Changes between Version 146 and Version 147 of WKTRaster/SpecificationWorking03
Show
07/11/11 14:12:55 (23 months ago)
pracine
  • WKTRaster/SpecificationWorking03
    v146 v147
    538538
    539539----
     540== '''Objective FV.19 - Being able burn geometries to existing raster''' ==
     541
     542'''ST_BurnToRaster(rast, geometry[, value, expression, nodata1expr, nodata2expr, nodatanodataexpr]) -> raster'''
     543
     544 * Burn a raster to the band of an existing raster.
     545
     546 * No geoferencing metadata have to be provided since the ones of the provided raster are used.
     547
     548 * This function is mostly different from the ST_AsRaster(geometry) by the fact that it must provide some options to take into account the existing pixel values when burning the new value associated with the geometry.
     549
     550 * It should be implemented as some wrappers around ST_MapAlgebra(raster, band, ST_AsRaster(geometry, val, raster, "CROP"), 'expression', 'nodata1expr', 'nodata2expr', 'nodatanodataexpr').
     551
     552 * 'expression', 'nodata1expr', 'nodata2expr', 'nodatanodataexpr' are SQL expressions passed to the underlying two raster map algebra function:
     553
     554 -'expression' is evaluated when both pixels have a value associated with them. The default for this expression is 'LAST'.[[BR]]
     555 -'nodata1expr' is evaluated when rast1 is a nodata value and rast2 has a value associated with it. The default for this expression is NULL.[[BR]]
     556 -'nodata2expr' is evaluated when rast2 is a nodata value and rast1 has a value associated with it. The default for this expression is NULL.[[BR]]
     557 -'nodatanodataexpr' is evaluated when both pixels are nodata values. The default for this expression is NULL.
     558
     559 * Here are some commonly used predefined expressions and how they materialize as the ST_Mapalgebra(rast1, rast2) expression, nodata1expr and nodata2expr, and nodatanodataexpr.
     560
     561 -LAST: expression = 'rast2'. This is the default ST_BurnToRaster expression.
     562
     563 -COUNT: expression = '2', nodata1expr = '1', nodata2expr = '1', nodatanodataexpr = '0'
     564
     565 -MAX: expression = 'GREATEST(rast1, rast2)' , nodata1expr = 'rast2', nodata2expr = 'rast1', nodatanodataexpr = 'NULL'
     566
     567 -MIN: expression = 'LEAST(rast1, rast2)' , nodata1expr = 'rast2', nodata2expr = 'rast1', nodatanodataexpr = 'NULL'
     568
     569 -RANGE: expression = 'ABS(rast1 - rast2)' , nodata1expr = '0', nodata2expr = '0', nodatanodataexpr = 'NULL'
     570
     571 -SUM: expression = 'rast1 + rast2' , nodata1expr = 'rast2', nodata2expr = 'rast1', nodatanodataexpr = 'NULL'
     572
     573 -MEAN: expression = '(rast1 + rast2)/2' , nodata1expr = 'rast2', nodata2expr = 'rast1', nodatanodataexpr = 'NULL'
     574
     575 * When expression is 'LAST' the process can be implemented with GDALRasterizeLayers since, apparently GDALRasterizeLayers do not allow other burning rules.
     576
     577'''ST_UnionToRaster(set of geometry[, p_expr, t_expr, f_expr]) -> raster'''
     578
     579 * ST_UnionToRaster is an aggregate function very similar to ST_Union(set of raster) which burn, one after the other, all the geometries of a table, or selected by a GROUP BY clause, into a unique raster.
     580
     581 * It is implemented as a wrapper around ST_Union(ST_AsRaster(geometry, value, raster, band, p_expression, t_expression, f_expression)) function.
     582
     583 * Variants
     584
     585 1) ToRaster(raster, band, geometry, val)
     586 2) ToRaster(raster, band, geometry, val, p_expression)
     587 3) ToRaster(raster, band, geometry, val, p_expression, t_expression)
     588 4) ToRaster(raster, band, geometry, val, p_expression, t_expression, f_expression)
     589
     590----
    540591== '''Other functions''' ==
    541592
