Changes between Version 3 and Version 4 of TracIni
- Feb 1, 2017, 12:33:40 AM (8 years ago)
TracIni
v3 v4 2 2 3 3 [[TracGuideToc]] 4 [[PageOutline ]]4 [[PageOutline(2-5,Contents,pullout)]] 5 5 6 Trac is configured by editingthe **`trac.ini`** file, located in the `<projectenv>/conf` directory. The `trac.ini` configuration file and its parent directory should be writable by the web server.6 Trac is configured through the **`trac.ini`** file, located in the `<projectenv>/conf` directory. The `trac.ini` configuration file and its parent directory should be writable by the web server. 7 7 8 8 Trac monitors the timestamp of the file to trigger a complete environment reload and flush its caches when the timestamp changes. Most changes to the configuration will be reflected immediately, though changes to the `[components]` or `[logging]` sections will require restarting the web server. You may also need to restart the web server after creating a [#GlobalConfiguration global configuration] file when none was previously present. … … 17 17 Multiple files can be specified using a comma-separated list. 18 18 19 Note that you can also specify a global option file when creating a new project, by adding the option `--inherit=/path/to/global/trac.ini` to [TracAdmin#initenv trac-admin]'s `initenv` command.If you do not do this but nevertheless intend to use a global option file with your new environment, you will have to go through the newly generated `conf/trac.ini` file and delete the entries that will otherwise override those set in the global file.19 Note that you can also specify a global option file when creating a new project, by adding the option `--inherit=/path/to/global/trac.ini` to [TracAdmin#initenv trac-admin]'s `initenv` command. If you do not do this but nevertheless intend to use a global option file with your new environment, you will have to go through the newly generated `conf/trac.ini` file and delete the entries that will otherwise override those set in the global file. 20 20 21 21 There are two more entries in the [[#inherit-section| [inherit] ]] section, `templates_dir` for sharing global templates and `plugins_dir`, for sharing plugins. Those entries can themselves be specified in the shared configuration file, and in fact, configuration files can even be chained if you specify another `[inherit] file` there.
