Changes between Version 6 and Version 7 of WikiStart
Show
05/15/08 21:06:41 (5 years ago)
warmerdam
flesh out most of page...
  • WikiStart
    v6 v7
    2727 * [ftp://ftp.remotesensing.org/proj/from_kai/ from_kai]: A snapshot of everything on the kai.er.usgs.gov/pub/PROJ.4 directory as of March/2000.
    2828
     29== Documentation ==
     30
     31 * [ftp://ftp.remotesensing.org/proj/OF90-284.pdf OF90-284.pdf (2.7MB)]: The main users manual for PROJ; however, this dates from PROJ.3 - the addendums [ftp://ftp.remotesensing.org/proj/proj.4.3.pdf proj.4.3.pdf (1MB)], [ftp://ftp.remotesensing.org/proj/proj.4.3.I2.pdf proj.4.3.I2.pdf (2MB)], and [ftp://ftp.remotesensing.org/proj/swiss.pdf swiss.pdf (78KB)] contain important additional information.
     32 * [http://members.verizon.net/~gerald.evenden/proj4/ Gerald Evenden's libproj]: includes some updates and documentation for his slimmed down libproj.
     33 * [wiki:man_proj proj], [wiki:man_cs2cs cs2cs], [wiki:man_geod geod] and [wiki:man_pj_init api] man pages.
     34 * [wiki:FAQ]: Frequently Asked Questions and Answers
     35 * [wiki:GenParms General Parameter Notes]
     36 * [http://www.remotesensing.org/geotiff/proj_list/ Projections List] page on the GeoTIFF site includes information on how to describe many common projections with PROJ.4 command arguments.
     37
     38== Mailing List ==
     39
     40A mailing list is available for users and developers of PROJ.4 as well as for discussion of general cartographic projections related issues.  Subscription, unsubscription and a web archive can be found at http://lists.maptools.org/mailman/listinfo/proj.
     41The PROJ.4 mailing list is also available by NNTP at news://news.gmane.org/gmane.comp.gis.proj-4.devel and via HTML at
     42[http://news.gmane.org/gmane.comp.gis.proj-4.devel].
     43
    2944== Bug Tracking ==
    3045
    4055
    4156If the Buildbot [http://buildbot.osgeo.org:8502/waterfall Waterfall] is green and there are no red boxes, then PROJ.4 is healthy.
     57
     58== Plans ==
     59
     60PROJ.4 is in active use by [http://grass.osgeo.org GRASS GIS], [http://mapserver.gis.umn.edu/ MapServer], [http://www.postgis.org/ PostGIS], [http://thuban.intevation.org/ Thuban], [http://ogdi.sourceforge.net/ OGDI] and [http://www.gdal.org/ogr/osr_tutorial.html OGRCoordinateTransformation] as well as various other projects (please let me know about other projects using PROJ.4!).
     61
     62Since work started on the PROJ.4.4.x series of releases, various bux fixes have been incorporated, and the build system has been overhauled to use autoconf/libtool.  Support has also been added for 3 and 7 parameter datum shifts, the '''PJ*''' structure now also carries datum information and '''PJ*''' can be considered a full coordinate system (geographic coordinate systems are also now supported with the '''+proj=latlong''' pseudo-projection).  The new '''cs2cs''' program performs a similar function to the '''proj''' program, but transforming from any one coordinate system to another.  The new '''pj_transform()''' is used to access the extended coordinate system to coordinate system transformation with datum shifting.
     63
     64A mapping file ('''epsg''') has also been introduced mapping most EPSG ([http://www.epsg.org/]) coordinate systems to PROJ.4 format.
     65
     66As of May 2008 PROJ.4 has become part of the [http://wiki.osgeo.org/wiki/MetaCRS MetaCRS] project, a confederation of coordinate systems related projects and it is hoped MetaCRS will enter incubation as an [http://www.osgeo.org/ OSGeo] project.
