Changes between Version 49 and Version 50 of WKTRaster/SpecificationWorking02
Mar 10, 2011, 1:50:45 PM (13 years ago)
pracine
  • WKTRaster/SpecificationWorking02
    v49 v50
    7272 '''Implementation details'''
    7373
    74  Only the first variant should be implemented in C. Others are PL/pgSQL variants. The C implementation should follow the PL/pgSQL script of the one raster version of ST_MapAlgebra implemented at the top of http://trac.osgeo.org/postgis/browser/spike/wktraster/scripts/plpgsql/st_mapalgebra.sql
     74 Only the first variant should be implemented in C. Others are PL/pgSQL variants. The C implementation should follow the PL/pgSQL script of the one raster version of ST_MapAlgebra implemented at the top of http://trac.osgeo.org/postgis/browser/trunk/raster/scripts/plpgsql/st_mapalgebra.sql
    7575
    7676 Optimizations should be implemented in many situations:
    111111 '''Implementation Details'''
    112112
    113  Only the first variant should be implemented in C. The second one is a PL/pgSQL variants. The C implementation should follow the PL/pgSQL version implemented in http://trac.osgeo.org/postgis/browser/spike/wktraster/scripts/plpgsql/st_mapalgebra.sql
     113 Only the first variant should be implemented in C. The second one is a PL/pgSQL variants. The C implementation should follow the PL/pgSQL version implemented in http://trac.osgeo.org/postgis/browser/trunk/raster/scripts/plpgsql/st_mapalgebra.sql
    114114
    115115 It is not clear if this PL/pgSQL implementation works when raster are rotated. To verify.
    116116
    117117
    118 '''ST_MapAlgebra'''
    119
    120  TBD
     118'''ST_MapAlgebra on two rasters'''
     119
     120 Specifications of ST_MapAlgebra on two rasters are still in progress as a new optimised version, filling large areas of same value more quickly, is planned. See http://trac.osgeo.org/postgis/browser/trunk/raster/scripts/plpgsql/st_mapalgebra_optimized.sql
    121121
    122122----
