Changes between Version 1 and Version 2 of TracChangeset
- Apr 22, 2015, 3:40:29 PM (9 years ago)
TracChangeset
v1 v2 2 2 [[TracGuideToc]] 3 3 4 Trac has a built-in functionality for visualizing “diffs” -changes to files.4 Trac has a built-in functionality for visualizing “diffs”, or changes to files. 5 5 6 There are different kinds of ''change sets''. 7 Some can correspond to revisions made in the repositories, 8 others can aggregate changes made in several revisions, 9 but in the end, any kind of differences can be shown. 6 There are different kinds of ''change sets''. Some correspond to revisions made in the repositories, others aggregate changes made in several revisions. Ultimately, any kind of difference can be shown. 10 7 11 The changeset view consists of two parts, the ''header'' 12 and the ''diff views''. 8 The changeset view consists of two parts, the ''header'' and the ''diff views''. 13 9 14 10 == Changeset Header == … … 17 13 Here you will find information such as: 18 14 19 * Timestamp -- When the changeset was commited 20 * Author -- Who commited the changeset 21 * Message -- A brief description from the author (the commit log message) 22 * Files -- A list of files affected by this changeset 15 * Timestamp — When the changeset was commited 16 * Author — Who commited the changeset 17 * Message — A brief description from the author (the commit log message) 18 * Location — Parent directory of all files affected by this changeset 19 * Files — A list of files affected by this changeset 23 20 24 If more than one revision is involved in the set of changes being 25 displayed, the ''Timestamp'', ''Author'' and ''Message'' fields 26 won't be shown. 21 If more than one revision is involved in the set of changes being displayed, the ''Timestamp'', ''Author'' and ''Message'' fields will not be shown. 27 22 28 In front of each listed file, you'll find a colored rectangle. The color 29 indicates how the file is affected by the changeset. 23 A colored rectangle indicates how the file is affected by the changeset: 30 24 31 * Green: Added 32 * Red: Removed 33 * Yellow: Modified 34 * Blue: Copied 35 * Gray: Moved 36 25 [[span(style=background:#bfb;border:1px solid #999;font-size:80%;margin-right:.5em,'' '')]] Green: Added \\ 26 [[span(style=background:#f88;border:1px solid #999;font-size:80%;margin-right:.5em,'' '')]] Red: Removed \\ 27 [[span(style=background:#fd8;border:1px solid #999;font-size:80%;margin-right:.5em,'' '')]] Yellow: Modified \\ 28 [[span(style=background:#88f;border:1px solid #999;font-size:80%;margin-right:.5em,'' '')]] Blue: Copied \\ 29 [[span(style=background:#ccc;border:1px solid #999;font-size:80%;margin-right:.5em,'' '')]] Gray: Moved \\ 37 30 The color legend is located below the header as a reminder. 38 31 39 32 == Diff Views == 40 33 41 Below the header is the main part of the changeset, the diff view. Each file is shown in a separate section, each of which will contain only the regions of the file that are affected by the changeset. There are two different styles of displaying the diffs: ''inline'' or ''side-by-side'' (you can switch between those styles using the preferences form):34 Below the header is the main part of the changeset, the diff view. Each file is shown in a separate section, each of which contains only the regions of the file that are affected by the changeset. There are two different styles to display the diffs: ''inline'' or ''side-by-side''. You can switch between the styles using the preferences form: 42 35 43 * The ''inline'' style shows the changed regions of a file underneath each other. A region removed from the file will be colored red, an added region will be colored green. If a region was modified, the old version is displayed above the new version. Line numbers on the left sideindicate the exact position of the change in both the old and the new version of the file.44 * The ''side-by-side'' style shows the old version on the left and the new version on the right (this will typically require more screen width than the inline style.) Added and removed regions will be colored in the same way as with the inline style (green and red, respectively), butmodified regions will have a yellow background.36 * The ''inline'' style shows the changed regions of a file underneath each other. A region removed from the file will be colored red, an added region will be colored green. If a region was modified, the old version is displayed above the new version. Line numbers indicate the exact position of the change in both the old and the new version of the file. 37 * The ''side-by-side'' style shows the old version on the left and the new version on the right and this will typically require more screen width than the inline style. Added and removed regions will be colored in the same way as with the inline style (green and red), and modified regions will have a yellow background. 