Changes between Version 3 and Version 4 of TracWorkflow
May 8, 2022, 3:10:12 PM (17 months ago)
  • TracWorkflow
    v3 v4
    77== The Default Ticket Workflow
    88
    9 When a new environment is created, a default workflow is configured in your trac.ini. This workflow is the basic workflow, such as specified in [trac:source:/trunk/trac/ticket/workflows/basic-workflow.ini basic-workflow.ini]:
     9When a new environment is created, a default workflow is configured in your trac.ini. This workflow is the basic workflow, as specified in [trac:source:branches/1.4-stable/trac/ticket/workflows/basic-workflow.ini basic-workflow.ini]:
    1010
    1111{{{#!Workflow width=700 height=300
    4141== Additional Ticket Workflows
    4242
    43 There are example workflows provided in the Trac source tree, see [trac:source:trunk/contrib/workflow contrib/workflow] for `.ini` config sections. One of those may be a good match for what you want. They can be pasted into the `[ticket-workflow]` section of your `trac.ini` file. However, if you have existing tickets then there may be issues if those tickets have states that are not in the new workflow.
     43There are example workflows provided in the Trac source tree, see [trac:source:branches/1.4-stable/contrib/workflow contrib/workflow] for `.ini` config sections. One of those may be a good match for what you want. They can be pasted into the `[ticket-workflow]` section of your `trac.ini` file. However, if you have existing tickets then there may be issues if those tickets have states that are not in the new workflow.
    4444
    4545Here are some [trac:WorkFlow/Examples diagrams] of the above examples.
    4949'''Note''': Ticket "statuses" or "states" are not separately defined. The states a ticket can be in are automatically generated by the transitions defined in a workflow. Therefore, creating a new ticket state simply requires defining a state transition in the workflow that starts or ends with that state.
    5050
    51 Create a `[ticket-workflow]` section in `trac.ini`.
    52 Within this section, each entry is an action that may be taken on a ticket.
     51In the `[ticket-workflow]` section of `trac.ini`, each entry is an action that may be taken on a ticket.
    5352For example, consider the `accept` action from `simple-workflow.ini`:
    5453
    6059
    6160The first line in this example defines the `accept` action, along with the states the action is valid in (`new` and `accepted`), and the new state of the ticket when the action is taken (`accepted`).
    62 The `accept.permissions` line specifies what permissions the user must have to use this action.
    63 The `accept.operations` line specifies changes that will be made to the ticket in addition to the status change when this action is taken.  In this case, when a user clicks on `accept`, the ticket owner field is updated to the logged in user.  Multiple operations may be specified in a comma separated list.
     61
     62The `accept.permissions` line specifies the permissions the user must have to use this action. [trac:ExtraPermissionsProvider] can define new permissions to be used here.
     63
     64The `accept.operations` line specifies changes that will be made to the ticket in addition to the status change when the action is taken.  In this case, when a user clicks on `accept`, the ticket owner field is updated to the logged in user.  Multiple operations may be specified in a comma separated list.
    6465
    6566The available operations are:
    66 - **del_owner** -- Clear the owner field.
     67- **del_owner** -- Clears the owner field.
    6768- **set_owner** -- Sets the owner to the selected or entered owner. Defaults to the current user. When `[ticket] restrict_owner = true`, the select will be populated with users that have `TICKET_MODIFY` permission and an authenticated session.
    68  - ''actionname''`.set_owner` may optionally be set to a comma delimited list of users that will be used to populate the select, or a single user. Groups and permissions may also be included in the list //(Since 1.1.3)//. When groups or permissions are specified the select is populated with all members of the group or all users that possess the permission.
     69 - ''actionname''`.set_owner` may optionally specify a comma delimited list of users that will be used to populate the select, or a single user. Groups and permissions may also be included in the list //(Since 1.1.3)//. When groups or permissions are specified the select is populated with all members of the group or all users that possess the permission.
    6970- **set_owner_to_self** -- Sets the owner to the logged in user.
    70 - **may_set_owner** -- Sets the owner to the selected or entered owner. Defaults to the existing owner. //(Since 1.1.2)//.
     71- **may_set_owner** -- Sets the owner to the selected or entered owner. Defaults to the existing owner. //(Since 1.1.2)//.
    7172- **del_resolution** -- Clears the resolution field.
    7273- **set_resolution** -- Sets the resolution to the selected value.
    73  - ''actionname''`.set_resolution` may optionally be set to a comma delimited list or a single value. Example:
     74 - ''actionname''`.set_resolution` may optionally be set to a comma delimited list or a single value. The resolution(s) specified in this attribute must be defined in the database. Example:
    7475 {{{#!ini
    7576resolve_new = new -> closed
    8384'''Note:''' Specifying conflicting operations, such as `set_owner` and `del_owner`, has unspecified results.
    8485
    85 In this example, we see the `.label` attribute used. The action here is `resolve_accepted`, but it will be presented to the user as `resolve`:
     86The example that follows demonstrates the `.label` attribute. The action here is `resolve_accepted`, but it will be presented to the user as `resolve`.
