| | 221 | Bborie: The JPEG format has several limitations: |
| | 222 | |
| | 223 | 1. JPEG only allows 1 (greyscale) or 3 (RGB) bands of data |
| | 224 | |
| | 225 | 2. JPEG only supports 8BUI pixeltype |
| | 226 | |
| | 227 | 3. JPEG cannot embed spatial reference information within the file but can have an associated world file |
| | 228 | |
| | 229 | To address the limitations: |
| | 230 | |
| | 231 | 1. Use ST_Band to specify which band(s) should be passed to the ST_AsJPEG function. Variations of ST_AsJPEG are made available that allows specifying a band index. If a raster whose number of specified bands does not equal 1 or 3 is provided, a warning is raised and the first or the first three bands are used. |
| | 232 | |
| | 233 | 2. Throw an exception if any of the specified bands is not 8BUI. The user should use ST_Reclass to convert any non-8BUI bands to 8BUI. |
| | 234 | |
| | 235 | 3. Nothing can be done. |
| | 236 | |
| | 237 | A proposed set of variations of the ST_AsJPEG function: |
| | 238 | |
| | 239 | 1. ST_AsJPEG(rast raster, options text[]) |
| | 240 | |
| | 241 | rast: the raster with one or three bands in 8BUI pixel type to generate a JPEG image from |
| | 242 | |
| | 243 | options: array of creation options to pass to the GDAL JPEG driver |
| | 244 | |
| | 245 | {{{ |
| | 246 | ST_AsJPEG(rast, ARRAY['QUALITY=90', 'PROGRESSIVE=ON']) |
| | 247 | }}} |
| | 248 | |
| | 249 | 2. ST_AsJPEG(rast raster) |
| | 250 | |
| | 251 | Like !#1 above but use the driver's default creation options |
| | 252 | |
| | 253 | 3. ST_AsJPEG(rast raster, nbands int[], options text[]) |
| | 254 | |
| | 255 | nbands: an integer array specifying the band indices of the raster to include in the JPEG file |
| | 256 | |
| | 257 | {{{ |
| | 258 | ST_AsJPEG(rast, ARRAY[1,3,6], ARRAY['QUALITY=50']) |
| | 259 | }}} |
| | 260 | |
| | 261 | 4. ST_AsJPEG(rast raster, nbands int[]) |
| | 262 | |
| | 263 | Like !#3, but use the default creation options |
| | 264 | |
| | 265 | {{{ |
| | 266 | ST_AsJPEG(rast, ARRAY[1,3,6]) |
| | 267 | }}} |
| | 268 | |
| | 269 | 5. ST_AsJPEG(rast raster, nbands int[], quality int) |
| | 270 | |
| | 271 | quality: number between 10 and 100 indicating image quality |
| | 272 | |
| | 273 | {{{ |
| | 274 | ST_AsJPEG(rast, ARRAY[1,2,3], 90) |
| | 275 | }}} |
| | 276 | |
| | 277 | 6. ST_AsJPEG(rast raster, nband int, options text[]) |
| | 278 | |
| | 279 | nband: index of the band to include |
| | 280 | |
| | 281 | {{{ |
| | 282 | ST_AsJPEG(rast, 2, ARRAY['QUALITY=25']) |
| | 283 | }}} |
| | 284 | |
| | 285 | 7. ST_AsJPEG(rast raster, nband int, quality int) |
| | 286 | |
| | 287 | {{{ |
| | 288 | ST_AsJPEG(rast, 5, 75) |
| | 289 | }}} |
| | 290 | |
| | 291 | 8. ST_AsJPEG(rast raster, nband int) |
| | 292 | |
| | 293 | {{{ |
| | 294 | ST_AsJPEG(rast, 4) |
| | 295 | }}} |
