Changes between Version 1 and Version 2 of TracImport
- Apr 22, 2015, 3:40:29 PM (9 years ago)
TracImport
v1 v2 1 1 = Importing ticket data = 2 [[PageOutline]] 3 4 To migrate issue tickets from other issue-tracking systems or perform housekeeping actions on tickets or simply synchronize different databases, there are some tools, plug-ins and scripts available, which let you import or update tickets into Trac. 5 6 == !TicketImportPlugin == 7 8 [http://trac-hacks.org/wiki/TicketImportPlugin TicketImportPlugin]: this plug-in lets you import or update into Trac a series of tickets from a '''CSV file''' or (if the [http://pypi.python.org/pypi/xlrd xlrd library] is installed) from an '''Excel spreadsheet'''. 9 10 == !ExportImportXlsPlugin == 11 12 [http://trac-hacks.org/wiki/ExportImportXlsPlugin ExportImportXlsPlugin]: this plug-in adds an admin panel for exporting and importing tickets via '''XLS file'''. Requires the python packages xlwt/rxld. 2 13 3 14 == Bugzilla == 4 15 5 Ticket data can be imported from Bugzilla using the [http://trac.edgewall.org/browser/trunk/contrib/bugzilla2trac.py bugzilla2trac.py] script, available in the contrib/ directory of the Trac distribution.16 [http://trac-hacks.org/wiki/BugzillaIssueTrackingPlugin BugzillaIssueTrackingPlugin]: integrates Bugzilla issue data into Trac keeping TracLinks. Ticket data can be imported from Bugzilla using the [trac:browser:trunk/contrib/bugzilla2trac.py bugzilla2trac.py] script, available in the contrib/ directory of the Trac distribution. 6 17 7 18 {{{ … … 24 35 25 36 Currently, the following data is imported from Bugzilla: 26 27 37 * bugs 28 38 * bug activity (field changes) … … 31 41 32 42 The script provides a number of features to ease the conversion, such as: 33 34 * PRODUCT_KEYWORDS: Trac doesn't have the concept of products, so the script provides the ability to attach a ticket keyword instead. 35 36 * IGNORE_COMMENTS: Don't import Bugzilla comments that match a certain regexp. 37 38 * STATUS_KEYWORDS: Attach ticket keywords for the Bugzilla statuses not available in Trac. By default, the 'VERIFIED' and 'RELEASED' Bugzilla statuses are translated into Trac keywords. 43 * PRODUCT_KEYWORDS: Trac has no concept of products, so the script provides the ability to attach a ticket keyword instead. 44 * IGNORE_COMMENTS: Don't import Bugzilla comments that match a certain regexp. 45 * STATUS_KEYWORDS: Attach ticket keywords for the Bugzilla statuses not available in Trac. By default, the 'VERIFIED' and 'RELEASED' Bugzilla statuses are translated into Trac keywords. 39 46 40 47 For more details on the available options, see the configuration section at the top of the script. 41 48 42 == Sourceforge == 49 === Known Issues === 50 {{{ 51 #!comment 52 Don't merge this section in the default page 53 }}} 54 [[TicketQuery(keywords=~bugzilla,status=!closed)]] 43 55 44 Ticket data can be imported from Sourceforge using the [http://trac.edgewall.org/browser/trunk/contrib/sourceforge2trac.py sourceforge2trac.py] script, available in the contrib/ directory of the Trac distribution. 56 The adequate milestone for valid bugzilla2trac issue is usually ''Not applicable'', which means that fixes to the contributed script are not planned for a particular Trac release, but can happen anytime. 57 58 == Jira == 59 60 [http://trac-hacks.org/wiki/JiraToTracIntegration JiraToTracIntegration]: provides tools to import Atlassian Jira backup files into Trac. The plug-in consists of a Python 3.1 commandline tool that: 61 - Parses the Jira backup XML file. 62 - Sends the imported Jira data and attachments to Trac using the [http://trac-hacks.org/wiki/XmlRpcPlugin XmlRpcPlugin]. 63 - Generates a htpasswd file containing the imported Jira users and their SHA-512 base64 encoded passwords. 