Changes between Version 61 and Version 62 of WKTRaster/SpecificationWorking03
Show
04/15/11 08:16:25 (2 years ago)
dustymugs
addition of ST_Reclass
  • WKTRaster/SpecificationWorking03
    v61 v62
    407407----
    408408
     409'''ST_Reclass(rast raster, VARIADIC argset reclassarg[]) -> raster'''
     410
     411Due to limitations in the JPEG (8BUI) and PNG (8BUI and 16BUI) raster formats regarding supported pixel/data types, a method must be provided that can convert a band of a larger data type to 8BUI, amongst other uses.  ST_Reclass allows raster's band pixel values to be remapped from one range of numbers to another as well as between pixel types, e.g. 32BF to 8BUI.
     412
     413ST_Reclass returns a duplicate of the submitted raster with the bands specified to be reclassed being processed.  This means that if a raster with 5 bands are submitted and band 1 is to be reclassed, the output raster will have 5 bands with band 1 reclassified.  The other four bands will not be touched.
     414
     4151. ST_Reclass(rast raster, VARIADIC argset reclassarg[]) -> raster
     416
     417  rast: the raster whose specified bands are to be reclassified
     418
     419  reclassarg: a new custom type defining the parameters required for reclassifying a band's pixel values.
     420
     421{{{
     422CREATE TYPE reclassarg AS (
     423
     424  nband int,
     425
     426  reclassexpr text,
     427
     428  pixeltype text,
     429
     430  nodata double
     431
     432);
     433}}}
     434
     435    nband: index of the band to reclass (1-based)
     436
     437    reclassexpr: reclassification expression indicating the ranges to convert from and to.  More than one expression can be provided by separating the expression with a comma (,).  The values provided can be of any valid numeric type.
     438
     439      ''rangefrom:rangeto[, rangefrom:rangeto]''
     440
     441{{{
     4420-100:0-10
     443
     4440-100:0-10, 101-1000:11-100
     445
     4460-100:0-10, 101-1000:11-100, 1001-10000:101-1000
     447}}}
     448
     449      In the last example above, the default evaluation of the ranges is
     450
     451{{{
     452        0 <= x < 100 reclassified to 0 <= y <= 10
     453
     454        101 <= x < 1000 reclassified to 11 <= y <= 100
     455
     456        1001 <= x < 10000 reclassified to 101 <= y <= 1000
     457}}}
     458
     459      To change the evaluation of rangefrom, use square brackets and parentheses.
     460
     461{{{
     4621. [a-b] = a <= x <= b
     463
     4642. (a-b] = a < x <= b
     465
     4663. [a-b) = a <= x < b
     467
     4684. (a-b) = a < x < b
     469}}}
     470
     471      !#3 above is the default evaluation of x in the range a-b. The use of square brackets and parentheses are optional, so the examples below would be permitted. Missing notations substitute the appropriate notation from #3 above.
     472
     473{{{
     474[a-b = a <= x < b
     475
     476(a-b = a < x < b
     477
     478a-b] = a <= x <= b
     479
     480a-b) = a <= x < b
     481}}}
     482
     483    pixeltype: the reclassified band's pixel type, e.g. 8BUI, 16BUI, 32BF
     484
     485    nodata: the nodata value of the reclassified band.  If the source band has a nodata value, all source pixel value equal to the source nodata value will be converted to the reclassified band's nodata value.  If set to NULL, the reclassified band will NOT have a nodata value specified.
     486
     487{{{
     488ST_Reclass(rast, ROW(1, '0-100:0-10, 101-1000:11-100, 1001-10000:101-1000', '16BUI', NULL));
     489
     490ST_Reclass(rast, ROW(1, '0-100:0-10, 101-1000:11-100, 1001-10000:101-1000', '16BUI', 1001));
     491
     492ST_Reclass(rast,
     493  ROW(1, '0-100:0-10, 101-1000:11-100, 1001-10000:101-1000', '16BUI', 1001),
     494  ROW(2, '0-100:0-10, 101-1000:11-100, 1001-10000:101-1000', '16BUI', 1001),
     495  ROW(3, '0-100:0-10, 101-1000:11-100, 1001-10000:101-1000', '16BUI', 1001),
     496  ROW(5, '0-100:0-10, 101-1000:11-100, 1001-10000:101-1000', '16BUI', 1001)
     497)
     498}}}
     499
     500  An expanded example
     501
     502{{{
     503SELECT ST_Reclass(
     504  ST_Band(rast, ARRAY[1,1,1]),
     505  1, LEAST(covmin, 0)::text || '-0:0,0-' || GREATEST(covmax, 0)::text || ':0-255', '8BUI',
     506  2, LEAST(covmin, 0)::text || '-0:200,0-' || GREATEST(covmax, 0)::text' || ':0-255','8BUI',
     507  3, LEAST(covmin, 0)::text || '-0:255,0-' || (GREATEST(covmax, 0)/2)::text' || ':0,' || (GREATEST(covmax, 0)/2)::text' || ':' || GREATEST(covmax, 0)::text || ':0-255', '8BUI')
     508FROM mycoverage
     509}}}
     510
     5112. ST_Reclass(rast raster, nband int, reclassexpr text, pixeltype text, nodata double) -> raster
     512
     513  provides a method to process just one band of a raster
     514
     515{{{
     516ST_Reclass(rast, 1, '0-100:0-10', '8BUI', 11)
     517}}}
     518
     5193. ST_Reclass(rast raster, nband int, reclassexpr text, pixeltype text) -> raster
     520
     521  nodata parameter removed so reclassified band will NOT have a nodata value set
     522
     523{{{
     524ST_Reclass(rast, 1, '0-100:0-10', '8BUI')
     525}}}
     526
     5274. ST_Reclass(rast raster, reclassexpr text, pixeltype text) -> raster
     528
     529  nband parameter removed so reclassified band is assumed to be 1.  nodata parameter removed so reclassified band has NO nodata value.
     530
     531{{{
     532ST_Reclass(rast, '0-100:0-10', '8BUI')
     533}}}
     534
     5355. ST_Reclass(rast raster, reclassexpr text, pixeltype text, nodata double) -> raster
     536
     537  nband parameter removed so reclassified band is assumed to be 1
     538
     539{{{
     540ST_Reclass(rast, '0-100:0-10', '8BUI', 11)
     541}}}
     542
     543----
     544
    409545== '''Objective FV.02 - Being able to intersect vector and raster to produce raster.''' ==
    410546
    607743'''ST_SelectByValue(raster|geometry, ‘expression’) -> same type as first argument'''[[BR]]
    608744'''ST_Reclass(raster|geometry,string) -> same type as first argument'''[[BR]]
     745
     746Bborie: Implementation has been moved to FV.01 above.
    609747
    610748'''ST_MapAlgebra(raster|geometry, [raster|geometry,…] ‘mathematical expression’, ‘raster’ |’geometry’) -> raster/geometry'''
