Changes between Version 49 and Version 50 of WKTRaster/SpecificationWorking03
Apr 6, 2011, 7:34:18 AM (13 years ago)
Bborie Park
  • WKTRaster/SpecificationWorking03
    v49 v50
    4242Return a single band from a multiband raster. If "band" is greater than the value returned by ST_GetNumBands(), the function returns the last band. This function should be used to select a band before converting it to JPEG, TIFF, PNG, SVG or KML with the corresponding function. e.g. '''ST_AsTIFF(ST_Band(raster, band))
    4343
    44 '''Bborie: A complete implementation of ST_Band would include the following:
     44Bborie: A complete implementation of ST_Band should include the following:
    4545
    4646ST_Band(rast raster, nbands int[]) -> raster
    186186Use GDAL to convert the raster into one of the format suported by GDAL.
    187187
     188Bborie: this is a generic interface to outputting a supported and installed GDAL raster:
     189
     190ST_AsGDALRaster(rast raster, format text, options text[], srs text) -> bytea
     191
     192  This is the most generic and GDAL-specific method to convert a raster to a GDAL raster.  Reference information for the format and options arguments of a particular format are specified at: http://gdal.org/formats_list.html.  The arguments specified are:
     193
     194  format: the GDAL format code.  e.g. GTiff, JPEG, PNG
     195
     196  options: the GDAL creation options found in the '''Creation Options''' section of a specified format.  e.g. COMPRESS=JPEG, JPEG_QUALITY=90
     197
     198  srs: the user-specified OGC WKT or the proj4 text for a spatial reference to embed in the GDAL raster.  Not all formats support embedding this information.  e.g. the non-empty value for the srtext or proj4text column from the spatial_ref_sys table.
     199
     200  Ex: ST_AsGDALRaster(rast, 'GTiff', ARRAY['COMPRESS=JPEG', 'JPEG_QUALITY=90'], '+proj=aea +lat_1=34 +lat_2=40.5 +lat_0=0 +lon_0=-120 +x_0=0 +y_0=-4000000 +ellps=GRS80 +datum=NAD83 +units=m +no_defs')
     201
     202      ST_AsGDALRaster(rast, 'GTiff', ARRAY['COMPRESS=JPEG', 'JPEG_QUALITY=90'], 'PROJCS["NAD83 / California Albers",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Albers_Conic_Equal_Area"],PARAMETER["standard_parallel_1",34],PARAMETER["standard_parallel_2",40.5],PARAMETER["latitude_of_center",0],PARAMETER["longitude_of_center",-120],PARAMETER["false_easting",0],PARAMETER["false_northing",-4000000],AUTHORITY["EPSG","3310"],AXIS["X",EAST],AXIS["Y",NORTH]]')
     203
     204ST_AsGDALRaster(rast raster, format text, options text[]) -> bytea
     205
     206  This one removes the user-specified srs argument.  The output GDAL raster's spatial reference will be set to the same as the input raster, if possible.
     207
     208  Ex: ST_AsGDALRaster(rast, 'JPEG', ARRAY['QUALITY=50'])
     209
     210      ST_AsGDALRaster(rast, 'PNG', ARRAY['ZLEVEL=7'])
     211
     212ST_AsGDALRaster(rast raster, format text) -> bytea
     213
     214  The simplest implementation of this function.  Since the options argument has been removed, the output GDAL raster will be created with default options.  Like the prior function, the spatial reference of the GDAL raster will be set to the same as the input raster.
     215
     216ST_AsGDALRaster and other format specific functions (ST_AsJPEG, ST_AsTIFF and ST_AsPNG) are all wrappers around the function
     217
     218_ST_AsGDALRaster(rast raster, format text, options text[], srs text)
    188219
    189220----
