Changes between Version 3 and Version 4 of TracLogging
- Feb 1, 2017, 12:33:40 AM (7 years ago)
TracLogging
v3 v4 1 = Trac Logging =1 = Trac Logging 2 2 [[TracGuideToc]] 3 3 … … 6 6 Logging is configured in the `[logging]` section in [wiki:TracIni#logging-section trac.ini]. 7 7 8 == Supported Logging Methods ==8 == Supported Logging Methods 9 9 10 10 The log method is set using the `log_type` option in [wiki:TracIni#logging-section trac.ini], which takes any of the following values: … … 16 16 '''eventlog''':: (Windows) Use the system's NT Event Log for Trac logging. 17 17 18 == Log Levels ==18 == Log Levels 19 19 20 20 The verbosity level of logged messages can be set using the `log_level` option in [wiki:TracIni#logging-section trac.ini]. The log level defines the minimum level of urgency required for a message to be logged, and those levels are: … … 28 28 Additionally, you can enable logging of SQL statements at debug level. This is turned off by default, as it's very verbose. Set `[trac] debug_sql = yes` in TracIni to activate. 29 29 30 == Log Format ==30 == Log Format 31 31 32 32 The output format for log entries can be specified through the `log_format` option in [wiki:TracIni#logging-section trac.ini]. The format is a string which can contain any of the [http://docs.python.org/library/logging.html#logrecord-attributes Python logging Formatter variables]. Additonally, the following Trac-specific variables can be used: … … 38 38 39 39 The default format is: 40 {{{ 40 {{{#!ini 41 41 log_format = Trac[$(module)s] $(levelname)s: $(message)s 42 42 }}} 43 43 44 44 In a multi-project environment where all logs are sent to the same place (e.g. `syslog`), it makes sense to add the project name. In this example we use `basename` since that can generally be used to identify a project: 45 {{{ 45 {{{#!ini 46 46 log_format = Trac[$(basename)s:$(module)s] $(levelname)s: $(message)s 47 47 }}}