    8687
    8788{{{#!ini
    9293}}}
    9394
    94 In this example, we see the `.label` attribute used.  The action here is `resolve_accepted`, but it will be presented to the user as `resolve`. The `.label` attribute is new in Trac 1.1.3 and is functionally the same as the `.name` attribute, which is now deprecated. If neither `.label` or `.name` is specified, the action will be presented to the user as //resolve accepted//, the underscores having been replaced by whitespace (//Since 1.1.3//).
     95The `.label` attribute is new in Trac 1.1.3 and is functionally the same as the `.name` attribute, which is now deprecated. If neither `.label` or `.name` is specified, the action will be presented to the user as //resolve accepted//, the underscores having been replaced by whitespace (//Since 1.1.3//).
    9596
    9697For actions that should be available in all states, `*` may be used in place of the state. The obvious example is the `leave` action:
    101102}}}
    102103
     104The transition to `*` (`-> *`) means the workflow operation determines the next status. The only configurable ticket workflow operation that determines the next status is `leave_status`. However, another workflow controller can operate on an action with new status `*` and determine the next status.
     105
    103106This also shows the use of the `.default` attribute. This value is expected to be an integer, and the order in which the actions are displayed is determined by this value. The action with the highest `.default` value is listed first, and is selected by default. The rest of the actions are listed in order of decreasing `.default` values.
    104107If not specified for an action, `.default` is 0. The value may be negative.
     108
     109There is one hard-coded constraint to the workflow: tickets are expected to have a `closed` state. The default reports/queries treat any state other than `closed` as an open state.
     110
     111=== Ticket Create Action
    105112
    106113The ticket create actions are specified by a transition from the special `<none>` state. At least one create action must be available to the user in order for tickets to be created. The create actions defined in the default workflow are:
    115122}}}
    116123
    117
    118 There is one hard-coded constraints to the workflow: tickets are expected to have a `closed` state. The default reports/queries treat any state other than `closed` as an open state.
     124=== Ticket Reset Action
    119125
    120126The special `_reset` action is added by default for tickets that are in states that are no longer defined. This allows tickets to be individually "repaired" after the workflow is changed, although it's recommended that the administrator perform the action by batch modifying the affected tickets. By default the `_reset` action is available to users with the `TICKET_ADMIN` permission and reset tickets are put in the //new// state. The default `_reset` action is equivalent to the following `[ticket-workflow]` action definition:
    142148Workflows can be visualized by rendering them on the wiki using the [WikiMacros#Workflow-macro Workflow macro].
    143149
    144 Workflows can also be visualized using the `contrib/workflow/workflow_parser.py` script. The script outputs `.dot` files that [http://www.graphviz.org GraphViz] understands. The script can be used as follows (your install path may be different):
     150Workflows can also be visualized using the `contrib/workflow/workflow_parser.py` script. The script outputs `.dot` files that [https://www.graphviz.org GraphViz] understands. The script can be used as follows (your install path may be different):
    145151
    146152{{{#!sh
    147 cd /var/local/trac_devel/contrib/workflow/
    148 sudo ./showworkflow /srv/trac/PlannerSuite/conf/trac.ini
    149 }}}
    150 And then open up the resulting `trac.pdf` file created by the script. It will be in the same directory as the `trac.ini` file.
    151
    152 After you have changed a workflow, you need to restart your webserver for the changes to take effect.
     153$ cd /var/local/trac_devel/contrib/workflow/
     154$ ./showworkflow /srv/trac/PlannerSuite/conf/trac.ini
     155}}}
     156The script outputs `trac.pdf` in the same directory as the `trac.ini` file.
    153157
    154158== Example: Adding optional Testing with Workflow
    155159
    156 By adding the following to your [ticket-workflow] section of trac.ini you get optional testing. When the ticket has status `new`, `accepted` or `needs_work`, you can choose to submit it for testing.  When it's in the testing status the user gets the option to reject it and send it back to `needs_work`, or pass the testing and send it along to `closed`. If they accept it, then it is automatically marked as `closed` and the resolution is set to `fixed`. Since all the old work flow remains, a ticket can skip this entire section.
     160The following adds a `testing` action. When the ticket has status `new`, `accepted` or `needs_work`, you can choose to submit it for testing.  When it's in the testing status the user gets the option to reject it and send it back to `needs_work`, or pass the testing and send it along to `closed`. If they accept it, then it is automatically marked as `closed` and the resolution is set to `fixed`. Since all the old work flow remains, a ticket can skip this entire section.
    157161
    158162{{{#!ini
    170174}}}
    171175
    172 === How to combine the `tracopt.ticket.commit_updater` with the testing workflow
    173
    174 The [[trac:source:trunk/tracopt/ticket/commit_updater.py|tracopt.ticket.commit_updater]] is the optional component that [[TracRepositoryAdmin#trac-post-commit-hook|replaces the old trac-post-commit-hook]], in Trac 0.12.
