Changes between Version 148 and Version 149 of WKTRaster/SpecificationWorking03
Show
07/14/11 16:05:25 (2 years ago)
dustymugs
ST_Resample, ST_Rescale, ST_Reskew, ST_SnapToGrid
  • WKTRaster/SpecificationWorking03
    v148 v149
    401401'''ST_ValuePercent(raster, value) -> double precision - done see below'''
    402402
    403 '''ST_Resample(raster, method, originx, originy, pixelsizex, pixelsizey) -> raster'''
    404
    405  * Implemented as a wrapper around GDAL like done for ST_DumpAsPolygons()
    406  * Resampling methods are the same as the one priovided by GDAL
    407
    408  '''Variants'''
    409
    410  * The '''first series of variants''' only change the pixelsize of the raster.
    411
    412  1) ST_Resample(raster, pixelsize) - modify pixelsize only and resample using the default method
    413
    414  2) ST_Resample(raster, method, pixelsize) - modify pixelsize and resample using the specified method
    415
    416  3) ST_Resample(raster, pixelsizex, pixelsizey) - modify pixelsize with different values for x and y using the default method
    417
    418  4) ST_Resample(raster, method, pixelsizex, pixelsizey) - modify pixelsize with different values for x and y using the specified method
    419
    420  * The '''second series of variants''' realign the raster and change the pixelsize
    421
    422  5) ST_Resample(raster, x, y, pixelsize) - realign and modify pixelsize using the default method
    423
    424  6) ST_Resample(raster, method, x, y, pixelsize) - realign and modify pixelsize using the specified method
    425
    426  7) ST_Resample(raster, x, y, pixelsizex, pixelsizey) - realign and modify pixelsize with different values for x and y using the default method
    427
    428  8) ST_Resample(raster, method, x, y, pixelsizex, pixelsizey) - realign and modify pixelsize with different values for x and y using the specified method
    429
    430  9) ST_Resample(raster, x, y, pixelsizex, pixelsizey, skewx, skewy) - realign and modify pixelsize and skew with different values for x and y using the default method
    431
    432  10) ST_Resample(raster, method, x, y, pixelsizex, pixelsizey, skewx, skewy) - realign and modify pixelsize and skew with different values for x and y using the specified method
    433
    434  * The '''third series of variants''' align and resample the raster to match the alignment, pixelsize and skew of an existing raster.
    435
    436  11) ST_Resample(destraster, sourceraster)
    437
    438  '''Questions'''
    439
    440  * Should there be a band parameter?
    441  * How does GDAL allow resampling?
    442  * Which methods GDAL supports? ArcGIS supports NEAREST | BILINEAR | CUBIC | MAJORITY
    443  * Does GDAL support change in skew?
     403'''ST_Resample(raster, method, originx, originy, pixelsizex, pixelsizey) -> raster - done see below'''
    444404
    445405'''ST_SelectByValue(raster, 'expression') -> same type as first argument'''
    27462706ST_Transform enables the end-user to reproject a raster to a new projection.  Unlike the ST_Transform function for geometries, ST_Transform for rasters depends upon the specificiation of a resampling algorithm and an error tolerance.  In addition, reprojecting a raster will probably change the scale of the pixels.  Therefore, ST_Transform for rasters can be more involved than the ST_Transform for geometries.
    27472707
     2708''If a skewed raster is provided to ST_Transform, the output raster will be deskewed (zero skew in X and Y axes thus "north up").  To preserve the skew, use ST_Resample.''
     2709
    274827101. ST_Transform(rast raster, srid integer, algorithm text DEFAULT '!NearestNeighbour', maxerr double precision DEFAULT 0.125, scalex double precision DEFAULT 0, scaley double precision DEFAULT 0)
    27492711
    32413203
    32423204    nband is assumed to be 1. roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE.
     3205
     3206----
     3207
     3208'''ST_Resample(raster, method, originx, originy, pixelsizex, pixelsizey) -> raster'''
     3209
     3210ST_Resample is the main function underlying the ST_Transform, ST_Rescale, ST_Reskew and ST_SnapToGrid functions.  ST_Resample provides the ability to change a raster's projection, adjust the scale of the raster within its extent, change the skew (or deskew) and "dissolve" the raster to a grid.
