Changes between Version 1 and Version 2 of TracUnicode
- Jun 10, 2010, 1:36:18 PM (14 years ago)
TracUnicode
v1 v2 5 5 6 6 As such, it supports most (all?) commonly used character encodings. 7 8 If your encoding is not UTF-8, you can use [wiki:TracModPython mod_python] to handle it. For example, if your local encoding is gbk, you can set 9 default_charset = gbk 10 in trac.ini. 11 12 You also must make sure that your [trac:DatabaseBackend database backend] stores its data in UTF-8; otherwise strange things will happen. 13 14 To convert your database to UTF-8, the easiest way is to dump the database, convert the dump into UTF-8 and then import the converted dump back into the database.[[BR]] 15 You can use [http://www.gnu.org/software/libiconv/documentation/libiconv/iconv.1.html iconv] to convert the dump. 16 7 17 8 18 == Examples == … … 74 84 75 85 === Polish === 76 Pchnąć w tę łódź jeża lub o śm skrzyń fig86 Pchnąć w tę łódź jeża lub osiem skrzyń fig; Nocna gżegżółka zawsze dzienną przekuka. 77 87 78 88 === Portuguese === … … 89 99 90 100 === Spanish === 91 Esto es un pequeño texto en Español, ahora una con acentó101 Esto es un pequeño texto en Español, donde el veloz murciélago hindú comía cardlllo y kiwi 92 102 93 103 === Swedish === … … 104 114 105 115 === Vietnamese === 106 Viết tiếng Việt cũng được. Nhưng search từ tiếng Việt thì không bôi vàng được. (Keyword(s) in Vietnamese search result can not be hightlighted !!!!).116 Viết tiếng Việt cũng được.
