Changes between Version 1 and Version 2 of WikiStart
05/15/08 20:38:37 (17 years ago)
warmerdam
preliminary content.
  • TabularUnified WikiStart
    v1 v2
    1 = Welcome to Trac 0.10.3.1 =
     1= CS-Map Tracker and Wiki =
    3 Trac is a '''minimalistic''' approach to '''web-based''' management of
    4 '''software projects'''. Its goal is to simplify effective tracking and handling of software issues, enhancements and overall progress.
     3This Trac instance is used for bug, enhancement & task tracking, and to some extent as a user and developer wiki.  To edit the wiki pages and bug/enhancement/task tickets you'll need to login with an [http://www.osgeo.org/osgeo_userid OSGeo Userid]. Read the TracGuide for details about how the site works.
    54
    6 All aspects of Trac have been designed with the single goal to
    7 '''help developers write great software''' while '''staying out of the way'''
    8 and imposing as little as possible on a team's established process and
    9 culture.
     5== Bug Tracking ==
    106
    11 As all Wiki pages, this page is editable, this means that you can
    12 modify the contents of this page simply by using your
    13 web-browser. Simply click on the "Edit this page" link at the bottom
    14 of the page. WikiFormatting will give you a detailed description of
    15 available Wiki formatting commands.
    16
    17 "[wiki:TracAdmin trac-admin] ''yourenvdir'' initenv" created
    18 a new Trac environment, containing a default set of wiki pages and some sample
    19 data. This newly created environment also contains
    20 [wiki:TracGuide documentation] to help you get started with your project.
    21
    22 You can use [wiki:TracAdmin trac-admin] to configure
    23 [http://trac.edgewall.org/ Trac] to better fit your project, especially in
    24 regard to ''components'', ''versions'' and ''milestones''.
    25
    27 TracGuide is a good place to start.
    28
    29 Enjoy! [[BR]]
    30 ''The Trac Team''
    31
    32 == Starting Points ==
    34  * TracGuide --  Built-in Documentation
    35  * [http://trac.edgewall.org/ The Trac project] -- Trac Open Source Project
    36  * [http://trac.edgewall.org/wiki/TracFaq Trac FAQ] -- Frequently Asked Questions
    37  * TracSupport --  Trac Support
    38
    39 For a complete list of local wiki pages, see TitleIndex.
     7 * [/csmap/newticket Submit a new bug report] (you need to [http://trac.osgeo.org/csmap/login login] with an [http://www.osgeo.org/osgeo_userid OSGeo Userid])
     8 * [query:status!=closed&type=defect&order=id&desc=1 List Open Bugs]
     9 * [query:status!=closed&type=enhancement&order=id&desc=1,compact List Open Enhancement Requests]