    175
    176 By default it reacts on some keywords found in changeset message logs like ''close'', ''fix'' etc. and performs the corresponding workflow action.
    177
    178 If you have a more complex workflow, like the testing stage described above and you want the ''closes'' keyword to move the ticket to the ''testing'' status instead of the ''closed'' status, you need to adapt the code a bit.
    179
    180 Have a look at the [[trac:wiki:0.11/TracWorkflow#How-ToCombineSVNtrac-post-commit-hookWithTestWorkflow|Trac 0.11 recipe]] for the `trac-post-commit-hook`, this will give you some ideas about how to modify the component.
    181
    182176== Example: Add simple optional generic review state
    183177
    192186}}}
    193187
    194 Then, to integrate this with the default Trac 0.11 workflow, you also need to add the `reviewing` state to the `accept` and `resolve` actions:
     188To integrate this with the default workflow, you also need to add the `reviewing` state to the `accept` and `resolve` actions:
    195189
    196190{{{#!ini
    205199reassign_reviewing = reviewing -> *
    206200reassign_reviewing.label = reassign review
    207 reassign_reviewing.operations = set_owner
     201reassign_reviewing.operations = set_owner, leave_status
    208202reassign_reviewing.permissions = TICKET_MODIFY
    209203}}}
    210204
    211 The full `[ticket-workflow]` configuration will thus look like this:
     205The full `[ticket-workflow]` configuration will be:
    212206
    213207{{{#!ini
    238232review.permissions = TICKET_MODIFY
    239233reassign_reviewing = reviewing -> *
    240 reassign_reviewing.operations = set_owner
     234reassign_reviewing.operations = set_owner, leave_status
    241235reassign_reviewing.label = reassign review
    242236reassign_reviewing.permissions = TICKET_MODIFY
    243237}}}
    244238
    245 == Example: Limit the resolution options for a new ticket
    246
    247 The above `resolve_new` operation allows you to set the possible resolutions for a new ticket. By modifying the existing resolve action and removing the new status from before the `->` we then get two resolve actions. One with limited resolutions for new tickets, and then the regular one once a ticket is accepted.
    248
    249 {{{#!ini
    250 resolve_new = new -> closed
    251 resolve_new.label = resolve
    252 resolve_new.operations = set_resolution
    253 resolve_new.permissions = TICKET_MODIFY
    254 resolve_new.set_resolution = invalid,wontfix,duplicate
    255
    256 resolve = assigned,accepted,reopened -> closed
    257 resolve.operations = set_resolution
    258 resolve.permissions = TICKET_MODIFY
    259 }}}
    260
    261239== Advanced Ticket Workflow Customization
    262240
    263 If the customizations above do not meet your needs, you can extend the workflow with plugins. Plugins can provide additional operations for the workflow, like code_review, or implement side-effects for an action, such as triggering a build, that may not be merely simple state changes. Look at [trac:source:trunk/sample-plugins/workflow sample-plugins/workflow] for a few examples to get started.
    264
    265 But if even that is not enough, you can disable the !ConfigurableTicketWorkflow component and create a plugin that completely replaces it.
     241If the customizations above do not meet your needs, you can extend the workflow with plugins. Plugins can provide additional operations for the workflow, like code review, or implement side-effects for an action, such as triggering a build, that may not be merely simple state changes. Look at [trac:source:branches/1.4-stable/sample-plugins/workflow sample-plugins/workflow] for a few examples to get started.
     242
     243But if even that is not enough, you can disable the !ConfigurableTicketWorkflow component and create a plugin that completely replaces it. See also the [https://trac-hacks.org/wiki/AdvancedTicketWorkflowPlugin AdvancedTicketWorkflowPlugin], which provides additional operations.
    266244
    267245== Adding Workflow States to Milestone Progress Bars
    268246
    269 If you add additional states to your workflow, you may want to customize your milestone progress bars as well. See [TracIni#milestone-groups-section TracIni].
     247If you add additional states to your workflow, you may want to customize your milestone progress bars as well. See the [TracIni#milestone-groups-section "[milestone-groups]"] section.
    270248
    271249== Ideas for next steps
    272250
    273 Enhancement ideas for the workflow system should be filed as enhancement tickets against the [trac:query:?status=assigned&status=new&status=reopened&keywords=~workflow&component=ticket+system ticket system] component.  You can also document ideas on the [trac:TracIdeas/TracWorkflow TracIdeas/TracWorkflow] page. Also look at the [http://trac-hacks.org/wiki/AdvancedTicketWorkflowPlugin AdvancedTicketWorkflowPlugin] as it provides experimental operations.
     251Enhancement ideas for the workflow system should be filed as enhancement tickets against the [trac:query:?status=assigned&status=new&status=reopened&keywords=~workflow&component=ticket+system ticket system] component.  You can also document ideas on the [trac:TracIdeas/TracWorkflow TracIdeas/TracWorkflow] page.
