Changes between Version 1 and Version 2 of WikiStart
Nov 17, 2009, 3:48:28 PM (14 years ago)
mdavis
  • WikiStart
    v1 v2
    1 = Welcome to Trac 0.10.3.1 =
     1= Welcome to Proj4J =
    3 Trac is a '''minimalistic''' approach to '''web-based''' management of
    4 '''software projects'''. Its goal is to simplify effective tracking and handling of software issues, enhancements and overall progress.
     3Proj4J is a Java library to transform point coordinates from one coordinate system to another, including datum transformations.
    54
    6 All aspects of Trac have been designed with the single goal to
    7 '''help developers write great software''' while '''staying out of the way'''
    8 and imposing as little as possible on a team's established process and
    9 culture.
     5The core of this library is a port of the popular [http://trac.osgeo.org/proj/ PROJ.4] C library. The basic algorithms, concepts and coordinate system definitions supplied by PROJ.4 have been exposed via a class model which follows standard Java conventions and OO best practices.
    106
    11 As all Wiki pages, this page is editable, this means that you can
    12 modify the contents of this page simply by using your
    13 web-browser. Simply click on the "Edit this page" link at the bottom
    14 of the page. WikiFormatting will give you a detailed description of
    15 available Wiki formatting commands.
     7Proj4J is a part of the [http://wiki.osgeo.org/wiki/MetaCRS MetaCRS] group of projects, hosted by [http://osgeo.org OSGeo].
    168
    17 "[wiki:TracAdmin trac-admin] ''yourenvdir'' initenv" created
    18 a new Trac environment, containing a default set of wiki pages and some sample
    19 data. This newly created environment also contains
    20 [wiki:TracGuide documentation] to help you get started with your project.
     9== Download ==
    2110
    22 You can use [wiki:TracAdmin trac-admin] to configure
    23 [http://trac.edgewall.org/ Trac] to better fit your project, especially in
    24 regard to ''components'', ''versions'' and ''milestones''.
     11The current development source is available by anonymous SVN from http://svn.osgeo.org/metacrs/proj4j/trunk.
    2512
    2613
    27 TracGuide is a good place to start.
    28
    29 Enjoy! [[BR]]
    30 ''The Trac Team''
    31
    32 == Starting Points ==
    34  * TracGuide --  Built-in Documentation
    35  * [http://trac.edgewall.org/ The Trac project] -- Trac Open Source Project
    36  * [http://trac.edgewall.org/wiki/TracFaq Trac FAQ] -- Frequently Asked Questions
    37  * TracSupport --  Trac Support
    38
    39 For a complete list of local wiki pages, see TitleIndex.
