Changes between Version 27 and Version 28 of WKTRaster/SpecificationWorking02
Sep 17, 2010, 8:48:04 AM (14 years ago)
pracine
  • WKTRaster/SpecificationWorking02
    v27 v28
    9898 This function is necessary to optimize ST_Intersection. The raster to be polygonised before proceeding to a vector intersection should first be clipped to the minimal intersecting area using ST_Clip().
    9999
    100 ----
    101 == '''Objective B02x - Being able to intersect vector and raster to produce raster.''' ==
    102
    103
    104 '''ST_Intersects(raster, raster)'''[[BR]]
    105 '''ST_AsRaster(geometry, pixelsize) -> raster'''[[BR]]
    106 '''ST_Intersection(geometry, val, raster, band) -> raster'''
    107
    108  The first series of variant return a raster having the same extent as the provided raster.
    109
    110   Variant 1: ST_Intersection(geometry, val, raster, band, pixeltype, nodatavalue) -> raster
    111
    112   Variant 2: ST_Intersection(raster, band, geometry, val, pixeltype, nodatavalue) -> raster
    113
    114   Variant 3: ST_Intersection(geometry, val, raster, pixeltype, nodatavalue) -> raster
    115
    116   Variant 4: ST_Intersection(raster, geometry, val, pixeltype, nodatavalue) -> raster
    117
    118  The second series of variant return a raster having the minimal extent.
    119
    120   Variant 5: ST_Intersection(geometry, val, raster, band, pixeltype, nodatavalue, 'TRIM') -> raster
    121
    122   Variant 6: ST_Intersection(raster, band, geometry, val, pixeltype, nodatavalue, 'TRIM') -> raster
    123
    124   Variant 7: ST_Intersection(geometry, val, raster, pixeltype, nodatavalue, 'TRIM') -> raster
    125
    126   Variant 8: ST_Intersection(raster, geometry, val, pixeltype, nodatavalue, 'TRIM') -> raster
    127
    128  Return a two bands raster the first band containing only the pixels from the provided raster intersecting with the geometry and the second band containing the same area filled with the provided value.
    129
    130  The second band gets its pixeltype and nodatavalue from the parameters.
    131
    132  Non intersecting pixels are filled with nodata values.
    133
    134  Variant 1 return a raster having the same extent as the provided raster.
    135
    136  Variant 3, 4, 7 and 8 defaults the band number to 1.
    137
    138  Variant 5 to 8 "trim" or "crop" the raster to the withvalue extent (removing extra nodata value pixels surrounding the extent of the resulting withvalue extent).
    139
    140
    141  '''Open question'''
    142
    143  PR: Shoud we return one raster per raster/geometry couple or split the raster into as many small rasters as there are areas sharing a same value? The second behavior seems more coherent with the present behavior of ST_Intersection(raster, geometry) -> geometry even if this would produce tons of small two bands rasters.
    144
    145  '''Implementation details'''
    146
    147  Rasterize the geometry as a new raster (ST_AsRaster(geometry, pixeltype, val, nodataval, raster)) and then copy only pixels for which both raster bands have a value.
    148  Should be implemented as a wrapper around ST_MapAlgebra after rasterizing the geometry to a raster having the same alignment as the raster.
    149
    150 ----
    151 == '''Objective B02x - Being able to use "group by" to accumulate tiles to form a new raster.''' ==
    152
    153
    154 '''ST_Union(raster|geometry, raster|geometry, ‘raster’|’geometry’) -> raster/geometry'''[[BR]]
    155 '''ST_Accum(raster set|geometry set, ‘raster’|’geometry’) -> raster/geometry'''
    156100
    157101----