45 64 46 65 == Mantis == 47 66 48 NB! The mantis2trac script now lives at http://trac-hacks.org/wiki/MantisImportScript . You can always get the latest version from http://trac-hacks.org/changeset/latest/mantisimportscript?old_path=/&filename=mantisimportscript&format=zip 49 50 Mantis bugs can be imported using the attached script. 51 52 Currently, the following data is imported from Mantis: 67 [http://trac-hacks.org/wiki/MantisImportScript MantisImportScript]: script to import the following data from Mantis into Trac: 53 68 * bugs 54 69 * bug comments 55 70 * bug activity (field changes) 56 * attachments (as long as the files live in the mantis db, not on the filesystem) 71 * attachments (as long as the files live in the mantis db, not on the filesystem) . 57 72 58 If you use the script, please read the NOTES section (at the top of the file) and make sure you adjust the config parameters for your environment. 73 == !PlanetForge == 59 74 60 mantis2trac.py has the same parameters as the bugzilla2trac.py script: 61 {{{ 62 mantis2trac - Imports a bug database from Mantis into Trac. 75 [http://trac-hacks.org/wiki/PlanetForgeImportExportPlugin PlanetForgeImportExportPlugin]: this plugin exports Trac data (wiki, tickets, compoments, permissions, repositories, etc.) using the open format designed by the COCLICO project. It extends the webadmin panel and the 'trac admin ...' command. Has no 'import' feature. 63 76 64 Usage: mantis2trac.py [options] 77 == Scarab == 65 78 66 Available Options: 67 --db <MySQL dbname> - Mantis database 68 --tracenv /path/to/trac/env - Full path to Trac db environment 69 -h | --host <MySQL hostname> - Mantis DNS host name 70 -u | --user <MySQL username> - Effective Mantis database user 71 -p | --passwd <MySQL password> - Mantis database user password 72 -c | --clean - Remove current Trac tickets before importing 73 --help | help - This help info 79 [http://trac-hacks.org/wiki/ScarabToTracScript ScarabToTracScript]: script that migrates Scarab issues to Trac tickets. Requires [http://trac-hacks.org/wiki/XmlRpcPlugin XmlRpcPlugin] 74 80 75 Additional configuration options can be defined directly in the script. 76 }}} 81 == Sourceforge == 82 83 [http://trac-hacks.org/wiki/SfnToTracScript SfnToTracScript]: importer of !SourceForge's new backup file (originated from #Trac3521). 84 Also, ticket data can be imported from Sourceforge using the [trac:browser:trunk/contrib/sourceforge2trac.py sourceforge2trac.py] script, available in the contrib/ directory of the Trac distribution. 77 85 78 86 == Other == 79 87 80 Since trac uses a SQL database to store the data, you can import from other systems by examining the database tables. Just go into [http://www.sqlite.org/sqlite.html sqlite] command line to look at the tables and import intothem from your application.88 Since Trac uses a SQL database to store the data, you can also custom-import from other systems by examining the database tables. Just go into [http://www.sqlite.org/sqlite.html sqlite] command line to look at the tables and import them from your application. 81 89 82 === Using a comma delimited file - CSV === 83 See [http://trac.edgewall.org/attachment/wiki/TracSynchronize/csv2trac.2.py] for details. This approach is particularly useful if one needs to enter a large number of tickets by hand. (note that the ticket type type field, (task etc...) is also needed for this script to work with more recent Trac releases) 90 === Comma delimited file - CSV === 91 See [trac:attachment:csv2trac.2.py:wiki:TracSynchronize csv2trac.2.py] for details. This approach is particularly useful if you need to enter a large number of tickets by hand. Note that the ticket type type field, (task etc...) is also needed for this script to work with more recent Trac releases. 92 Comments on script: The script has an error on line 168: 'Ticket' needs to be 'ticket'. Also, the listed values for severity and priority are swapped. 84 93 94 ---- 95 See also: 96 * to import/export wiki pages: TracAdmin, 97 * to export tickets: TracTickets, TracQuery