     67
     68Future plans for PROJ.4 will hopefully include better online documentation, refinement of datum shifting support and extension of the external
     69programming API for greater convenience in handling coordinate systems from applications.
     70
     71If you are a user of PROJ.4, and/or are interested in contributing please drop me a line and join the mailing list.
     72
     73== License ==
     74
     75
     76PROJ.4 has been placed under an MIT license.  I believe this to
     77be as close as possible to public domain while satisfying those who say that
     78a copyright notice is required in some countries.  The COPYING file read as
     79follows:
     80
     81All source, data files and other contents of the PROJ.4 package are
     82available under the following terms.  Note that the PROJ 4.3 and earlier
     83was "public domain" as is common with US government work, but apparently
     84this is not a well defined legal term in many countries.  I am placing
     85everything under the following MIT style license because I believe it is
     86effectively the same as public domain, allowing anyone to use the code as
     87they wish, including making proprietary derivatives.
     88
     89Though I have put my own name as copyright holder, I don't mean to imply
     90I did the work.  Essentially all work was done by Gerald Evenden.
     91
     92{{{
     93 Copyright (c) 2000, Frank Warmerdam
     94
     95 Permission is hereby granted, free of charge, to any person obtaining a
     96 copy of this software and associated documentation files (the "Software"),
     97 to deal in the Software without restriction, including without limitation
     98 the rights to use, copy, modify, merge, publish, distribute, sublicense,
     99 and/or sell copies of the Software, and to permit persons to whom the
     100 Software is furnished to do so, subject to the following conditions:
     101
     102 The above copyright notice and this permission notice shall be included
     103 in all copies or substantial portions of the Software.
     104
     105 THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
     106 OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
     107 FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
     108 THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
     109 LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
     110 FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
     111 DEALINGS IN THE SOFTWARE.
     112}}}
     113
     114== Related Resources ==
     115
     116<ul>
     117
     118<li> <a href="http://pubs.er.usgs.gov/usgspubs/pp/pp1395">Snyder, 1987: Map
     119projections; a working manual</a>.<p>
     120
     121<li> <a href="http://ftp.dfg.ca.gov/Public/BDB/Tools/proj4/proj_api.zip">
     122PROJ.4 VB Wrappers</a> from Eric G. Miller. <p>
     123
     124<li> <a href="http://gmt.soest.hawaii.edu/">GMT</a> - Generic
     125Mapping Tools, includes reprojection services.<p>
     126
     127<li> <a href="http://www.progonos.com/furuti/MapProj/CartIndex/cartIndex.html">
     128Map projections</a>: An introduction to cartography emphasizing map projections: their properties, applications and basic mathematics.<p>
     129
     130<li> <a href="http://edc.usgs.gov/pub/software/gctpc/">GCTPC</a>: The
     131other widely used projection package from te USGS.<p>
     132
     133<li> <a href="http://earth-info.nga.mil/GandG/geotrans/index.htm">
     134Geotrans</a>: a projections and datum shift program from NIMA.<p>
     135
     136<li> <a href="http://www.jhlabs.com/java/maps/proj/">JHLabs Java Map Projection Library</a>: Loosely derived from PROJ.4 with similar syntax.<p>
     137
     138<li> <a href="http://geotools.org/">GeoTools</a>: GeoTools is a Java GIS library that includes projections support.<p>
     139
     140<li> <a href="http://www.mapref.org">MapRef</a>: Assorted general information on projections, and related topics.<p>
     141
     142<li> <a href="http://www.asprs.org/resources/GRIDS/">Grids & Datums</a>: Clifford J. Mugnier's columns in PE&amp;RS.<p>
     143
     144<li> <a href="http://earth-info.nga.mil/GandG/publications/index.htm">NGA (former NIMA) Publications on Geodesy</a>.<p>
     145
     146<li> <a href="http://www.galleryofmapprojections.com/">Paul B. Anderson's Map Projections Site</a>.<p>
     147
     148</ul>
     149
