only one element can be imported, the content needs some sort of wrapper such as a `<div>` block or other similar parent container. The XInclude namespace must be specified to allow includes, but that can be moved to document root along with the others: 121 {{{ 122 #!xml 123 <form py:match="div[@id='content' and @class='ticket']/form" py:attrs="select('@*')" 124 xmlns:xi="http://www.w3.org/2001/XInclude"> 125 <py:if test="req.environ['PATH_INFO'] == '/newticket' and (not 'preview' in req.args)"> 126 <xi:include href="site_newticket.cs"><xi:fallback /></xi:include> 127 </py:if> 128 ${select('*')} 129 </form> 130 }}} 104 Note that the `site.html`, despite its name, can be put in a shared templates directory, see the [[TracIni#inherit-section|[inherit] templates_dir]] option. This could provide easier maintainence as one new global `site.html` file can be made to include any existing header, footer and newticket snippets. 131 105 132 Also note that the `site.html`, despite its name, can be put in a shared templates directory, see the [[TracIni#inherit-section|[inherit] templates_dir]] option. This could provide easier maintainence (and a migration path from 0.10 for larger installations) as one new global `site.html` file can be made to include any existing header, footer and newticket snippets. 106 == Project List #ProjectList 133 107 134 == Project List == #ProjectList 135 136 You can use a custom Genshi template to display the list of projects if you are using Trac with multiple projects. 108 You can use a custom Genshi template to display the list of projects if you are using Trac with multiple projects. 137 109 138 110 The following is the basic template used by Trac to display a list of links to the projects. For projects that could not be loaded, it displays an error message. You can use this as a starting point for your own index template: 139 111 140 {{{ 141 #!text/html 112 {{{#!text/html 142 113 <!DOCTYPE html 143 114 PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" … … 164 135 }}} 165 136 166 Once you've created your custom template you will need to configure the webserver to tell Trac where the template is located (pls verify ... not yet changed to 0.11):137 Once you've created your custom template you will need to configure the webserver to tell Trac where the template is located: 167 138 168 139 For [wiki:TracModWSGI mod_wsgi]: 169 {{{ 140 {{{#!python 170 141 os.environ['TRAC_ENV_INDEX_TEMPLATE'] = '/path/to/template.html' 171 142 }}} 172 143 173 144 For [wiki:TracFastCgi FastCGI]: 174 {{{ 145 {{{#!apache 175 146 FastCgiConfig -initial-env TRAC_ENV_PARENT_DIR=/parent/dir/of/projects \ 176 147 -initial-env TRAC_ENV_INDEX_TEMPLATE=/path/to/template … … 178 149 179 150 For [wiki:TracModPython mod_python]: 180 {{{ 151 {{{#!apache 181 152 PythonOption TracEnvParentDir /parent/dir/of/projects 182 153 PythonOption TracEnvIndexTemplate /path/to/template … … 184 155 185 156 For [wiki:TracCgi CGI]: 186 {{{ 157 {{{#!apache 187 158 SetEnv TRAC_ENV_INDEX_TEMPLATE /path/to/template 188 159 }}} 189 160 190 161 For [wiki:TracStandalone], you'll need to set up the `TRAC_ENV_INDEX_TEMPLATE` environment variable in the shell used to launch tracd: 191 - Unix 192 {{{ 193 #!sh 162 - Unix: 163 {{{#!sh 194 164 $ export TRAC_ENV_INDEX_TEMPLATE=/path/to/template 195 165 }}} 196 - Windows 197 {{{ 198 #!sh 166 - Windows: 167 {{{#!sh 199 168 $ set TRAC_ENV_INDEX_TEMPLATE=/path/to/template 200 169 }}} 201 170 202 == Project Templates ==171 == Project Templates 203 172 204 The appearance of each individual Trac environment, ie instance of a project, can be customized independently of other projects, even those hosted on the same server. The recommended way is to use a `site.html` template (see [#SiteAppearance]) whenever possible. Using `site.html` means changes are made to the original templates as they are rendered, and you should not normally need to redo modifications whenever Trac is upgraded. If you do make a copy of `theme.html` or any other Trac template, you need to migrate your modifiations to the newer version. If not, new Trac features or bug fixes may not work as expected.173 The appearance of each individual Trac environment, ie instance of a project, can be customized independently of other projects, even those hosted on the same server. The recommended way is to use a `site.html` template whenever possible, see [#SiteAppearance]. Using `site.html` means changes are made to the original templates as they are rendered, and you should not normally need to redo modifications whenever Trac is upgraded. If you do make a copy of `theme.html` or any other Trac template, you need to migrate your modifiations to the newer version. If not, new Trac features or bug fixes may not work as expected. 205 174 206 With that word of caution, any Trac template may be copied and customized. The default Trac templates are located inside the installed Trac egg (`/usr/lib/pythonVERSION/site-packages/Trac-VERSION.egg/trac/templates, .../trac/ticket/templates, .../trac/wiki/templates, ++`). The [#ProjectList] template file is called `index.html`, while the template responsible for main layout is called `theme.html`. Page assets such as images and CSS style sheets are located in the egg's `trac/htdocs` directory.175 With that word of caution, any Trac template may be copied and customized. The default Trac templates are located inside the installed Trac egg, such as `/usr/lib/pythonVERSION/site-packages/Trac-VERSION.egg/trac/templates, ../trac/ticket/templates, ../trac/wiki/templates`. The [#ProjectList] template file is called `index.html`, while the template responsible for main layout is called `theme.html`. Page assets such as images and CSS style sheets are located in the egg's `trac/htdocs` directory. 207 176 208 177 However, do not edit templates or site resources inside the Trac egg. Reinstalling Trac overwrites your modifications. Instead use one of these alternatives: 209 178 * For a modification to one project only, copy the template to project `templates` directory. 210 * For a modification shared by several projects, copy the template to a shared location and have each project point to this location using the `[inherit] templates_dir =` trac.ini option.179 * For a modification shared by several projects, copy the template to a shared location and have each project point to this location using the `[inherit] templates_dir` trac.ini option. 211 180 212 181 Trac resolves requests for a template by first looking inside the project, then in any inherited templates location, and finally inside the Trac egg. 213 182 214 Trac caches templates in memory by default to improve performance. To apply a template you need to restart the server.183 Trac caches templates in memory by default to improve performance. To apply a template you need to restart the web server. 215 184 216 185 ----
