Changes between Version 17 and Version 18 of WKTRasterGSoC
Show
09/20/11 07:59:13 (20 months ago)
pracine
  • WKTRasterGSoC
    v17 v18
    3232    1) '''ST_AsRaster''' takes a geometry and converts it to a raster.
    3333
    34     2) '''ST_Interpolate''' takes a point (e.g. filtered lidar points) or line geometry (e.g. digitized topo lines) coverage to interpolate pixels values between geometries. There are numerous methods of [http://en.wikipedia.org/wiki/Interpolation interpolation] and it would nice to have a generic method so we can use all of them, but we’re first targeting [http://en.wikipedia.org/wiki/Bilinear_interpolation bilinear interpolation], which will fill most needs and lay the ground for other methods. For reference, you might want to check an implementation in [http://apps.nrbook.com/empanel/index.html Numerical Recipes (chap. 3)] or in [http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Interpolation/Chapter_main.html#Section_68.3 CGAL]
     34    2) '''ST_Interpolate''' takes a point (e.g. filtered lidar points) or line geometry (e.g. digitized topo lines) coverage to interpolate pixels values between geometries. There are numerous methods of [http://en.wikipedia.org/wiki/Interpolation interpolation] and it would nice to have a generic method so we can use all of them, but we’re first targeting [http://en.wikipedia.org/wiki/Bilinear_interpolation bilinear interpolation], which will fill most needs and lay the ground for other methods. For reference, you might want to check an implementation in [http://apps.nrbook.com/empanel/index.html Numerical Recipes (chap. 3)] or in [http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Interpolation/Chapter_main.html#Section_68.3 CGAL]. Converting a point table to a TIN and then to a raster is also a way to go. A Delaunay triangulation can be produced with the [http://www.cs.cmu.edu/~quake/triangle.html Triangle library] (copyright issues should be checked first).
    3535
    3636
