Changes between Version 1 and Version 2 of TracImport
- Jun 10, 2010, 1:36:34 PM (14 years ago)
TracImport
v1 v2 3 3 == Bugzilla == 4 4 5 Ticket data can be imported from Bugzilla using the [http:// projects.edgewall.com/trac/browser/trunk/contrib/bugzilla2trac.py bugzilla2trac.py] script, available in the contrib/ directory of the Trac distribution.5 Ticket data can be imported from Bugzilla using the [http://trac.edgewall.org/browser/trunk/contrib/bugzilla2trac.py bugzilla2trac.py] script, available in the contrib/ directory of the Trac distribution. 6 6 7 7 {{{ … … 42 42 == Sourceforge == 43 43 44 Ticket data can be imported from Sourceforge using the [http:// projects.edgewall.com/trac/browser/trunk/contrib/sourceforge2trac.py sourceforge2trac.py] script, available in the contrib/ directory of the Trac distribution.44 Ticket data can be imported from Sourceforge using the [http://trac.edgewall.org/browser/trunk/contrib/sourceforge2trac.py sourceforge2trac.py] script, available in the contrib/ directory of the Trac distribution. 45 45 46 46 == Mantis == 47 48 NB! The mantis2trac script now lives at http://trac-hacks.org/wiki/MantisImportScript . You can always get the latest version from http://trac-hacks.org/changeset/latest/mantisimportscript?old_path=/&filename=mantisimportscript&format=zip 47 49 48 50 Mantis bugs can be imported using the attached script. … … 52 54 * bug comments 53 55 * bug activity (field changes) 56 * attachments (as long as the files live in the mantis db, not on the filesystem) 54 57 55 Attachments are NOT imported.If you use the script, please read the NOTES section (at the top of the file) and make sure you adjust the config parameters for your environment.58 If you use the script, please read the NOTES section (at the top of the file) and make sure you adjust the config parameters for your environment. 56 59 57 60 mantis2trac.py has the same parameters as the bugzilla2trac.py script: … … 79 82 === Using a comma delimited file - CSV === 80 83 See [http://trac.edgewall.org/attachment/wiki/TracSynchronize/csv2trac.2.py] for details. This approach is particularly useful if one needs to enter a large number of tickets by hand. (note that the ticket type type field, (task etc...) is also needed for this script to work with more recent Trac releases) 84