45 38 46 39 In addition, various advanced options are available in the preferences form for adjusting the display of the diffs: 47 * You can set how many lines are displayed before and after every change 48 (if the value ''all'' is used, then the full file will be shown) 49 * You can toggle whether blank lines, case changes and white space changes are ignored, thereby letting you find the functional changes more quickly 50 40 * You can set how many lines are displayed before and after every change; if the value ''all'' is used, then the full file will be shown. 41 * You can toggle whether blank lines, case changes and white space changes are ignored, thereby letting you find the functional changes more quickly. 51 42 52 43 == The Different Ways to Get a Diff == … … 54 45 === Examining a Changeset === 55 46 56 When viewing a repository check-in, such as when following a 57 changeset [wiki:TracLinks link] or a changeset event in the 58 [wiki:TracTimeline timeline], Trac will display the exact changes 59 made by the check-in. 47 When viewing a repository check-in, such as when following a changeset [wiki:TracLinks link] or a changeset event in the [wiki:TracTimeline timeline], Trac will display the exact changes made by the check-in. 60 48 61 There will be also navigation links to the ''Previous Changeset'' 62 to and ''Next Changeset''. 49 There will be also navigation links to the ''Previous Changeset'' to and ''Next Changeset''. 63 50 64 51 === Examining Differences Between Revisions === 65 52 66 Often you'll want to look at changes made on a file 67 or on a directory spanning multiple revisions. The easiest way 68 to get there is from the TracRevisionLog, where you can select 69 the ''old'' and the ''new'' revisions of the file or directory, and 70 then click the ''View changes'' button. 53 Often you want to look at changes made on a file or on a directory spanning multiple revisions. The easiest way to get there is from the TracRevisionLog, where you can select the ''old'' and the ''new'' revisions of the file or directory, and then click the ''View changes'' button. 71 54 72 55 === Examining Differences Between Branches === 73 56 74 One of the core features of version control systems is the possibility 75 to work simultaneously on different ''Lines of Developments'', commonly 76 called “branches”. Trac enables you to examine the exact differences 77 between such branches. 57 One of the core features of version control systems is the possibility to work simultaneously on different ''Lines of Developments'', commonly called “branches”. Trac enables you to examine the exact differences between such branches. 78 58 79 Using the '''View changes ...''' button in the TracBrowser allows you to enter 80 ''From:'' and ''To:'' path/revision pairs. The resulting set of differences consist 81 of the changes that should be applied to the ''From:'' content in order 82 to get to the ''To:'' content. 59 Using the '''View changes ...''' button in the TracBrowser allows you to enter ''From:'' and ''To:'' path/revision pairs. The resulting set of differences consist of the changes that should be applied to the ''From:'' content to get to the ''To:'' content. 83 60 84 For convenience, it is possible to invert the roles of the ''old'' and the ''new'' 85 path/revision pairs by clicking the ''Reverse Diff'' link on the changeset page. 61 For convenience, it is possible to invert the roles of the ''old'' and the ''new'' path/revision pairs by clicking the ''Reverse Diff'' link on the changeset page. 86 62 87 63 === Checking the Last Change === 88 64 89 The last possibility for examining changes is to use the ''Last Change'' 90 link provided by the TracBrowser. 65 Another way to examine changes is to use the ''Last Change'' link provided by the TracBrowser. 91 66 92 This link will take you to the last change that was made on that path. 93 From there, you can use the ''Previous Change'' and ''Next Change'' links 94 to traverse the change history of the file or directory. 67 This link will take you to the last change that was made on that path. From there, you can use the ''Previous Change'' and ''Next Change'' links to traverse the change history of the file or directory. 95 68 96 69 ----
