Changes between Version 35 and Version 36 of WKTRaster/SpecificationWorking03
- Mar 14, 2011, 11:15:55 AM (13 years ago)
v35 v36 207 207 So this would mean "for each pixel, compute the average of all the 1 + 8 + 16 = 25 pixels surrounding the current pixel and "ignore" pixels with nodata values." 208 208 209 The "ST_Avg" summarizing function should accept three parameters: an array of float8 values, a X and a Y dimension, and optionnally a "what to do with nodata values". The possible value for this parameter could be:209 The "ST_Avg" summarizing function should accept three parameters: an array of float8 values, a X and a Y dimension, and optionnally a "what to do with nodata values". The possible value for this last parameter could be: 210 210 211 211 *"NULL": If any value is a nodata value, return NULL. 212 212 213 *"ignore": Ignore any nodata value so that if 4 pixels on 25 are nodata values, do the computation with the 21 remaining. 214 213 215 *a value: Replace any nodata value with this value and compute. 214 216