     3211
     3212''If a skewed raster is provided to ST_Resample and skewx and/or skewy are not provided, the output raster will be deskewed (zero skew in X and Y axes thus "north up")''
     3213
     32141. ST_Resample(
     3215        rast raster,
     3216        srid integer DEFAULT NULL,
     3217        scalex double precision DEFAULT 0, scaley double precision DEFAULT 0,
     3218        gridx double precision DEFAULT NULL, gridy double precision DEFAULT NULL,
     3219        skewx double precision DEFAULT 0, skewy double precision DEFAULT 0,
     3220        algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125
     3221) -> raster
     3222
     3223  srid: the SRID that the function will use to reproject the raster to.  If NULL, the raster's SRID will be used.
     3224
     3225  scalex: the scale/pixel size in the X axis of the resampled raster.  If scalex and scaley are zero (0), the resampled raster's scale will be autocomputed.  If provided, scaley must also be provided.
     3226
     3227  scaley: the scale/pixel size in the Y axis of the resampled raster.  If scalex and scaley are zero (0), the resampled raster's scale will be autocomputed.  If provided, scalex must also be provided.
     3228
     3229  gridx: the X coordinate of a point on the grid to which the raster will be aligned.  Value is in the resampled raster's world coordinates.  If provided, gridy must also be provided.
     3230
     3231  gridy: the Y coordinate of a point on the grid to which the raster will be aligned.  Value is in the resampled raster's world coordinates.  If provided, gridx must also be provided.
     3232
     3233  skewx: the skew along the X axis of the resampled raster.  If skewx and skewy are zero (0), the resampled raster will be "north up".
     3234
     3235  skewy: the skew along the Y axis of the resampled raster.  If skewx and skewy are zero (0), the resampled raster will be "north up".
     3236
     3237  algorithm: the algorithm to use when resampling the raster. default is 'NearestNeighbour'. possible algorithms are:
     3238
     3239{{{
     3240NearestNeighbour (default.  fastest performance but worst interpolation)
     3241
     3242NearestNeighbor (for those wanting to use the American spelling)
     3243
     3244Bilinear
     3245
     3246Cubic
     3247
     3248CubicSpline
     3249
     3250Lanczos
     3251}}}
     3252
     3253  maxerr: the threshold for approximation by the resampling algorithm (in pixel units). default is 0.125, which is the same value used in GDAL gdalwarp utility. if set to zero, no approximation takes place.
     3254
     32552. ST_Resample(
     3256        rast raster,
     3257        ref raster,
     3258        algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125
     3259) -> raster
     3260
     3261  ref: the reference raster to which rast will copy the scalex, scaley, skewx, skewy and srid.  In addition, the upperleft corner of ref will be used as a grid point to align rast.
     3262
     3263----
     3264
     3265'''ST_Rescale(raster, scalex, scaley) -> raster'''
     3266
     3267ST_Rescale is a focused function of ST_Resample for changing the X and Y scale without affecting the extent of the raster.
     3268
     3269''If a skewed raster is provided to ST_Rescale, the output raster will be deskewed (zero skew in X and Y axes thus "north up").  To preserve the skew, use ST_Resample.''
     3270
     32711. ST_Rescale(rast raster, scalex double precision, scaley double precision, algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125) -> raster
     3272
     3273  scalex: the scale/pixel size in the X axis of the resampled raster
     3274
     3275  scaley: the scale/pixel size in the Y axis of the resampled raster
     3276
     32772. ST_Rescale(rast raster, scalexy double precision, algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125) -> raster
     3278
     3279  scalexy: the scale/pixel size in the X and Y axes of the resampled raster.
     3280
     3281----
     3282
     3283'''ST_Reskew(raster, skewx, skewy) -> raster'''
     3284
     3285ST_Reskew is a focused function of ST_Resample for changing the skew along the X and Y axes.
     3286
     32871. ST_Reskew(rast raster, skewx double precision, skewy double precision, algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125) -> raster
     3288
     3289  skewx: the skew along the X axis of the resampled raster.  If skewx and skewy are zero (0), the resampled raster will be "north up".
     3290
     3291  skewy: the skew along the Y axis of the resampled raster.  If skewx and skewy are zero (0), the resampled raster will be "north up".
     3292
     32932. ST_Reskew(rast raster, skewxy double precision, algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125) -> raster
     3294
     3295  skewxy: the skew along both X and Y axes of the resampled raster.  If skewxy is zero (0), the resampled raster will be "north up".
     3296
     3297----
     3298
     3299'''ST_SnapToGrid(raster, gridx, gridy)'''
     3300
     3301ST_SnapToGrid provides the ability to align a raster to grid (possibly that of a coverage).  The returned raster has its upper-left corner placed at the closest valid grid point to the source raster's upper-left corner without losing a data.  The same is done for the lower-right corner.
     3302
     3303''If a skewed raster is provided to ST_SnapToGrid, the output raster will be deskewed (zero skew in X and Y axes thus "north up").  To preserve the skew, use ST_Resample.''
     3304
     33051. ST_SnapToGrid(
     3306        rast raster,
     3307        gridx double precision, gridy double precision,
     3308        algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125,
     3309        scalex double precision DEFAULT 0, scaley double precision DEFAULT 0
     3310) -> raster
     3311
     3312  gridx: the X coordinate of a point on the grid to which the raster will be aligned.  Value is in the raster's world coordinates.
     3313
     3314  gridy: the Y coordinate of a point on the grid to which the raster will be aligned.  Value is in the raster's world coordinates.
     3315
     3316  scalex: the scale/pixel size in the X axis of the resampled raster.  This is also the scale of the grid to which the raster is being "snapped".  If provided, scaley must be provided.  If scalex and scaley are zero, the input raster's scale will be used.
     3317
     3318  scaley: the scale/pixel size in the Y axis of the resampled raster.  This is also the scale of the grid to which the raster is being "snapped"  If provided, scalex must be provided.  If scalex and scaley are zero, the input raster's scale will be used.
     3319
     33202. ST_SnapToGrid(
     3321        rast raster,
     3322        gridx double precision, gridy double precision,
     3323        scalex double precision, scaley double precision,
     3324        algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125
     3325) -> raster
     3326
     33273. ST_SnapToGrid(
     3328        rast raster,
     3329        gridx double precision, gridy double precision,
     3330        scalexy double precision,
     3331        algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125
     3332) -> raster
     3333
     3334  scalexy: the scale/pixel size in the X and Y axes of the resampled raster.
     3335
     3336~~ * Implemented as a wrapper around GDAL like done for ST_DumpAsPolygons()~~
     3337~~ * Resampling methods are the same as the one priovided by GDAL~~
     3338
     3339~~ '''Variants'''~~
     3340
     3341~~ * The '''first series of variants''' only change the pixelsize of the raster.~~
     3342
     3343~~ 1) ST_Resample(raster, pixelsize) - modify pixelsize only and resample using the default method~~
     3344
     3345~~ 2) ST_Resample(raster, method, pixelsize) - modify pixelsize and resample using the specified method~~
     3346
     3347~~ 3) ST_Resample(raster, pixelsizex, pixelsizey) - modify pixelsize with different values for x and y using the default method~~
     3348
     3349~~ 4) ST_Resample(raster, method, pixelsizex, pixelsizey) - modify pixelsize with different values for x and y using the specified method~~
     3350
     3351~~ * The '''second series of variants''' realign the raster and change the pixelsize~~
     3352
     3353~~ 5) ST_Resample(raster, x, y, pixelsize) - realign and modify pixelsize using the default method~~
     3354
     3355~~ 6) ST_Resample(raster, method, x, y, pixelsize) - realign and modify pixelsize using the specified method~~
     3356
     3357~~ 7) ST_Resample(raster, x, y, pixelsizex, pixelsizey) - realign and modify pixelsize with different values for x and y using the default method~~
     3358
     3359~~ 8) ST_Resample(raster, method, x, y, pixelsizex, pixelsizey) - realign and modify pixelsize with different values for x and y using the specified method~~
     3360
     3361~~ 9) ST_Resample(raster, x, y, pixelsizex, pixelsizey, skewx, skewy) - realign and modify pixelsize and skew with different values for x and y using the default method~~
     3362
     3363~~ 10) ST_Resample(raster, method, x, y, pixelsizex, pixelsizey, skewx, skewy) - realign and modify pixelsize and skew with different values for x and y using the specified method~~
     3364
     3365~~ * The '''third series of variants''' align and resample the raster to match the alignment, pixelsize and skew of an existing raster.~~
     3366
     3367~~ 11) ST_Resample(destraster, sourceraster)~~
     3368
     3369~~ '''Questions'''~~
     3370
     3371~~ * Should there be a band parameter?~~
     3372
     3373~~ * How does GDAL allow resampling?~~
     3374
     3375~~ * Which methods GDAL supports? ArcGIS supports NEAREST | BILINEAR | CUBIC | MAJORITY~~
     3376
     3377~~ * Does GDAL support change in skew?~~
     3378
